samsung le32c650 not find serviio
patillaldi
Post Wed Oct 27, 2010 10:06 pm
Samsung tv is not finding Serviio. Is connected by cable TV network through PLC. PC is connected directly to the router by cable. I have opened ports 1 through 65535 for the computer's IP (192.168.0.14) and the tv (192.168.0.20).
The computer's firewall is disabled. Tv intertet accessed through Internet @ Tv (yahoo widgets) but can not find the server Serviio.
Log
2010-10-27 23:50:29,156 INFO [WebServer] WebServer shutting down
2010-10-27 23:50:29,156 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2010-10-27 23:50:29,156 INFO [EventDispatcher] Leaving EventDispatcher
2010-10-27 23:50:29,156 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2010-10-27 23:50:32,015 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2010-10-27 23:50:32,015 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface 192.168.0.14
2010-10-27 23:50:32,015 INFO [WebServer] WebServer starting on port 8895
2010-10-27 23:50:32,015 INFO [EventDispatcher] Starting EventDispatcher
2010-10-27 23:50:32,015 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2010-10-27 23:51:41,984 WARN [EventDispatcher] Couldn't send event message for subscription f796aea0-fa71-4c36-8c0b-252bffffdd5c, will keep trying until subscription expires
2010-10-27 23:54:43,546 WARN [EventDispatcher] Couldn't send event message for subscription b1e2f949-deae-454f-83d5-de53da3ccdda, will keep trying until subscription expires
2010-10-27 23:54:44,546 WARN [EventDispatcher] Couldn't send event message for subscription f796aea0-fa71-4c36-8c0b-252bffffdd5c, will keep trying until subscription expires
2010-10-27 23:57:44,796 WARN [EventDispatcher] Couldn't send event message for subscription c112cad8-a768-4a02-9173-0ef50a82e178, will keep trying until subscription expires
2010-10-27 23:57:45,796 WARN [EventDispatcher] Couldn't send event message for subscription b1e2f949-deae-454f-83d5-de53da3ccdda, will keep trying until subscription expires
2010-10-27 23:57:46,812 WARN [EventDispatcher] Couldn't send event message for subscription f796aea0-fa71-4c36-8c0b-252bffffdd5c, will keep trying until subscription expires
2010-10-28 00:00:44,953 WARN [EventDispatcher] Couldn't send event message for subscription 03e8e35c-c7ff-4c28-b459-4b17abeb1105, will keep trying until subscription expires
2010-10-28 00:00:45,953 WARN [EventDispatcher] Couldn't send event message for subscription c112cad8-a768-4a02-9173-0ef50a82e178, will keep trying until subscription expires
2010-10-28 00:00:46,953 WARN [EventDispatcher] Couldn't send event message for subscription b1e2f949-deae-454f-83d5-de53da3ccdda, will keep trying until subscription expires
2010-10-28 00:00:47,968 WARN [EventDispatcher] Couldn't send event message for subscription f796aea0-fa71-4c36-8c0b-252bffffdd5c, will keep trying until subscription expires
2010-10-28 00:03:46,609 WARN [EventDispatcher] Couldn't send event message for subscription e7f6b736-47ed-4117-8f92-b1c57e0a65f0, will keep trying until subscription expires
2010-10-28 00:03:47,609 WARN [EventDispatcher] Couldn't send event message for subscription 03e8e35c-c7ff-4c28-b459-4b17abeb1105, will keep trying until subscription expires
2010-10-28 00:03:48,609 WARN [EventDispatcher] Couldn't send event message for subscription c112cad8-a768-4a02-9173-0ef50a82e178, will keep trying until subscription expires
2010-10-28 00:03:49,625 WARN [EventDispatcher] Couldn't send event message for subscription b1e2f949-deae-454f-83d5-de53da3ccdda, will keep trying until subscription expires
2010-10-28 00:03:50,531 WARN [EventDispatcher] Couldn't send event message for subscription f796aea0-fa71-4c36-8c0b-252bffffdd5c, will keep trying until subscription expires
Post Wed Oct 27, 2010 10:10 pm
Re: samsung le32c650 not find serviio
turn on detailed logging and restart serviio, then post the result here
patillaldi
Post Wed Oct 27, 2010 10:13 pm
How can i turn on detailed logging?
