samsung le32c650 not find serviio
patillaldi
Post Thu Oct 28, 2010 2:42 pm
Re: samsung le32c650 not find serviio
Firewall windows turned off. I can ping from PC to TV.
My router is Webstar Scientific Atlanta DPR 2320.
Use the USB port to avoid having to buy the switch, but if it works the wifi connection so I have to buy
hennys
Post Thu Oct 28, 2010 6:04 pm
did you try a stop server - start server from the serviio console. this helps for me most of the times I cannot see serviio from the TV (samsung LE40C650)
Regards,
Hen
patillaldi
Post Thu Oct 28, 2010 6:52 pm
In Pc with serviio unplugged usb cable and connect wifi pendrive. Change IP to 192.168.0.13, open the ports in router and it not works.
Attach 2 images from Device Spy because I rarely bring up the ip 127.0.0.1.
Log with this information
2010-10-28 20:27:28,281 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2010-10-28 20:27:30,328 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /192.168.0.13:1086
2010-10-28 20:27:30,328 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /127.0.0.1:1087
2010-10-28 20:27:30,328 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s)
2010-10-28 20:27:32,343 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /192.168.0.13:1086
2010-10-28 20:27:32,343 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /127.0.0.1:1087
2010-10-28 20:27:32,359 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s)
2010-10-28 20:28:23,843 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /192.168.0.13:1086
2010-10-28 20:28:23,843 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s)
2010-10-28 20:28:23,875 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /192.168.0.13:1086
2010-10-28 20:28:23,875 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /127.0.0.1:1087
2010-10-28 20:28:23,875 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s)
2010-10-28 20:28:55,875 DEBUG [WebServer] Incoming connection from /192.168.0.13:57650
2010-10-28 20:28:55,875 DEBUG [ServiceEventSubscriptionRequestHandler] ServiceEvent renewal request received for service ContentDirectory and subscription uuid:69b689a7-da5d-48bd-b2d7-845e841954ea
2010-10-28 20:28:55,875 DEBUG [ServiceEventSubscriptionRequestHandler] Event subscription renewed for service urn:upnp-org:serviceId:ContentDirectory and subscription 69b689a7-da5d-48bd-b2d7-845e841954ea
2010-10-28 20:29:14,281 DEBUG [RepositoryDAOImpl] Reading all Repositories
2010-10-28 20:29:14,281 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: C:\Documents and Settings\monica\Escritorio\fotos
2010-10-28 20:29:14,296 DEBUG [LibraryAdditionsCheckerThread] Found file 'IMG_1073.jpg', checking if it's already in the Library
2010-10-28 20:29:14,296 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item IMG_1073.jpg
2010-10-28 20:29:14,312 DEBUG [MediaItemDAOImpl] Media item IMG_1073.jpg already exists in DB
2010-10-28 20:29:14,328 DEBUG [LibraryAdditionsCheckerThread] Found file 'IMG_1074.jpg', checking if it's already in the Library
2010-10-28 20:29:14,328 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item IMG_1074.jpg
2010-10-28 20:29:30,125 DEBUG [WebServer] Incoming connection from /192.168.0.13:1403
2010-10-28 20:29:43,359 DEBUG [WebServer] Incoming connection from /127.0.0.1:1408
2010-10-28 20:29:46,171 DEBUG [WebServer] Incoming connection from /192.168.0.13:1409
2010-10-28 20:29:46,187 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.0.13:51865
2010-10-28 20:29:46,203 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s)
