LibraryUpdater error
fizze
Post Wed Dec 30, 2009 7:56 pm
I see tons of these in my log file:
20:55:30,648 WARN  [LibraryUpdaterThread] Cannot search for updated metadata for title {title}. Message: null
       at org.serviio.library.metadata.extractor.embedded.EmbeddedMetadataExtractor.isMetadataUpdated(EmbeddedMetadataExtractor.java:83)
       at org.serviio.library.metadata.LibraryUpdaterThread.searchForUpdatedMetadata(LibraryUpdaterThread.java:329)
       at org.serviio.library.metadata.LibraryUpdaterThread.run(LibraryUpdaterThread.java:141)
20:55:31,505 WARN  [EventDispatcher] Couldn't send event message for subscription ba5cc426-7d33-49a0-b171-14b11d728146, will try until subscription expires
and these:
20:42:51,065 ERROR [ContainerNode] Cannot retrieve results of action command: Cannot execute library command f                or list: null
org.serviio.upnp.service.contentdirectory.command.CommandExecutionException: Cannot execute library command fo                r list: null
       at org.serviio.upnp.service.contentdirectory.command.AbstractCommand.retrieveItemList(AbstractCommand.j                ava:117)
       at org.serviio.upnp.service.contentdirectory.definition.ContainerNode.executeListAction(ContainerNode.j                ava:195)
       at org.serviio.upnp.service.contentdirectory.definition.ActionNode.retrieveContainerItems(ActionNode.ja                va:123)
       at org.serviio.upnp.service.contentdirectory.ContentDirectory.Browse(ContentDirectory.java:154)
       at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
       at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
       at java.lang.reflect.Method.invoke(Method.java:597)
       at org.serviio.upnp.protocol.soap.ServiceInvoker.invokeOperation(ServiceInvoker.java:253)
       at org.serviio.upnp.protocol.soap.ServiceInvoker.invokeService(ServiceInvoker.java:93)
       at org.serviio.upnp.webserver.ServiceControlRequestHandler.handleRequest(ServiceControlRequestHandler.j                ava:73)
       at org.serviio.upnp.webserver.AbstractRequestHandler.handle(AbstractRequestHandler.java:46)
       at org.serviio.upnp.webserver.WebServer$WorkerThread.run(WebServer.java:163)
Caused by: java.lang.NullPointerException
       at org.serviio.library.dao.FolderDAOImpl.getNumberOfSubFolders(FolderDAOImpl.java:253)
       at org.serviio.library.dao.FolderDAOImpl.getNumberOfFoldersAndMediaItems(FolderDAOImpl.java:288)
       at org.serviio.library.service.FolderService.getNumberOfFoldersAndMediaItems(FolderService.java:93)
       at org.serviio.upnp.service.contentdirectory.command.AbstractListObjectsByFSHierarchyCommand.retrieveIt                emCount(AbstractListObjectsByFSHierarchyCommand.java:187)
       at org.serviio.upnp.service.contentdirectory.definition.ContainerNode.executeCountAction(ContainerNode.                java:175)
       at org.serviio.upnp.service.contentdirectory.definition.ActionNode.retrieveContainerItemsCount(ActionNo                de.java:147)
       at org.serviio.upnp.service.contentdirectory.command.ObjectValuesBuilder.instantiateValuesForContainer(                ObjectValuesBuilder.java:118)
       at org.serviio.upnp.service.contentdirectory.command.ObjectValuesBuilder.buildObjectValues(ObjectValues                Builder.java:49)
       at org.serviio.upnp.service.contentdirectory.command.AbstractListObjectsByFSHierarchyCommand.retrieveLi                st(AbstractListObjectsByFSHierarchyCommand.java:113)
       at org.serviio.upnp.service.contentdirectory.command.AbstractCommand.retrieveItemList(AbstractCommand.j                ava:111)
       ... 14 more
Sorry about the formatting, but you get the idea, right...? ;)
What do these mean?
I didn't even have any DLNA clients turned on when this error happened..... weird..
edit:
So i was renaming some files, figuring special characters and whatnot might cause problems. Well in the log, they actually do.
