Serviio and WDTV issue
purplemark123
Post Wed Apr 18, 2012 2:44 pm
I installed Serviio on my computer and everything is fine, it did detect my WDTV. I added a live stream to the library and WDTV picked it up, the problem is when I play the stream it will take at least 2 minutes :? to play/start, it's a really long time to start a channel up even when I change from one stream to another.
the stream is a http link.
On VLC it opens in 3 seconds.
Can you please let me know if there is anything i CAN DO / CHANGE on my WDTV config files or the serviio software ?
Thanks,
Post Wed Apr 18, 2012 4:14 pm
Re: Serviio and WDTV issue
purplemark123
Post Wed Apr 18, 2012 4:50 pm
Hey Zip,
Thanks for the respond.
I did look at the open ticket and the first person mentioned something about the videobroadcast. I did add
class => object.item...... and so on to my WDTV UMSP.php conf file, but nothing happened still the same.
is that the right place to insert it ? or which file I should edit ?
And you wrote Changed version from 0.6.1 to nothing. ???? what do you mean.
So you don't think it's something to do with transcoding ??
thanks,
Post Wed Apr 18, 2012 10:35 pm
It means i know about this problem, but it's WDTV specific and I'll look at it in future at some point. You can't do anything ATM.
purplemark123
Post Thu Apr 19, 2012 2:10 am
castalla
Post Sat Apr 21, 2012 2:54 am
Same problem here ... 1 minute to load a live stream.
And it can't play the BBC rss streams reliably - the audio drops out after about 1 minute.
Return to User experiences
