192Khz Audio File Does Not play
Laz Baz
Post Sat Jan 12, 2013 3:37 am
I am very happy with Servio for streaming HD Video.
However I am also a music lover and do stream a lot 44.1Khz, 82.2, 96 and 192 Khz audio files. Servio does not play the 192 high res.
Is there a way to play it without downmixing?
Samsung UE55JU7000; Panasonic BDT 110; Cambridge Audio 640; IMF TLS80 Mk II front & Yamaha centre & surround speakers
slyguy42o
Post Tue Jan 15, 2013 4:12 pm
Re: 192Khz Audio File Does Not play
I think it depends on what the device you are playing the file on supports.
Does it work if you stream it via VLC?
Laz Baz
Post Tue Jan 15, 2013 6:06 pm
The device is Onkyo TX-Nr609 and it plays 192Khz audio very well when I use another (may be your competitor & I am not sure if I should mention the name) streaming server. As I said I am very happy with Serviio and would like to use it for both my Video and Audio streaming. If you could point me in the right direction, I may be able to play the 192Khz, since it is playable on my setup with the other software.
Regards
Post Tue Jan 15, 2013 6:12 pm
can you post detailed log of playing the file?
Return to User experiences