So here I am, renaming files when this clusterfsck pops up:
21:26:39,062 INFO  [LibraryUpdaterThread] Removing 'Star Wars Attack of the Clones' from Library
21:27:02,574 ERROR [ContainerNode] Cannot retrieve results of action command: Cannot execute library command for list: Cannot read list of persons with role DIRECTOR for media item 2979
org.serviio.upnp.service.contentdirectory.command.CommandExecutionException: Cannot execute library command for list: Cannot read list of persons with role DIRECTOR for media item 2979
       at org.serviio.upnp.service.contentdirectory.command.AbstractCommand.retrieveItemList(AbstractCommand.java:117)
       at org.serviio.upnp.service.contentdirectory.definition.ContainerNode.executeListAction(ContainerNode.java:195)
       at org.serviio.upnp.service.contentdirectory.definition.ActionNode.retrieveContainerItems(ActionNode.java:123)
       at sun.reflect.GeneratedMethodAccessor254.invoke(Unknown Source)
       at org.serviio.upnp.webserver.ServiceControlRequestHandler.handleRequest(ServiceControlRequestHandler.java:73)
Caused by: org.serviio.db.dao.PersistenceException: Cannot read list of persons with role DIRECTOR for media item 2979
       at org.serviio.library.dao.PersonDAOImpl.retrievePersonsWithRoleForMediaItem(PersonDAOImpl.java:325)
       at org.serviio.library.service.PersonService.getListOfPersonsForMediaItem(PersonService.java:53)
       at org.serviio.upnp.service.contentdirectory.command.ObjectValuesBuilder.buildObjectValues(ObjectValuesBuilder.java:83)
       at org.serviio.upnp.service.contentdirectory.command.AbstractListObjectsByFSHierarchyCommand.retrieveList(AbstractListObjectsByFSHierarchyCommand.java:126)
       at org.serviio.upnp.service.contentdirectory.command.AbstractCommand.retrieveItemList(AbstractCommand.java:111)
       ... 13 more
Caused by: java.sql.SQLTransactionRollbackException: A lock could not be obtained due to a deadlock, cycle of locks and waiters is:
Lock : TABLE, MEDIA_ITEM, Tablelock
  Waiting XID : {282780140, IS} , APP, SELECT DISTINCT(p.id) as id, p.name as name, p.sort_name as sort_name FROM person p, person_role r, media_item m WHERE r.person_id = p.id AND r.ROLE_TYPE = ? AND r.media_item_id = ?
  Granted XID : {282780130, X}
Lock : TABLE, PERSON_ROLE, Tablelock
  Waiting XID : {282780130, X} , APP, DELETE FROM cover_image WHERE id = ?
  Granted XID : {282780131, IS} , {282780134, IS} , {282780135, IS} , {282780136, IS} , {282780140, IS}
. The selected victim is XID : 282780140.
       at org.apache.derby.impl.jdbc.EmbedStatement.executeStatement(Unknown Source)
       at org.apache.derby.impl.jdbc.EmbedPreparedStatement.executeStatement(Unknown Source)
       at org.apache.derby.impl.jdbc.EmbedPreparedStatement.executeQuery(Unknown Source)
       at org.serviio.library.dao.PersonDAOImpl.retrievePersonsWithRoleForMediaItem(PersonDAOImpl.java:322)
       ... 17 more
Caused by: java.sql.SQLException: A lock could not be obtained due to a deadlock, cycle of locks and waiters is:
       ... 27 more
Caused by: ERROR 40001: A lock could not be obtained due to a deadlock, cycle of locks and waiters is:
       at org.apache.derby.impl.services.locks.Deadlock.buildException(Unknown Source)
       at org.apache.derby.impl.services.locks.ConcurrentLockSet.lockObject(Unknown Source)
       at org.apache.derby.impl.services.locks.AbstractPool.lockObject(Unknown Source)
       at org.apache.derby.impl.services.locks.ConcurrentPool.lockObject(Unknown Source)
       at org.apache.derby.impl.store.raw.xact.RowLocking2.lockContainer(Unknown Source)
       at org.apache.derby.impl.store.raw.data.BaseContainerHandle.useContainer(Unknown Source)
       at org.apache.derby.impl.store.raw.data.BaseDataFileFactory.openContainer(Unknown Source)
       at org.apache.derby.impl.store.raw.xact.Xact.openContainer(Unknown Source)
       at org.apache.derby.impl.store.access.conglomerate.OpenConglomerate.init(Unknown Source)
       at org.apache.derby.impl.store.access.heap.Heap.open(Unknown Source)
       at org.apache.derby.impl.store.access.RAMTransaction.openConglomerate(Unknown Source)
       at org.apache.derby.impl.store.access.RAMTransaction.openCompiledConglomerate(Unknown Source)
       at org.apache.derby.impl.store.access.btree.index.B2IForwardScan.init(Unknown Source)
       at org.apache.derby.impl.store.access.btree.index.B2I.openScan(Unknown Source)
       at org.apache.derby.impl.store.access.RAMTransaction.openScan(Unknown Source)
       at org.apache.derby.impl.store.access.RAMTransaction.openCompiledScan(Unknown Source)
       at org.apache.derby.impl.sql.execute.BulkTableScanResultSet.openScanController(Unknown Source)
       at org.apache.derby.impl.sql.execute.TableScanResultSet.openCore(Unknown Source)
       at org.apache.derby.impl.sql.execute.BulkTableScanResultSet.openCore(Unknown Source)