2010-10-28 20:29:47,234 DEBUG [WebServer] Incoming connection from /192.168.0.13:52711
2010-10-28 20:29:47,234 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device dbda6698-2372-39e4-98c5-15b528e7d81f from WINDOWS, UPnP/1.0, Intel MicroStack/1.0.1497
2010-10-28 20:29:47,234 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Samsung TV / player (C-series)'
2010-10-28 20:29:47,234 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2010-10-28 20:29:47,234 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2010-10-28 20:29:47,234 DEBUG [ServiceEventSubscriptionRequestHandler] ServiceEvent subscription request received for service ContentDirectory
2010-10-28 20:29:47,234 DEBUG [ServiceEventSubscriptionRequestHandler] Event subscription registered (uuid=69200895-3832-41f0-be82-1bcf64aeefa8) for service urn:upnp-org:serviceId:ContentDirectory reporting to http://192.168.0.13:64794/serviceEventi ... tDirectory
2010-10-28 20:29:47,343 DEBUG [EventDispatcher] Sending event notification #0 for subscription 69200895-3832-41f0-be82-1bcf64aeefa8 to endpoint http://192.168.0.13:64794/serviceEventi ... tDirectory
2010-10-28 20:29:47,343 DEBUG [RequestExecutor] Sending HTTP request to 192.168.0.13:64794
2010-10-28 20:29:47,359 DEBUG [EventDispatcher] Event notification sent and received successfully
2010-10-28 20:29:47,359 DEBUG [EventDispatcher] Sending event notification #1 for subscription 69b689a7-da5d-48bd-b2d7-845e841954ea to endpoint http://192.168.0.13:64199/serviceEventi ... tDirectory
2010-10-28 20:29:47,359 DEBUG [RequestExecutor] Sending HTTP request to 192.168.0.13:64199
2010-10-28 20:29:48,359 WARN [EventDispatcher] Couldn't send event message for subscription 69b689a7-da5d-48bd-b2d7-845e841954ea, will keep trying until subscription expires
2010-10-28 20:29:51,296 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /192.168.0.13:1086
2010-10-28 20:29:51,296 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /127.0.0.1:1087
2010-10-28 20:29:51,296 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s)
2010-10-28 20:29:51,312 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s)
2010-10-28 20:31:17,234 DEBUG [WebServer] Incoming connection from /192.168.0.13:61417
2010-10-28 20:31:17,234 DEBUG [ServiceEventSubscriptionRequestHandler] ServiceEvent renewal request received for service ContentDirectory and subscription uuid:69200895-3832-41f0-be82-1bcf64aeefa8
2010-10-28 20:31:17,234 DEBUG [ServiceEventSubscriptionRequestHandler] Event subscription renewed for service urn:upnp-org:serviceId:ContentDirectory and subscription 69200895-3832-41f0-be82-1bcf64aeefa8
2010-10-28 20:31:56,078 DEBUG [EventSubscriptionExpirationChecker] Removed expired subscription 69b689a7-da5d-48bd-b2d7-845e841954ea from service urn:upnp-org:serviceId:ContentDirectory
2010-10-28 20:31:58,078 DEBUG [EventSubscriptionExpirationChecker] Removed expired subscription 69b689a7-da5d-48bd-b2d7-845e841954ea from service urn:upnp-org:serviceId:ContentDirectory
2010-10-28 20:32:00,078 DEBUG [EventSubscriptionExpirationChecker] Removed expired subscription 69b689a7-da5d-48bd-b2d7-845e841954ea from service urn:upnp-org:serviceId:ContentDirectory
2010-10-28 20:32:02,078 DEBUG [EventSubscriptionExpirationChecker] Removed expired subscription 69b689a7-da5d-48bd-b2d7-845e841954ea from service urn:upnp-org:serviceId:ContentDirectory
2010-10-28 20:32:04,078 DEBUG [EventSubscriptionExpirationChecker] Removed expired subscription 69b689a7-da5d-48bd-b2d7-845e841954ea from service urn:upnp-org:serviceId:ContentDirectory
