Serviio no working on Mountain Lion (OS X 10.8)
repeters
Post Mon Jul 30, 2012 11:19 pm
Re: Serviio no working on Mountain Lion (OS X 10.8)
zip wrote:So I tried it on a clean 10.8 install (vmware)... Opened Serviio, it told me java is not installed and it installed it automatically, then I just ran the apps as always. I didn't have change the setting to run apps downloaded from anywhere. Not sure if it's because I'm an administrator?
I am an also administrator on my MacBook Pro. However, if I delete the serviio applications and install them again I must temporarily set the Gatekeeper setting to "always".
repeters
Post Wed Aug 15, 2012 10:52 pm
Do you still plan to update serviio applications so that they "play nice" with Mountain Lion Gatekeeper?
Post Wed Aug 15, 2012 10:57 pm
Probably at some point yes, it's not a massive priority at the moment if there is a workaround.
emre
Post Thu Aug 23, 2012 11:15 pm
After I upgraded to Mountain Lion, serviio starts fine and my 2012 Bravia connects to it and I can browse my library. But when I want to play a video file I get "cannot access server". Any idea what might be causing this? It used to work fine with Snow Leopard before and I haven't touched my network or router settings since then. I have enabled "run programs from anywhere" but as I said it serviio process has already been running.
emre
Post Fri Aug 24, 2012 1:30 am
Ok, so the problem was that Serviio was not able to create the temp folder for transcoding after I upgraded to 10.8 from 10.6 snow leopard.
2012-08-23 18:13:16,799 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: Cannot create transcoding folder: /var/folders/Yu/YuVsZlrCGa0MHXekvxtrv++++TI/-Tmp-/Serviio
java.io.IOException: Cannot create transcoding folder: /var/folders/Yu/YuVsZlrCGa0MHXekvxtrv++++TI/-Tmp-/Serviio
Fixed this by creating a tmp folder and updating the transcoding folder location. I'm wondering if other people who did the OS X upgrade had the same issue. Anyway, thanks for a great product, I use it everyday to stream stuff to my tv.
Previous
Return to User experiences
