No Files found
aSystemOverload
Post Thu Apr 05, 2012 7:39 pm
No Files found
I've set up Serviio on a Win7 little box, then clicked on it from another win7 machine thru windows media player and both in Videos and Music it says no files found, even though I've got two folder shares, one for videos and one for music.
Any ideas?
Post Thu Apr 05, 2012 7:54 pm
Re: No Files found
WMP doesn't work properly as it isn't DLNA compliant (might work if you select the XBOX 360 profile), you can use VLC 2.0 or XBMC.
Return to User experiences