patillaldi
Post Wed Oct 27, 2010 10:25 pm
Log with debug options
2010-10-28 00:19:38,421 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44331
2010-10-28 00:19:38,515 INFO [MediaServer] ------------------------------------------------------------------------
2010-10-28 00:19:38,515 INFO [MediaServer] Serviio DLNA media streaming server v 0.4.2 (rev. 683706a96104)
2010-10-28 00:19:38,515 INFO [MediaServer] Petr Nejedly 2009-2010
2010-10-28 00:19:38,515 INFO [MediaServer] http://www.serviio.org
2010-10-28 00:19:38,562 INFO [MediaServer] Java 1.6.0_20-Sun Microsystems Inc.
2010-10-28 00:19:38,578 INFO [MediaServer] OS Windows XP x86 5.1
2010-10-28 00:19:38,578 INFO [MediaServer] File encoding: windows-1252
2010-10-28 00:19:38,578 INFO [MediaServer] ------------------------------------------------------------------------
2010-10-28 00:19:40,828 DEBUG [ServiioConsole] Initializing Serviio Console
2010-10-28 00:19:41,046 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44332
2010-10-28 00:19:41,062 INFO [ServiioConsole] Starting Serviio Console
2010-10-28 00:19:44,515 DEBUG [SwingHelper] Choosing java look and feel: com.sun.java.swing.plaf.windows.WindowsLookAndFeel
2010-10-28 00:19:51,875 INFO [RestletServer] Starting Restlet server exposed on localhost:23423
2010-10-28 00:19:51,937 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2010-10-28 00:19:54,593 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2010-10-28 00:19:56,093 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.sql' has been run
2010-10-28 00:20:25,890 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.1.sql' has been run
2010-10-28 00:20:25,890 DEBUG [DBLogDAOImpl] Checking if script 'script-0.2.sql' has been run
2010-10-28 00:20:25,890 DEBUG [DBLogDAOImpl] Checking if script 'script-0.3.1.sql' has been run
2010-10-28 00:20:25,890 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.sql' has been run
2010-10-28 00:20:25,890 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.1.sql' has been run
2010-10-28 00:20:25,890 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.2.sql' has been run
2010-10-28 00:20:32,750 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2010-10-28 00:20:32,859 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 1
2010-10-28 00:20:33,578 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2010-10-28 00:20:33,578 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 2
2010-10-28 00:20:33,734 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2010-10-28 00:20:33,734 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 3
2010-10-28 00:20:33,875 INFO [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2010-10-28 00:20:33,875 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 4
2010-10-28 00:20:33,921 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2010-10-28 00:20:34,109 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 5
2010-10-28 00:20:34,156 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2010-10-28 00:20:34,156 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 6
2010-10-28 00:20:34,187 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2010-10-28 00:20:34,203 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 7
2010-10-28 00:20:34,250 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C-series)' (id=7)
2010-10-28 00:20:34,250 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 8
2010-10-28 00:20:34,281 INFO [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2010-10-28 00:20:34,281 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 9
2010-10-28 00:20:34,421 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2010-10-28 00:20:34,421 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 10
2010-10-28 00:20:34,578 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2010-10-28 00:20:34,625 DEBUG [FFMPEGWrapper] Invoking FFMPEG to check if it exists of path C:\Archivos de programa\Serviio\bin\\..\lib/ffmpeg.exe
2010-10-28 00:20:34,687 DEBUG [ProcessExecutor] Starting C:\Archivos de programa\Serviio\bin\\..\lib/ffmpeg.exe
2010-10-28 00:20:36,671 INFO [VideoDeliveryEngine] Cleaning transcode engine and its data
2010-10-28 00:20:36,671 DEBUG [ConfigEntryDAOImpl] Reading all ConfigEntries
2010-10-28 00:20:37,390 INFO [WebServer] WebServer starting on port 8895
2010-10-28 00:20:37,546 INFO [Device] Created UPnP Device with UUID: 33a806e5-df8a-3086-bdee-a45ec476debd, bound address: 192.168.0.14
2010-10-28 00:20:37,890 INFO [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2010-10-28 00:20:37,968 INFO [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2010-10-28 00:20:37,968 INFO [CompositeCacheConfigurator] Setting default auxiliaries to null