2010-10-28 20:32:06,078 DEBUG [EventSubscriptionExpirationChecker] Removed expired subscription 69b689a7-da5d-48bd-b2d7-845e841954ea from service urn:upnp-org:serviceId:ContentDirectory
2010-10-28 20:32:08,078 DEBUG [EventSubscriptionExpirationChecker] Removed expired subscription 69b689a7-da5d-48bd-b2d7-845e841954ea from service urn:upnp-org:serviceId:ContentDirectory
2010-10-28 20:32:10,078 DEBUG [EventSubscriptionExpirationChecker] Removed expired subscription 69b689a7-da5d-48bd-b2d7-845e841954ea from service urn:upnp-org:serviceId:ContentDirectory
2010-10-28 20:32:12,078 DEBUG [EventSubscriptionExpirationChecker] Removed expired subscription 69b689a7-da5d-48bd-b2d7-845e841954ea from service urn:upnp-org:serviceId:ContentDirectory
2010-10-28 20:32:14,140 DEBUG [EventSubscriptionExpirationChecker] Removed expired subscription 69b689a7-da5d-48bd-b2d7-845e841954ea from service urn:upnp-org:serviceId:ContentDirectory
2010-10-28 20:32:16,140 DEBUG [EventSubscriptionExpirationChecker] Removed expired subscription 69b689a7-da5d-48bd-b2d7-845e841954ea from service urn:upnp-org:serviceId:ContentDirectory
2010-10-28 20:32:18,140 DEBUG [EventSubscriptionExpirationChecker] Removed expired subscription 69b689a7-da5d-48bd-b2d7-845e841954ea from service urn:upnp-org:serviceId:ContentDirectory
2010-10-28 20:32:20,140 DEBUG [EventSubscriptionExpirationChecker] Removed expired subscription 69b689a7-da5d-48bd-b2d7-845e841954ea from service urn:upnp-org:serviceId:ContentDirectory
2010-10-28 20:32:22,140 DEBUG [EventSubscriptionExpirationChecker] Removed expired subscription 69b689a7-da5d-48bd-b2d7-845e841954ea from service urn:upnp-org:serviceId:ContentDirectory
2010-10-28 20:32:24,140 DEBUG [EventSubscriptionExpirationChecker] Removed expired subscription 69b689a7-da5d-48bd-b2d7-845e841954ea from service urn:upnp-org:serviceId:ContentDirectory
2010-10-28 20:32:26,140 DEBUG [EventSubscriptionExpirationChecker] Removed expired subscription 69b689a7-da5d-48bd-b2d7-845e841954ea from service urn:upnp-org:serviceId:ContentDirectory
2010-10-28 20:32:28,140 DEBUG [EventSubscriptionExpirationChecker] Removed expired subscription 69b689a7-da5d-48bd-b2d7-845e841954ea from service urn:upnp-org:serviceId:ContentDirectory
2010-10-28 20:32:30,140 DEBUG [EventSubscriptionExpirationChecker] Removed expired subscription 69b689a7-da5d-48bd-b2d7-845e841954ea from service urn:upnp-org:serviceId:ContentDirectory
2010-10-28 20:32:32,140 DEBUG [EventSubscriptionExpirationChecker] Removed expired subscription 69b689a7-da5d-48bd-b2d7-845e841954ea from service urn:upnp-org:serviceId:ContentDirectory
2010-10-28 20:32:34,140 DEBUG [EventSubscriptionExpirationChecker] Removed expired subscription 69b689a7-da5d-48bd-b2d7-845e841954ea from service urn:upnp-org:serviceId:ContentDirectory
2010-10-28 20:32:36,140 DEBUG [EventSubscriptionExpirationChecker] Removed expired subscription 69b689a7-da5d-48bd-b2d7-845e841954ea from service urn:upnp-org:serviceId:ContentDirectory
2010-10-28 20:32:38,140 DEBUG [EventSubscriptionExpirationChecker] Removed expired subscription 69b689a7-da5d-48bd-b2d7-845e841954ea from service urn:upnp-org:serviceId:ContentDirectory
2010-10-28 20:32:40,140 DEBUG [EventSubscriptionExpirationChecker] Removed expired subscription 69b689a7-da5d-48bd-b2d7-845e841954ea from service urn:upnp-org:serviceId:ContentDirectory
2010-10-28 20:32:42,140 DEBUG [EventSubscriptionExpirationChecker] Removed expired subscription 69b689a7-da5d-48bd-b2d7-845e841954ea from service urn:upnp-org:serviceId:ContentDirectory
2010-10-28 20:32:44,140 DEBUG [EventSubscriptionExpirationChecker] Removed expired subscription 69b689a7-da5d-48bd-b2d7-845e841954ea from service urn:upnp-org:serviceId:ContentDirectory
