Slow to respond since 1.5?
spudy12
Post Fri Feb 13, 2015 10:39 am
Has anyone else had issues with serviio being slow to respond since the 1.5 upgrade?
I mainly use the MB and serviigo but sometimes the MB loads fine (or serviigo connects fine) but then it takes a while and a few refreshes for any shows to show up?
I can browse the structure of Series, Season etc but when I get there, there are no files to play. It usually takes aroun 30 - 60 seconds for them to show up.
I have a rather large library and the media is stored on a backend NAS. Would this have anything to do with it?
My thinking was that it could be waiting for the NAS to wake up? Anyway I can test this..
Didnt used to have this issue prior to 1.5
Did a fresh install, running on an Ubuntu Server. All wired gigabit ethernet.
Post Fri Feb 13, 2015 1:34 pm
Re: Slow to respond since 1.5?
Browsing runs from the database, so it doesn't matter where the files are stored.
You could check the detailed log and see if there is a delay between the request coming and response coming back.
Actually, do this in the beta forum, we have 1.5.1 in testing now.
spudy12
Post Sun Feb 15, 2015 10:01 am
Okay will do
Return to User experiences
Users browsing this forum: Google [Bot] and 17 guests
