A question for Zip (Online Sources)
tstrike
Post Thu Sep 24, 2015 4:25 am
Zip (aka Mr. Chelsea Blue hehehe)
Is there a way to build a list of URLs and have Serviio read in the files into the Online Sources... Doing this one at a time is cumbersome and when I want to refresh the list, it is a tedious task...
Is this a derby function? If so, could you instruct me in the syntax of such an endeavor?
Post Thu Sep 24, 2015 1:14 pm
Re: A question for Zip (Online Sources)
There is the Import / Export function in the console. It's just a file with ServiioLink entries.
Post Thu Sep 24, 2015 2:15 pm
I built this long ago, but the samples are all out of date.
Problem is that the feeds expire whereas web-resources for each site find the latest feeds, but it does allow the feeds to be maintained in a single file that can be refreshed in serviio.
http://wiki.serviio.org/doku.php?id=live_stream_folders
viewtopic.php?f=20&t=6645&p=104171#p48054
tstrike
Post Thu Sep 24, 2015 4:08 pm
jhb50 wrote:I built this long ago, but the samples are all out of date.
This is good... I will start with this... I need to sit down for a weekend and learn groovys and some of this stuff.... I have such a hectic schedule, but this is on my Programming bucket list.... I feel like I havent contributed a damn thing to this very very awesome solution. *guilt*
Thanks guys, I will circle back.
tstrike
Post Thu Sep 24, 2015 4:45 pm
Hey guys...
I really like the ServiioLinks (I never really paid attention to them before).. I noticed a series of variables set to escape certain characters that are translated in the URL... Example
<serviioLink>serviio://video:live?url=http%3A%2F%2Fvurl.com%2FOYLlG&amp;name=NASA</serviioLink>
Note the variables for %3A (for :), %2F (for /). I was wondering if there is a guide for scripting ServiioLinks... I searched the forums, but didnt find a reference guide or anything.... I got the overall structure, just want to make sure I am coding the sob's correctly before import.
OR
Can I place the URL into the sob and when imported, Serviio automajically translate?
tstrike
Hey guys...
Note the variables for %3A (for : ), %2F (for /). I was wondering if there is a guide for scripting ServiioLinks... I searched the forums, but didnt find a reference guide or anything.... I got the overall structure, just want to make sure I am coding the sob's correctly before import.
OR
Post Thu Sep 24, 2015 6:59 pm
You can use this to encode the URL: http://www.url-encode-decode.com/
tstrike
Post Thu Sep 24, 2015 7:36 pm
zip wrote:You can use this to encode the URL: http://www.url-encode-decode.com/
THank You THANK YOU!!!
I was loosing my mind for a minute or two.
tstrike
Post Thu Sep 24, 2015 7:38 pm
Zip... one more question.... if you update your existing sob file, it overwrites the current one you have running correct? Afterwards, the search index poller picks up the change and rescans correct?
Post Fri Sep 25, 2015 3:59 am
Here is the encoder/decoder I use.
http://meyerweb.com/eric/tools/dencoder/
Post Fri Sep 25, 2015 9:22 pm
The sob file is just a backup / or a way to share with others. If you make a change, you have to import it back.
Return to User experiences
