File parsing error
Rosa Negra
Post Wed Jul 10, 2019 7:32 pm
File parsing error
Hi
I have been trying to add the following file to the db:
The 100 - S01E01 # Pilot.mp4
The entry in the db comes back as:
100% -> Season 1 -> 01. Planes
How can I get it to enter correctly?
N.B. The rest of the series enters correctly.
Regards
Tracy
Running Serviio on Windows Server 2012 64 bit and a Toshiba Regza TV
Post Thu Jul 11, 2019 1:21 am
Re: File parsing error
I'm assuming you have a folder for this series, most likely just called "The 100". You could try adding the IMDB number to the file name, i.e. "The 100 tt2661044". I don't think you'd have to add it to each file name. I believe the folder name is sufficient. But if the folder name doesn't do it, then you will have to add it the file name. You also might try removing the # from the file name. That isn't a recommended naming convention. https://www.serviio.org/index.php?optio ... icle&id=12
Rosa Negra
Post Thu Jul 11, 2019 7:33 am
Thanks Dan - that's got it.
Regards
Tracy
Return to User experiences
