Serviio 1.5.1 on Os X 10.8.5
pteeson
Post Thu Feb 26, 2015 10:28 pm
Two things that are related to 1.5.1
A
I'm presently on 1.4 .1.2 so I downloaded 1.5.1 and unzipped it.
It mounted as what at first sight appers to be dmg.
However the following 3 snapshots show there is something not correct with it, at least on my system.
I was able to use Pacifist to extract the server and the console but I have not installed them yet.
B
I run serviio from a folder on my desktop and not from the Application folder.
This has worked well for me from day 1. I don't like things being installed and automatically launched.
As a developer on Mac since 1984 I am able to manage the computer.
Perhaps there is an option using the Installer to omit the automatic install?
respect..
Peter
serviio-c -1.5.1.tiff
serviio-c -1.5.1.tiff (32.2 KiB) Viewed 7757 times
serviio-b -1.5.1.tiff
serviio-b -1.5.1.tiff (25.71 KiB) Viewed 7757 times
serviio-a -1.5.1.tiff
serviio-a -1.5.1.tiff (76.38 KiB) Viewed 7757 times
Mac Pro OS X Yosemite, Toshiba 55SL500U
Post Fri Feb 27, 2015 9:58 pm
Re: Serviio 1.5.1 on Os X 10.8.5
It starts as a launch daemon now. Read the FAQ to see how to disable the autostart.
pteeson
Post Sat Feb 28, 2015 3:24 am
Thanks for your reply to item B. Of course I did read the FAQ before even downloading.
I guesss I can edit org.seriio.server.plist and set RunAtLoad to false and change UserName to something less powerfull!
You didn't comment on the out of the box items on which I sent you snapshots.
Is this just something to do with my system or have other Mac users had similar issues?
respect
Post Mon Mar 02, 2015 7:39 pm
I cant see the snapshots.
Return to User experiences
Users browsing this forum: Google [Bot] and 20 guests
