Problem with version 1.5
BaX
Post Fri Jan 16, 2015 10:11 pm
I just installed version 1.5, but the application will not pick up my rendering device (an LG 55L V5400 television) in the Status window. After several attempts to get the system working, I reverted to version 1.4.1.2 and the device showed immediately. Suggestions? I use an iMac 27" Late 2012 computer, running OSX 10.10, with 32GB of RAM.
BaX
stefana888
Post Fri Jan 16, 2015 11:13 pm
Re: Problem with version 1.5
wrong post
Post Sat Jan 17, 2015 12:30 am
you will have to post a detailed log as a minimum for us to help
BaX
Post Sat Jan 17, 2015 11:30 pm
I followed the instructions exactly as indicated. I'll try it again.
BaX
Post Sun Jan 18, 2015 12:45 pm
this is not detailed log. Follw the steps in the link and post the log again - there should be a lot of DEBUG lines
in the meantime, I assume 192.168.1.27 is the IP of your Mac?
Also, do you have a firewall that might be blocking port 8895 for the app (the name and location of serviio has changed in 1.5, so the firewall rules might need o be updated)
BaX
Post Mon Jan 19, 2015 5:21 am
It appears port 8895 is open:
“From the Apple Network Utility”
Esamina Porte avviato...
Port Scanning host: 192.168.1.27
Open TCP Port: 8000 irdmi
Open TCP Port: 8080 http-alt
Open TCP Port: 8088 radan-http
Open TCP Port: 8888 ddi-tcp-1
Open TCP Port: 8895
Esamina Porte completato...
“From Unix-based Command”
MY-iMac:~ computername$ sudo lsof -i -P | grep -i "listen"
JavaAppli 958 username 96u IPv4 0x229f8373c718c177 0t0 TCP *:8895 (LISTEN)
Post Mon Jan 19, 2015 10:26 am
how about UDP 1900 ?
BaX
Post Tue Jan 20, 2015 3:51 am
It also appears UDP 1900 is open:
iMac:~ username$ sudo lsof -i -P
JavaAppli 958 username 85u IPv4 0x229f8373c83bb05f 0t0 UDP *:1900
BaX
Post Tue Jan 20, 2015 10:38 am
I'm not sure how the firewall on OSF works, but is it tied to a username? Serviio now runs as 'root'...
Users browsing this forum: Google [Bot] and 15 guests
