File naming on Win10 (since no WMC)
Tim9898
Post Mon Mar 07, 2016 4:57 am
Since migrating to Win10 I am no longer able to name TV Shows like,
Grey's Anatomy-S10E19-I'm Winning.mp4.
Instead they now look like,
Blue Bloods - S2016E14 - The Road to Hell.mp4
Yes I know that Serviio doesn't rename files, however it does not organize a year-based filename into season-based folders. So only navigation by folder now works.
I just want things to work like they did before Win10, and I can no longer get filenames to be season-based.
My setup: HDHomeRun tuner card;
MCEBuddy;
either jRiver MediaCenter -OR- NextPVR;
Servio
I thought I would start with the Serviio forum, then try others.
Ideas appreciated.
Post Mon Mar 07, 2016 7:14 am
Re: File naming on Win10 (since no WMC)
I'm confused - why are you no longer able to name your files??
What is doing the file naming? If it is MCEBuddy then believe you you can set it to name the file according to your previous scheme (ie SxxEyy): https://mcebuddy2x.codeplex.com/wikipag ... 20Commands
Post Mon Mar 07, 2016 1:28 pm
Use Fliebot for file naming, and you won't have any issues. I also am curious about how you are currently naming files.
Tim9898
Post Mon Mar 07, 2016 7:55 pm
MCEBuddy is not renaming the file with series/episode as desired because that information is not in the .xml file that JRiver creates. (I presume that season/episode used to be in the .wtv file that WMC used to create.)
-- I do appreciate help from this forum. To continue using Serviio's "organize shows by season", I think I need to get season/episode into the file name in the form, "SxxExx".
I don't know how to get "SxxExx" with NextPVR or with JRiver, but with JRiver I see an xml file being generated that MCEBuddy should use, but the xml file defines the season represented as the episode's release year instead -please see attachment:
The recorded ts file name is: The Good Wife - S2016E16 - The Good Wife.ts
The "sidecar" .xml file name is: The Good Wife - S2016E16 - The Good Wife_ts_JRSidecar.xml
These two file name obviously differ. Is that a problem for MCEBuddy, since its documentation says,
"Using Custom Filenames and Custom Metadata (v2.3.12+)
If you're using a WTV or DVRMS file, then MCEBuddy will extract the metadata from them directly.
Otherwise, MCEBuddy looks for a XML metadata file along with the original source video (with the same source video filename). It uses this file to extract Metadata information for non WTV/DVRMS files."
The (to large to attach) MCBuddy log file can be found here:
https://s3-us-west-2.amazonaws.com/tim- ... -08-00.log
The log shows
Genres: Season: 0
Episode: 0
for this conversion, so clearly it fails to get this information, which later causes it not to include "SxxExx" in the converted file name.
Thanks again for any ideas.
(1.99 KiB) Downloaded 1058 times
Tim9898
Post Wed Mar 09, 2016 9:33 pm
Thanks for the FileBot suggestion. It works well. I also set MCEbuddy to not rename my files, since FileBot did a better job.
Attached is a .jpg of the MCEBuddy setting.
Later I may automate FileBot to monitor my recording folder and automatically rename/move files. For me, writing a PowerShell script to monitor a folder and launch FileBot via its CLI interface should be easiest. (I do see the FileBot CLI documentation, but I still expect some effort to get it working.)
Thanks again to all responders.
Post Wed Mar 09, 2016 9:47 pm
While I do run Windows Media Center on one computer (solely for recording off the air movies), I've never looked at MCEBuddy. Maybe I should :D
Rosales_Network
Post Mon Mar 14, 2016 4:18 am
I use mp3tag
I also use powershell to rename some files in bulk. Mp3tag will automate files in bulk too
message me if you want a remote session. Paypal Friendly
Return to User experiences
