MediaBrowser anonymous login
Sheriff Hobbes
Post Fri Mar 06, 2015 11:05 pm
I was happy to see that there was a new system property added to Serviio 1.5:
Dserviio.cdsAnonymousAccess
...which is supposed to enable MediaBrowser w/o the need to log in when set to "true".
I added this new parameter to JAVA_OPTS and I can verify that in serviio console the Remote/Security/Password field is now uneditable (grayed out), but when I open the MediaBrowser in Firefox, I still need to provide the password, no access otherwise. How come? :ugeek:
Running v1.5.1 on CentOS 7.0....
Thanks,
SH
Marriage is a three ring circus:
-engagement ring
-wedding ring
-suffering
H. L. Mencken
Post Sun Mar 08, 2015 12:51 pm
Re: MediaBrowser anonymous login
try to clean your browser cache
DaFerociousBeast
Post Sat Mar 21, 2015 1:34 pm
Where is this property located? Which file?
Sheriff Hobbes
Post Sat Mar 21, 2015 4:55 pm
@DaFerociousBeast: See here: http://www.serviio.org/index.php?option ... icle&id=43
@zip: I doubt that was the problem, but I can't check because I went back to Serviio 1.4.
-engagement ring
-wedding ring
-suffering
H. L. Mencken