2010-10-28 00:20:37,968 INFO [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2010-10-28 00:20:37,984 INFO [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2010-10-28 00:20:37,984 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2010-10-28 00:20:37,984 INFO [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1288218037984, LastAccessTime = 1288218037984, getTimeToLiveSeconds() = -1, createTime = 1288218037984 ]
2010-10-28 00:20:37,984 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2010-10-28 00:20:38,078 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2010-10-28 00:20:38,078 INFO [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2010-10-28 00:20:38,078 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2010-10-28 00:20:38,078 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_default
2010-10-28 00:20:38,078 INFO [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2010-10-28 00:20:38,078 INFO [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2010-10-28 00:20:38,078 INFO [CompositeCacheConfigurator] Finished configuration in 110 ms.
2010-10-28 00:20:38,078 DEBUG [DiscoveryManager] UPNP device 33a806e5-df8a-3086-bdee-a45ec476debd is available
2010-10-28 00:20:38,078 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2010-10-28 00:20:38,078 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface 192.168.0.14
2010-10-28 00:20:38,078 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2010-10-28 00:20:38,078 INFO [EventDispatcher] Starting EventDispatcher
2010-10-28 00:20:38,187 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface 192.168.0.14
2010-10-28 00:20:38,312 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 33a806e5-df8a-3086-bdee-a45ec476debd
2010-10-28 00:20:38,343 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:12:08
2010-10-28 00:20:38,390 DEBUG [WebServer] Incoming connection from /192.168.0.14:50677
2010-10-28 00:20:38,390 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 33a806e5-df8a-3086-bdee-a45ec476debd from WINDOWS, UPnP/1.0, Intel MicroStack/1.0.1497
2010-10-28 00:20:38,765 INFO [UpdateChecker] Checking if a new version is available
2010-10-28 00:20:40,093 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Samsung TV / player (C-series)'
2010-10-28 00:20:40,093 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2010-10-28 00:20:40,109 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2010-10-28 00:20:40,203 DEBUG [ServiceEventSubscriptionRequestHandler] ServiceEvent subscription request received for service ContentDirectory
2010-10-28 00:20:40,203 DEBUG [ServiceEventSubscriptionRequestHandler] Event subscription registered (uuid=ae9b89db-56e0-4323-b3f5-31add5d90adc) for service urn:upnp-org:serviceId:ContentDirectory reporting to http://192.168.0.14:57046/serviceEventi ... tDirectory
2010-10-28 00:20:40,343 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.0.14:63072
2010-10-28 00:20:40,359 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s)
2010-10-28 00:20:40,625 DEBUG [EventDispatcher] Sending event notification #0 for subscription ae9b89db-56e0-4323-b3f5-31add5d90adc to endpoint http://192.168.0.14:57046/serviceEventi ... tDirectory
2010-10-28 00:20:40,640 DEBUG [RequestExecutor] Sending HTTP request to 192.168.0.14:57046
2010-10-28 00:20:40,656 DEBUG [EventDispatcher] Event notification sent and received successfully
2010-10-28 00:20:42,000 DEBUG [RepositoryDAOImpl] Reading all Repositories
2010-10-28 00:20:42,531 DEBUG [WebServer] Incoming connection from /192.168.0.14:52928
2010-10-28 00:20:42,531 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 33a806e5-df8a-3086-bdee-a45ec476debd from WINDOWS, UPnP/1.0, Intel MicroStack/1.0.1497
2010-10-28 00:20:42,546 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Samsung TV / player (C-series)'
2010-10-28 00:20:42,546 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2010-10-28 00:20:42,546 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2010-10-28 00:20:42,546 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from WINDOWS, UPnP/1.0, Intel MicroStack/1.0.1497:
2010-10-28 00:20:43,812 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type AUDIO
2010-10-28 00:20:43,968 DEBUG [ContentDirectory] Browse() called for profile Samsung TV / player (C-series) with parameters: objectID = 0, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 4096, sortCriteria =
2010-10-28 00:20:44,062 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2010-10-28 00:20:44,078 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=0, title=Serviio Media Library, class=CONTAINER, cacheRegion=local_default
2010-10-28 00:20:44,250 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type VIDEO
2010-10-28 00:20:44,265 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A, title=Audio, class=CONTAINER, cacheRegion=local_default
