MediaBrowser can not drag video online
229212543
Post Mon Feb 13, 2017 6:51 am
I am a user from China, recently in the use of iphone (ios9.3.5) landing MediaBrowser online play shared video, the player always broadcast the way to play the film, there is no way to drag the playback progress, there is no good solution Way? thank! (Thanks google translation to give me a very strong English level! :D )
Post Mon Feb 13, 2017 8:52 am
Re: MediaBrowser can not drag video online
That id due to the file being transcoded, the iPhone thinks it's a live stream.
You'd have to use Original quality in the console and then also have the file in mp4/h264/aac so that they are not transcoded.
229212543
Post Tue Feb 14, 2017 5:57 am
zip wrote:That id due to the file being transcoded, the iPhone thinks it's a live stream.
Because some video I need to go out through the mobile phone 3G to play, I do not mind to reduce the quality of some pictures, hoping to transcode to reduce my bandwidth requirements, speed up the loading speed, make playback more smooth.
I would like to ask in addition to the way I mentioned earlier, because if the LAN environment that is ok, but for the 3g environment, the bandwidth of the video is still some lack, I also think of other methods, such as my original video re-encoding Compressed volume, but my pc has about 2t video, the number is still increasing, and the size, format, different resolution, conversion is very time-consuming and laborious, is there a better solution?
Mobile side of the ios devices and Android devices have tried to broadcast in the form of broadcast in the pc side of the flash page player can play the normal, but helpless ios and Android do not support flash.
Return to User experiences
