install issue on Mac
zingo1
Post Wed Feb 25, 2015 3:00 pm
Mac running on Yosemite 10.10.2
I have been using Serviio for some time now without any problems. I removed an older version and downloaded 1.5.1
If i am correct Serviio comes with two files, console and server. for some reason only the console is installing.
In my apps list there use to be two Serviio symbols and i opened both for serviio to work now i only have one symbol.
I have removed re downloaded a few times but still the same.
rodluvan
Post Sat Feb 28, 2015 9:00 pm
Re: install issue on Mac
I hve _exactly_ the same problem.
result: the serviio shows up on the tv, but no content.
Post Mon Mar 02, 2015 8:29 pm
Starting with 1.5 Serviio installs the server into a different location than Applications and it starts automatically. FAQ: http://serviio.org/component/content/article?id=21#q18
It was also mentioned in the release notes: http://serviio.org/news/84-version-1-5-released
Next time please read the docs before spamming the forum - thanks.
zingo1
Post Tue Mar 03, 2015 2:01 pm
Thanks for getting back to me.
I had already read the release notes and FAQ and did all as required but still got this message.
Cannot connect to server,it does not appear to be running
Even putting command to start it in the terminal did not work
I was just about to give up but tried removing it from the terminal and re install then re start in terminal and at last ``up and running``.
:D
rodluvan
Post Tue Mar 03, 2015 9:33 pm
yes, thanks for getting back,although id didn't address the paramount problem at all (no files showing up)
I simply rebooted and re-added media folder and voilá
Users browsing this forum: No registered users and 52 guests