2010-10-28 00:20:44,281 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_A, title=Artists, class=CONTAINER, cacheRegion=local_default
2010-10-28 00:20:44,296 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListArtistsByNameCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=ART, recursive=false, cacheRegion=local_default
2010-10-28 00:20:44,312 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAlbumsForArtistCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=A, recursive=false, cacheRegion=local_default
2010-10-28 00:20:44,328 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForArtistAndAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2010-10-28 00:20:44,328 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_F, title=Folders, class=CONTAINER, cacheRegion=local_default
2010-10-28 00:20:44,343 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAudioFoldersByNameCommand, containerClass=STORAGE_FOLDER, itemClass=MUSIC_TRACK, idPrefix=FOL, recursive=true, cacheRegion=local_default
2010-10-28 00:20:44,343 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_G, title=Genres, class=CONTAINER, cacheRegion=local_default
2010-10-28 00:20:44,359 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAudioGenresByNameCommand, containerClass=MUSIC_GENRE, itemClass=null, idPrefix=GEN, recursive=false, cacheRegion=local_default
2010-10-28 00:20:44,359 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForGenreCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2010-10-28 00:20:44,375 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_T, title=Titles, class=CONTAINER, cacheRegion=local_default
2010-10-28 00:20:44,375 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2010-10-28 00:20:44,390 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForInitialCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2010-10-28 00:20:44,406 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_S, title=All songs, class=CONTAINER, cacheRegion=local_default
2010-10-28 00:20:44,406 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAllSongsCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2010-10-28 00:20:44,421 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_AS, title=Artist Songs, class=CONTAINER, cacheRegion=local_default
2010-10-28 00:20:44,421 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListArtistsByNameCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=ART_S, recursive=false, cacheRegion=local_default
2010-10-28 00:20:44,437 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForArtistCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2010-10-28 00:20:44,453 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_ALB, title=All albums, class=CONTAINER, cacheRegion=local_default
2010-10-28 00:20:44,468 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAllAlbumsCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=ALB, recursive=false, cacheRegion=local_default
2010-10-28 00:20:44,468 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2010-10-28 00:20:44,484 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I, title=Image, class=CONTAINER, cacheRegion=local_default
2010-10-28 00:20:44,484 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_A, title=Albums, class=CONTAINER, cacheRegion=local_default
2010-10-28 00:20:44,500 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListFlatImageFoldersByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=ALB, recursive=false, cacheRegion=local_default
2010-10-28 00:20:44,500 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForFolderCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2010-10-28 00:20:44,515 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_F, title=Folders, class=CONTAINER, cacheRegion=local_default
2010-10-28 00:20:44,531 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImageFoldersByNameCommand, containerClass=STORAGE_FOLDER, itemClass=PHOTO, idPrefix=FOL, recursive=true, cacheRegion=local_default
2010-10-28 00:20:44,546 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_Y, title=Year, class=CONTAINER, cacheRegion=local_default
2010-10-28 00:20:44,546 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesCreationYearsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=YEAR, recursive=false, cacheRegion=local_default
2010-10-28 00:20:44,562 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForCreationYearCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2010-10-28 00:20:44,578 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_T, title=Timeline, class=CONTAINER, cacheRegion=local_default
2010-10-28 00:20:44,578 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesCreationYearsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=YEAR, recursive=false, cacheRegion=local_default
