[Solved] Random disconnection
vtec123
Post Mon Mar 26, 2012 5:10 pm
Hi Guys
Newbeee... :)
I have a Samsung D8000 SMART T.V hard wired cat5e.
Serviio running on windows 7 64bit Laptop wireless
BT HUB 3 router
Serviio keeps disconnecting all the time?
can anyone help changed channel on router from 11 to 4 no good
re-installed serviio no good
please see logs
(179.84 KiB) Downloaded 711 times
Post Mon Mar 26, 2012 6:55 pm
Re: Random disconnection
did you search the forum?
vtec123
Post Mon Mar 26, 2012 7:09 pm
loads mate
i have changed loads of things but still no joy :?
Post Mon Mar 26, 2012 7:15 pm
it's usually caused by dodgy routers and/or bad wifi connection
Post Mon Mar 26, 2012 7:17 pm
Make and model of router. Do google search for inssider I think that is correct spelling. It is a wifi monitor and see if someone else around you is on the same freq. Look under Third party apps here in forums also
Sent from my DROID RAZR using Tapatalk
vtec123
Post Mon Mar 26, 2012 7:38 pm
changed my channel on my router ..still no good
it's a brand new router...
also Samsung All-share work prefect.....?
also have hard wired it still get disconnection ?
vtec123
Post Tue Mar 27, 2012 7:05 pm
Hi Guys
I have tried Nearly everything to get serviio work....
It connects to my T.V for about 20-25 sec and disconnects
My Router is the NEW BT HOME HUB 3...
So I Download Mezzmo and tried that ...and it worked no problem perfect!!
I really want to get serviio to work...
PLease Help
Post Wed Mar 28, 2012 12:40 pm
does this happen for every file? videos and music?
vtec123
Post Wed Mar 28, 2012 3:32 pm
Hi Zip
Can not see any-files ?
I see my Folder but noting in them ..
Thanx
Post Wed Mar 28, 2012 3:39 pm
post the log please, ideally detailed
vtec123
Post Wed Mar 28, 2012 4:49 pm
Hi zip
I think I did in my first Post
I can re-post logs again
Thanx
vtec123
Post Wed Mar 28, 2012 8:06 pm
Right did some more checks and things...
This is what is happening ...
The serviio services keep stopping that why it disconnects from my Samsung T.V ..soon as i restart the services it connects back for about 30 sec and the disconnects ...???
ANY ideas ...pls
some log files too
Thnx
(73.72 KiB) Downloaded 683 times
Post Thu Mar 29, 2012 9:05 am
weird.. post detailed log please.
vtec123
Post Thu Mar 29, 2012 3:14 pm
Detailed logs Zip..
Thanx again for your help
(194.19 KiB) Downloaded 712 times
vtec123
Post Thu Mar 29, 2012 3:47 pm
Hi Zip
I have Fixed the disconnection problem it was Spy_Bolt running in the background Doh!!!! did not know that it was running ...lol...
Thanx
Return to User experiences
