Serviio Broken after QTS 4.5.2 install ?
christruk42
Post Thu Mar 18, 2021 3:33 am
Has anybody else running Serviio (v2.1) on an x86 QNap had issues since installing QTS 4.5.2 ?
No problems up to this point but now I find that:-
the instance is invisible to all my DLNA devices
it is impossible to stop the Serviio Server from within the Serviio GUI - it just spins endlessly but never stops
I've completely uninstalled both Serviio and Java, rebooted and then re-installed. Same issue presents immediately.
Just looking for some more confirmation as I've raised a ticket with QNap but I kinda expect them to just blame the app.10.0.0.0.1 192.168.1.254
Post Thu Mar 18, 2021 1:20 pm
Re: Serviio Broken after QTS 4.5.2 install ?
Yes, there's several threads in the NAS section of the forum (viewforum.php?f=14) that describe QNap releasing an update that causes issues with Serviio. You might look in there to see if someone found a solution.
stepla
Post Tue Mar 23, 2021 6:50 pm
I have also had a problem, I thought that maybe it was something regarding the download but it seems to be a direct problem of the update
Return to User experiences
