Skipping unfinished files on version 1.5
spepe
Post Thu Jan 22, 2015 2:42 pm
Hi all,
After the update to new version 1.5, I experience some issues that i do not know how to deal with them.
Each time when i download a movie, servio is processing the file as unsupported :
2015-01-22 16:16:27,121 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (D:\Downloads\Houdini.Part2.2014.EXTENDED.720p.BluRay.x264-TOPCAT\Sample\sample-houdini.part2.2014.extended.720p.bluray.x264-topcat.mkv). Message: Unknown video file type.
this happens because at the time it appears in the folder, the file it is not downloaded 100%, but serviio once it marks the file like this the only way in order to refresh is by using force refresh from console .
in the previous folder the functionality was ok ... there was no need for me to push manual refresh once the file was downloaded
Can u please assist me in this matter ... i use the PRO license
Post Thu Jan 22, 2015 5:19 pm
Re: Skipping files on version 1.5
Yes, it's the cons of the new files detection system. Before it was basically making 'force refreshes' each 5 minutes, now Serviio only detects file changes. For torrent, the file is created in full file size (with zeros) and then filled in as the download progresses - thus the OS doesn't see any change to the file really.
So to get around it, you can either:
- use force refresh button
- download files into a different folder and move the files to the shared folder once they are fully downloaded
Post Thu Jan 22, 2015 9:25 pm
Re: Skipping unfinished files on version 1.5
I had the same problem and have overcome it by: viewtopic.php?f=17&t=18183
spepe
Post Fri Jan 23, 2015 6:43 am
Thanks for hint. It does the trick.
Users browsing this forum: Google [Bot] and 291 guests