2010-10-28 20:32:46,140 DEBUG [EventSubscriptionExpirationChecker] Removed expired subscription 69b689a7-da5d-48bd-b2d7-845e841954ea from service urn:upnp-org:serviceId:ContentDirectory
2010-10-28 20:32:47,734 DEBUG [WebServer] Incoming connection from /192.168.0.13:1518
2010-10-28 20:32:47,750 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.0.13:64015
2010-10-28 20:32:47,750 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s)
2010-10-28 20:32:48,140 DEBUG [EventSubscriptionExpirationChecker] Removed expired subscription 69b689a7-da5d-48bd-b2d7-845e841954ea from service urn:upnp-org:serviceId:ContentDirectory
2010-10-28 20:32:49,781 DEBUG [WebServer] Incoming connection from /192.168.0.13:57094
2010-10-28 20:32:49,781 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device dbda6698-2372-39e4-98c5-15b528e7d81f from WINDOWS, UPnP/1.0, Intel MicroStack/1.0.1497
2010-10-28 20:32:49,781 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Samsung TV / player (C-series)'
2010-10-28 20:32:49,781 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2010-10-28 20:32:49,796 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2010-10-28 20:32:49,796 DEBUG [ServiceEventSubscriptionRequestHandler] ServiceEvent subscription request received for service ContentDirectory
2010-10-28 20:32:49,796 DEBUG [ServiceEventSubscriptionRequestHandler] Event subscription registered (uuid=c71eadcc-46db-412a-ad6f-2fdf4446120a) for service urn:upnp-org:serviceId:ContentDirectory reporting to http://192.168.0.13:50385/serviceEventi ... tDirectory
2010-10-28 20:32:49,859 DEBUG [EventDispatcher] Sending event notification #0 for subscription c71eadcc-46db-412a-ad6f-2fdf4446120a to endpoint http://192.168.0.13:50385/serviceEventi ... tDirectory
2010-10-28 20:32:49,859 DEBUG [RequestExecutor] Sending HTTP request to 192.168.0.13:50385
2010-10-28 20:32:49,875 DEBUG [EventDispatcher] Event notification sent and received successfully
2010-10-28 20:32:49,875 DEBUG [EventDispatcher] Sending event notification #1 for subscription 69200895-3832-41f0-be82-1bcf64aeefa8 to endpoint http://192.168.0.13:64794/serviceEventi ... tDirectory
2010-10-28 20:32:49,875 DEBUG [RequestExecutor] Sending HTTP request to 192.168.0.13:64794
2010-10-28 20:32:50,140 DEBUG [EventSubscriptionExpirationChecker] Removed expired subscription 69b689a7-da5d-48bd-b2d7-845e841954ea from service urn:upnp-org:serviceId:ContentDirectory
2010-10-28 20:32:50,812 WARN [EventDispatcher] Couldn't send event message for subscription 69200895-3832-41f0-be82-1bcf64aeefa8, will keep trying until subscription expires
2010-10-28 20:32:50,812 DEBUG [EventDispatcher] Sending event notification #1 for subscription 69b689a7-da5d-48bd-b2d7-845e841954ea to endpoint http://192.168.0.13:64199/serviceEventi ... tDirectory
2010-10-28 20:32:50,812 DEBUG [RequestExecutor] Sending HTTP request to 192.168.0.13:64199
patillaldi
stop and start the server without results
Post Thu Oct 28, 2010 8:15 pm
there is something wrong with your network, as DeviceSpy cannot see your TV.
patillaldi
Post Fri Nov 05, 2010 8:40 pm
with a switch, the TV sees the server. It´s works.
¿Se puede con serviio rebobinar una pelicula?
patillaldi
Post Sat Nov 06, 2010 7:22 am
my last post was half of Spanish content, Sorry.
Can Serviio rewind a movie?
Post Sat Nov 06, 2010 12:23 pm
patillaldi wrote:Can Serviio rewind a movie?
Depends on the format (with a Samsung TV), but generally yes.
Previous
Return to User experiences
