file won't play on Xbox 360
ttguy
Post Wed May 30, 2012 1:56 pm
So on Serviio Support & Help sub forum there is a "HOWTO: Provide details of a video file that doesn't play" So I guess I can ask people if they can help get a file to play.
/ffmpeg -i "/home/PUBLIC/TV/Red Riding.s01e01.In the Year of Our Lord 1974.avi"
Input #0, avi, from '/home/PUBLIC/TV/Red Riding.s01e01.In the Year of Our Lord 1974.avi':
encoder : Lavf52.64.2
Duration: 01:41:49.44, start: 0.000000, bitrate: 1140 kb/s
Stream #0.0: Video: mpeg4 (Simple Profile), yuv420p, 720x576 [PAR 64:45 DAR 16:9], 25 tbr, 25 tbn, 25 tbc
Stream #0.1: Audio: mp3, 44100 Hz, stereo, s16, 128 kb/s
my serviio instance is on linux and the render that the file will not play on is XBOX360.
It does play on my android tablet using UnPnP
An help for this issue?
linux/Humax HDR-3000T
Post Wed May 30, 2012 3:33 pm
Re: file won't play on Xbox 360
these files are sent natively to the xbox, so it's probably something in the way it's encoded the xbox doesn't like. MIght be anything, I'd recommend reencode.
ttguy
Post Sat Jun 02, 2012 1:25 pm
zip wrote:these files are sent natively to the xbox, so it's probably something in the way it's encoded the xbox doesn't like. MIght be anything, I'd recommend reencode.
Transcoded them to to .mkv and now they play. So thanks for the hint.
Post Sat Jun 02, 2012 5:11 pm
that's because Serviio transcodes MKV for the xbox, thus you're losing quality 2 times. You should just reencode it into divx and then it should play natively.
facethewolf
Post Sun Aug 05, 2012 8:08 pm
It's the MP3 audio stream. Xbox doesn't like it for some reason in the MP4 container.
When I convert videos to MP4 I always retain the original AC3 stream, called "AC3 passthrough" on handbrake.
Also Xbox won't reject a file with multiple audio streams, but it will only play the last one, the one at the bottom of the list.
Return to User experiences
