Choppy playback on PS3
Evostance
Post Sun Dec 11, 2011 1:10 am
Does anyone experience intermittent pauses when playing back on a PS3? It's as if it keeps bufferring the content but im not sure why. I'm just playing some family guy so it's low resolution.
Nothing else is using the network at the moment so not sure what could cause it. It doesn't happen all the time and I dont have issues when playing back via xmbc on my mac
Sent from my iPad 2 using Tapatalk
Evostance
Post Mon Dec 12, 2011 10:31 pm
Anyone?
Post Mon Dec 12, 2011 11:40 pm
Re: Choppy playback on PS3
you didn't provide any information based on which we could help.
Post Tue Dec 13, 2011 9:01 pm
with limited information provided the answer is no but give me somegthing specific to test and will have a look into it for you :)
Evostance
Post Wed Dec 14, 2011 12:04 am
Ok, sorry :)
What information do you require?
The server is a HP Proliant Microserver with 4gb ram.
My router is a Netgear N3000 (I think. It's the one that can do 2.4 and 5ghz at the same time)
PS3 is connected to the server via 2.4ghz connection, however my mac is too and it's further away from the router
Post Wed Dec 14, 2011 12:11 am
Post Wed Dec 14, 2011 12:15 am
change your wifi channel on your router to channel 9, you can do this by:
1. in IE type 192.168.1.1
2. enter login details
username: admin
Password: password
3. go to wifi settings and set wifi channel to 9
i could prolly talk you thorugh it better but im not at home near my reference info so cant be more specific but should be obvious once your there. :)
Evostance
Post Thu Dec 15, 2011 11:56 pm
Cheers zip. I posted from tapatalk so didn't see it. I'll get the logs
Evostance
Post Fri Dec 16, 2011 6:38 pm
Ok,
Wifi channel changes to 9 and heres the Serviio.log in debug mode.
serviio.log.zip
(25.25 KiB) Downloaded 605 times
I just tried to play it on a HD Video which I know will stutter, however the stuttering also occurs on just normal SD videos. I was watching Misfits last night on it and it kept stuttering.
ffmpeg version 0.7.2-4:0.7.2-1ubuntu1, Copyright (c) 2000-2011 the Libav developers
built on Oct 2 2011 15:12:32 with gcc 4.6.1
configuration: --extra-version='4:0.7.2-1ubuntu1' --arch=i386 --prefix=/usr --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --enable-shared --disable-static
WARNING: library configuration mismatch
avutil configuration: --extra-version='4:0.7.2-1ubuntu1' --arch=i386 --prefix=/usr --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
avcodec configuration: --extra-version='4:0.7.2-1ubuntu1' --arch=i386 --prefix=/usr --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
avformat configuration: --extra-version='4:0.7.2-1ubuntu1' --arch=i386 --prefix=/usr --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
avdevice configuration: --extra-version='4:0.7.2-1ubuntu1' --arch=i386 --prefix=/usr --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
avfilter configuration: --extra-version='4:0.7.2-1ubuntu1' --arch=i386 --prefix=/usr --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
swscale configuration: --extra-version='4:0.7.2-1ubuntu1' --arch=i386 --prefix=/usr --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
postproc configuration: --extra-version='4:0.7.2-1ubuntu1' --arch=i386 --prefix=/usr --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
libavutil 51. 7. 0 / 51. 7. 0
libavcodec 53. 5. 0 / 53. 5. 0
libavformat 53. 2. 0 / 53. 2. 0
libavdevice 53. 0. 0 / 53. 0. 0
libavfilter 2. 4. 0 / 2. 4. 0
libswscale 2. 0. 0 / 2. 0. 0
libpostproc 52. 0. 0 / 52. 0. 0
Input #0, avi, from '/media/sdd1/Videos/Films/Tron Legacy.avi':
encoder : VirtualDubMod 1.5.10.2 (build 2540/release)
Duration: 02:05:08.66, start: 0.000000, bitrate: 4457 kb/s
Stream #0.0: Video: mpeg4, yuv420p, 1280x720 [PAR 1:1 DAR 16:9], 23.98 tbr, 23.98 tbn, 23.98 tbc
Stream #0.1: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
Post Fri Dec 16, 2011 8:04 pm
ok, this file is played natively. Can you try connecting via cable rather than wi-fi (for a test)?
Evostance
Post Sat Dec 17, 2011 12:42 am
Unfortunately not :(
I think perhaps its to do with network traffic? My dad has suggested that when it happens rarely on the TV, that he can pause the stream for a bit to let it buffer and it will play OK.
What I can't understand is why the PS3 stutters, yet my Mac which is next to it, doesn't.
The issue is that its completely random. Theres no set period in a movie when it will do it. Last week I tried to stream Tron and it couldnt even get past the opening without stuttering. On that stream I posted, it got a few minutes in
Return to User experiences
