Library Tab not displaying correctly
aldero99
Post Sun Dec 07, 2014 8:29 pm
When I open the Serviio console it does not display the Library Tab correctly, I added a screenshot so you can see what goes wrong ....
The fields that are on the form only display when I hover over them with the mouse, otherwise they would be invisible as well.
Hope to hear from you how to fix this ....
Alexander de Rooij
Post Mon Dec 08, 2014 12:34 am
Re: Library Tab not displaying correctly
My guess is a Java version issue. Can you tell us what version of Java you have, and if it's 32 or 64 bit? Looks like Windows 8/8.1. Is that right? Which version of Windows?
Denison
Post Thu Mar 26, 2015 4:11 pm
Hi got here because I have the exact same problem which started only today.
Yestreday and earlier it was fine.
I am running win 7 on a 64 bit processor
It could be java because Java update ran overnight.
The current version I have is Version 8 update 40 (build 1.8.0_40-b26)
Will this effect the DNLA function?
Should I roll back the java update?
Post Thu Mar 26, 2015 9:06 pm
If you are on 1.5.x, any system Java update won't affect you.
Return to User experiences
