How to delete data (list IPTV) from the library ?
Eltosh
Post Sat Jun 11, 2016 2:14 pm
Hi
I am using Serviio on PS4.
I installed a brazilian IPTV list, I need now to delete it from the library.
How to do please ?
Thanks for your help
Post Sun Jun 12, 2016 9:32 am
Re: How to delete data (list IPTV) from the library ?
Do you mean a plugin or online resource?
rakesh456
Post Fri Apr 17, 2020 10:35 am
Hello, everyone.
To delete the data from the IPTV library, you need to remove the plugins that are installed like IPTV plugin and as well as the NextPVR plugin which is installed previously. Remove those two and restart the server. Your old data will be getting vanished as soon as you remove those two plugins.
Thank you.
Return to User experiences
