Blue Screen of Death
richardar
Post Fri Mar 29, 2013 1:36 pm
For a long time time I've had the occasional BSOD which BlueScreenView has always logged as being caused by the NT Kernel & System. Using Windbg I have finally traced it to the PROCESS NAME 0xF4_ServiioService. I have a copy of the dump file log but that's the limit of my technical ability. I wonder if anyone else has had this problem and if there is a solution. My OS is Win7 and I have Serviio Ver 1.2.1. Serviio has always worked perfectly with my Sony TV.
slyguy42o
Post Fri Mar 29, 2013 2:25 pm
Re: Blue Screen of Death
sounds like you might have a hardware issue.. you might want to check your windows event logs for critical events like a disk timeout or something similar.
Return to User experiences
