DSM 5.1 - 5022 Update 3 doesn`t work with Serviio 1.4.1.2
tomek7
Post Sun Mar 15, 2015 10:40 am
I can`t make it work, please help!
When I check Serviio log at DSM I see that new files are being updated (from time to time new files are added) to the library, but this is now going like this for 40 hours although I disabled thumbnails in console. Usually when serviio was adding a new files I could see new folders on my tv, not now.
I am attachig serviio log. I run console on windows 8, Serviio is visible on my tv however I can`t browse folders...
Model name: DS112j
CPU: MARVELL Kirkwood 88F6702
CPU clock rate: 1 GHz
CPU cores: 1
Total physical memory: 128 MB
DSM version: DSM 5.1-5022 Update 3
(9.99 KiB) Downloaded 517 times
Post Sun Mar 15, 2015 12:11 pm
Re: DSM 5.1 - 5022 Update 3 doesn`t work with Serviio 1.4.1.
This is the console log, we ill need the server log, stored on your NAS in the Serviio installation folder.
tomek7
Post Sun Mar 15, 2015 2:52 pm
Thank you for looking into my problem, I am not sure where can I find this log file.
I have one serviio folder on my Nas in Homes but inside of this folder there is only one folder called .java and 2 other files calles .dir and .profile. DO i need to eneble detailed logging?
I am attaching print screen from DSM, I hope this will help.
tomek7
Post Sun Mar 29, 2015 12:10 pm
I re installed serviio server and console and now everything is working, we can close this thread.
