Java runtime
AppleTree
Post Fri May 11, 2012 10:43 am
Java runtime
Just a remark for other user which have experienced the same problem
I have a Toshiba Regza TV. Serviio stopped working about the beginning of this year after a Java runtime update
Recently, after the Java runtime update 6.0.32 everything is working again.
So probably there has been some problem between Serviio an some Java runtime versions
Post Fri May 11, 2012 12:18 pm
Re: Java runtime
Or that java update installed incorrectly.
AppleTree
Post Fri May 11, 2012 12:32 pm
Re: Java runtime
Could indeed be that Java was not correct installed. However I doubt it.
I installed some previous versions several times and they did not work (6.0.31 did not work either)
It began working again with version 6.0.32
Post Fri May 11, 2012 4:45 pm
Re: Java runtime
I just saw today 6.0.31 didn't open the console... 7.0.4 worked.
Return to User experiences
