Playlist folder empty
tuareg64ve
Post Sat Jan 24, 2015 4:07 pm
Hi, I need an help to determine a problem.
My Serviio is installed on Centos 6.5, ffmpeg 2.2.1 with --enable-librtmp.
I am successfully using Serviio to watch movies and youtube channels.
I'd like to try some streaming video/audio.
For this purpose I have downloaded from internet the following play list but I did not get any resource in the Playlist folder.
English.txt
playlist
(3.92 KiB) Downloaded 531 times
So I enabled DEBUG in the logs and discover the playlist is read, but I get many of the following messages:
Item 'rtmp://xxx' cannot be resolved to an entity in the Serviio library, will try again later
In attachment you can find the example for resource:
rtmp://cdn-sov-2.musicradio.com:80/LiveVideo/Capital
log error
I get the error message, but, as you can see in the following attachment, ffmpeg can access the stream correctly.
ffmpeg example
Can you just give me an hint where to investigate?
Post Sun Jan 25, 2015 2:47 am
Re: Playlist folder empty
This is just a guess, but I think Playlists only work for local files.
Post Sun Jan 25, 2015 2:16 pm
tuareg64ve
Post Sun Jan 25, 2015 9:08 pm
atc98092 wrote:This is just a guess, but I think Playlists only work for local files.
But is stored in a local file!
Then I have added the directory to online resources.
The playlist is recognized, but no item is added to the folder, because of the error above.
Any clue?
Post Mon Jan 26, 2015 1:52 pm
Serviio doesn't support playlists with online items. As per above.
tuareg64ve
Post Mon Jan 26, 2015 5:37 pm
zip wrote:Serviio doesn't support playlists with online items. As per above.
Ok, now it's clear.