2010-10-28 00:20:44,593 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesCreationMonthsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=MON, recursive=false, cacheRegion=local_default
2010-10-28 00:20:44,609 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForCreationMonthAndYearCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2010-10-28 00:20:44,625 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_AI, title=All images, class=CONTAINER, cacheRegion=local_default
2010-10-28 00:20:44,640 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListAllImagesCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2010-10-28 00:20:44,656 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V, title=Video, class=CONTAINER, cacheRegion=local_default
2010-10-28 00:20:44,671 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_T, title=All titles, class=CONTAINER, cacheRegion=local_default
2010-10-28 00:20:44,671 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2010-10-28 00:20:44,687 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForInitialCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2010-10-28 00:20:44,703 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_M, title=Movies, class=CONTAINER, cacheRegion=local_default
2010-10-28 00:20:44,718 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListMovieVideosByNameCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2010-10-28 00:20:44,734 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_S, title=Series, class=CONTAINER, cacheRegion=local_default
2010-10-28 00:20:44,750 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListSeriesByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=SER, recursive=false, cacheRegion=local_resetafterplay
2010-10-28 00:20:44,781 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListSeasonsForSeriesCommand, containerClass=CONTAINER, itemClass=null, idPrefix=SSN, recursive=false, cacheRegion=local_resetafterplay
2010-10-28 00:20:44,796 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListEpisodesForSeriesSeasonCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_resetafterplay
2010-10-28 00:20:44,796 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_F, title=Folders, class=CONTAINER, cacheRegion=local_default
2010-10-28 00:20:44,812 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoFoldersByNameCommand, containerClass=STORAGE_FOLDER, itemClass=VIDEO_ITEM, idPrefix=FOL, recursive=true, cacheRegion=local_default
2010-10-28 00:20:44,812 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_LV, title=Last viewed, class=CONTAINER, cacheRegion=local_resetafterplay
2010-10-28 00:20:44,828 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListLastViewedVideosCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_resetafterplay
2010-10-28 00:20:44,843 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_LA, title=Last added, class=CONTAINER, cacheRegion=local_default
2010-10-28 00:20:44,859 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListLastAddedVideosCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2010-10-28 00:20:44,859 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_G, title=Genres, class=CONTAINER, cacheRegion=local_default
2010-10-28 00:20:44,875 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoGenresByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=GEN, recursive=false, cacheRegion=local_default
2010-10-28 00:20:44,906 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForGenreCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2010-10-28 00:20:44,906 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_A, title=Actors, class=CONTAINER, cacheRegion=local_default
2010-10-28 00:20:44,921 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListActorInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2010-10-28 00:20:44,921 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListActorsForInitialCommand, containerClass=PERSON, itemClass=null, idPrefix=P, recursive=false, cacheRegion=local_default
2010-10-28 00:20:44,937 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForActorCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2010-10-28 00:20:44,953 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_D, title=Directors, class=CONTAINER, cacheRegion=local_default
2010-10-28 00:20:44,968 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListDirectorInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2010-10-28 00:20:44,984 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListDirectorsForInitialCommand, containerClass=PERSON, itemClass=null, idPrefix=P, recursive=false, cacheRegion=local_default