       at org.apache.derby.impl.sql.execute.JoinResultSet.openRight(Unknown Source)
       at org.apache.derby.impl.sql.execute.JoinResultSet.openCore(Unknown Source)
       at org.apache.derby.impl.sql.execute.ProjectRestrictResultSet.openCore(Unknown Source)
       at org.apache.derby.impl.sql.execute.SortResultSet.openCore(Unknown Source)
       at org.apache.derby.impl.sql.execute.BasicNoPutResultSetImpl.open(Unknown Source)
       at org.apache.derby.impl.sql.GenericPreparedStatement.executeStmt(Unknown Source)
       at org.apache.derby.impl.sql.GenericPreparedStatement.execute(Unknown Source)
       ... 21 more
21:27:02,580 WARN  [ContentDirectory] Browse for object id V_F#FOL_R2 failed with exception: null
       at org.serviio.upnp.service.contentdirectory.ContentDirectory.Browse(ContentDirectory.java:168)
21:27:02,596 ERROR [ContainerNode] Cannot retrieve results of action command: Cannot execute library command for list: Cannot read list of persons with role PRODUCER for media item 2967
org.serviio.upnp.service.contentdirectory.command.CommandExecutionException: Cannot execute library command for list: Cannot read list of persons with role PRODUCER for media item 2967
Caused by: org.serviio.db.dao.PersistenceException: Cannot read list of persons with role PRODUCER for media item 2967
       at org.serviio.upnp.service.contentdirectory.command.ObjectValuesBuilder.buildObjectValues(ObjectValuesBuilder.java:84)
       ... 13 more
  Waiting XID : {282780136, IS} , APP, SELECT DISTINCT(p.id) as id, p.name as name, p.sort_name as sort_name FROM person p, person_role r, media_item m WHERE r.person_id = p.id AND r.ROLE_TYPE = ? AND r.media_item_id = ?
. The selected victim is XID : 282780136.
       ... 17 more
       ... 27 more
       ... 21 more
21:27:02,597 WARN  [ContentDirectory] Browse for object id V_F#FOL_R2 failed with exception: null
21:27:02,830 ERROR [ContainerNode] Cannot retrieve results of action command: Cannot execute library command for list: Cannot read list of persons with role PRODUCER for media item 2969
org.serviio.upnp.service.contentdirectory.command.CommandExecutionException: Cannot execute library command for list: Cannot read list of persons with role PRODUCER for media item 2969
Caused by: org.serviio.db.dao.PersistenceException: Cannot read list of persons with role PRODUCER for media item 2969
       ... 13 more
  Waiting XID : {282780134, IS} , APP, SELECT DISTINCT(p.id) as id, p.name as name, p.sort_name as sort_name FROM person p, person_role r, media_item m WHERE r.person_id = p.id AND r.ROLE_TYPE = ? AND r.media_item_id = ?
. The selected victim is XID : 282780134.
       ... 17 more
       ... 27 more
       ... 21 more
21:27:02,831 WARN  [ContentDirectory] Browse for object id V_F#FOL_R2 failed with exception: null
21:27:02,843 ERROR [ContainerNode] Cannot retrieve results of action command: Cannot execute library command for list: Cannot read list of persons with role PRODUCER for media item 3212
org.serviio.upnp.service.contentdirectory.command.CommandExecutionException: Cannot execute library command for list: Cannot read list of persons with role PRODUCER for media item 3212
Caused by: org.serviio.db.dao.PersistenceException: Cannot read list of persons with role PRODUCER for media item 3212
       ... 13 more
  Waiting XID : {282780135, IS} , APP, SELECT DISTINCT(p.id) as id, p.name as name, p.sort_name as sort_name FROM person p, person_role r, media_item m WHERE r.person_id = p.id AND r.ROLE_TYPE = ? AND r.media_item_id = ?
. The selected victim is XID : 282780135.
       ... 17 more
       ... 27 more
       ... 21 more
Database locks and unhandled exceptions are a bad thing ;) :twisted:
Intel SS4200 - Ubuntu Server 8.04
LG BD - 390
Post Wed Dec 30, 2009 11:22 pm
Re: LibraryUpdater error
Some of these should be fixed in 0.3.1 already, will look into the other ones.
Post Thu Dec 31, 2009 12:57 pm
Itseems tome that your DB is corrupt, most of these exceptions should not normally occur, that's why I don't deal with them. Try to delete folder library/db (stop Serviio first) and it should get back to normal. Mind you, you will lose your settings and metadata.
Not sure why this happened... did you do something with the DB using external tools?
fizze
Post Thu Dec 31, 2009 3:00 pm
Other than insert my library locations using ij, no.
Alright, I'll try to rebuild it from scratch.
On a sidenote: media without metadata DOES appear in serviio, right?
LG BD - 390
Post Thu Dec 31, 2009 3:41 pm
fizze wrote:On a sidenote: media without metadata DOES appear in serviio, right?
Without metadata from the online sources - yes. Using priority extraction it'll only get as much as possible from the other extractors, ie local dvd cover and embedded information (e.g. file name, file length, FFmpeg generated thumbnail, etc)
Return to User experiences
