errror in downloadind serviio update
Georges
Post Sat May 16, 2015 11:20 am
error in opening. I am user since 2 years without problem. After having loaded Java 8 I could not open Serviio anymore with the following message "No JVM could be found. Please define Exe 4J_Java_home to point to an installed 64 bit JDK or JRE" After having search solutions without success I decide to reinstal the version 7 of java. Immediately I open Serviio. Howeve I had a message saying that an update was available. So I download the version 1.5.2 instead of the 1.4. During the loading an error message . Now when i try to open " Java lang unsupported Class Version Error : org/serviio/console : unsupported major.minor version 52.0
Is somebody able to help me ?
I am using Windows 8.1 64 bits - Internet Explorer
Many thanks in advance. I apologize for my poor English. Regards
Post Sat May 16, 2015 7:15 pm
Re: errror in downloadind serviio update
remove java from your system, if you don't need it. Serviio 1.5.x comes with java bundled.
Return to User experiences
