Metadata options keep re-ticking themselves
BadBunny
Post Tue Mar 17, 2015 11:46 am
In the Serviio console all the options in the Metadata tab keep re-ticking themselves after I restart the computer, and I can see in the logs that Serviio continues to look for and add metadata info for my media.
Is there a way to stop this? I don't use the web interface or need this metadata so thought that having it all un-ticked would speed up the process of adding media to my database, especially when building a new database.
Windows 7 64bit / Linux Mint 17.1 KDE 64bit (Dual boot)
Serviio v1.5.2
Enjoys a pint of fine wine and as many french fries as I can stuff in my face.
Post Tue Mar 17, 2015 12:01 pm
Re: Metadata options keep re-ticking themselves
To check to obvious first:
  • you are pressing the Save button after unchecking the Metadata options?; and
  • you are also unchecking the Metadata tickbox against all your shared folders (the "M" symbol) on the Library, Shared Folders tab (and pressing Save)?
<Edit> - actually, you only really need to do the second dot point to stop Metatdata collection.
BadBunny
Post Tue Mar 17, 2015 12:08 pm
The save button is actually not available after unticking the metadata options so I was just unticking and ticking something else on another tab to make the save button available, however I did not untick the metadata tickbox against the shared folders, silly me!
Thank you for pointing that out :)
Serviio v1.5.2
