Serviio Startup Error: No JVM could be found on your system
serviiobbbb
Post Mon Dec 29, 2014 3:28 pm
I just installed Serviio 1.4.1.2. When I start the Serviio Console, I get this error:
"No JVM could be found on your system. please define EXE4J_JAVA_HOME to point to an installed 64-bit JDK or JRE or download a JRE from http://www.java.com"
PC Info: Win7 64bit
Steps I took:
• Updated my Java to v 8.25 - no change in the issue
• Uninstalled Java
• Rebooted my PC
• Reinstalled Java v8.25 - no change
Not sure what to do next to get Serviio to work.
PLEASE HELP!!!
Post Mon Dec 29, 2014 4:00 pm
Re: Serviio Startup Error: No JVM could be found on your sys
You need 64 bit Java installed, not 32-bit.
If you search on this forum, you will find the solution too.
serviiobbbb
Post Mon Dec 29, 2014 6:23 pm
I did search before I posted but I apparently did not use the best search phrases because I could not locate any threads on this topic. Your solution fixed it!! Thanks!!!