2010-10-28 00:20:45,015 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForDirectorCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2010-10-28 00:20:45,031 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_P, title=Producers, class=CONTAINER, cacheRegion=local_default
2010-10-28 00:20:45,046 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListProducerInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2010-10-28 00:20:45,078 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListProducersForInitialCommand, containerClass=PERSON, itemClass=null, idPrefix=P, recursive=false, cacheRegion=local_default
2010-10-28 00:20:45,078 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForProducerCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2010-10-28 00:20:45,203 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2010-10-28 00:20:45,531 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2010-10-28 00:20:45,531 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from WINDOWS, UPnP/1.0, Intel MicroStack/1.0.1497:
2010-10-28 00:20:45,531 DEBUG [ContentDirectory] Browse() called for profile Samsung TV / player (C-series) with parameters: objectID = A, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 4096, sortCriteria =
2010-10-28 00:20:45,625 DEBUG [PersonDAOImpl] Retrieving number of persons with role ARTIST
2010-10-28 00:20:47,281 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for AUDIO
2010-10-28 00:20:47,375 DEBUG [GenreDAOImpl] Retrieving number of genres for AUDIO
2010-10-28 00:20:48,218 DEBUG [RepositoryDAOImpl] Reading all Repositories
2010-10-28 00:20:49,265 DEBUG [MusicTrackDAOImpl] Retrieving number of music track initials
2010-10-28 00:20:49,281 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2010-10-28 00:20:49,296 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2010-10-28 00:20:49,296 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from WINDOWS, UPnP/1.0, Intel MicroStack/1.0.1497:
2010-10-28 00:20:49,312 DEBUG [ContentDirectory] Browse() called for profile Samsung TV / player (C-series) with parameters: objectID = I, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 4096, sortCriteria =
2010-10-28 00:20:49,312 DEBUG [FolderDAOImpl] Retrieving number of leaf folders
2010-10-28 00:20:50,171 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for IMAGE
2010-10-28 00:20:50,796 DEBUG [ImageDAOImpl] Retrieving number of images' years
2010-10-28 00:20:50,859 DEBUG [ImageDAOImpl] Retrieving number of images' years
2010-10-28 00:20:50,859 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2010-10-28 00:20:50,875 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2010-10-28 00:20:50,875 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from WINDOWS, UPnP/1.0, Intel MicroStack/1.0.1497:
2010-10-28 00:20:50,875 DEBUG [ContentDirectory] Browse() called for profile Samsung TV / player (C-series) with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 4096, sortCriteria =
2010-10-28 00:20:51,062 DEBUG [VideoDAOImpl] Retrieving number of video initials
2010-10-28 00:20:51,140 DEBUG [VideoDAOImpl] Retrieving number of videos of type 2
2010-10-28 00:20:51,171 DEBUG [SeriesDAOImpl] Retrieving number of series
2010-10-28 00:20:51,453 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO
2010-10-28 00:20:51,453 DEBUG [VideoDAOImpl] Retrieving number of 10 last viewed videos
2010-10-28 00:20:51,484 DEBUG [VideoDAOImpl] Retrieving number of 10 last added videos
2010-10-28 00:20:51,484 DEBUG [VideoDAOImpl] Retrieving number of videos of type 0
2010-10-28 00:20:51,500 DEBUG [GenreDAOImpl] Retrieving number of genres for VIDEO
2010-10-28 00:20:51,500 DEBUG [PersonDAOImpl] Retrieving number of person initials for role ACTOR
2010-10-28 00:20:51,546 DEBUG [PersonDAOImpl] Retrieving number of person initials for role DIRECTOR
2010-10-28 00:20:51,546 DEBUG [PersonDAOImpl] Retrieving number of person initials for role PRODUCER
2010-10-28 00:20:51,546 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2010-10-28 00:20:51,562 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2010-10-28 00:20:51,562 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from WINDOWS, UPnP/1.0, Intel MicroStack/1.0.1497:
2010-10-28 00:20:51,562 DEBUG [ContentDirectory] Browse() called for profile Samsung TV / player (C-series) with parameters: objectID = A_A, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 4096, sortCriteria =
2010-10-28 00:20:51,562 DEBUG [PersonDAOImpl] Retrieving list of persons with role ARTIST (from=0, count=4096)
2010-10-28 00:20:51,609 DEBUG [PersonDAOImpl] Retrieving number of persons with role ARTIST
2010-10-28 00:20:51,609 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2010-10-28 00:20:51,625 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2010-10-28 00:20:51,640 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from WINDOWS, UPnP/1.0, Intel MicroStack/1.0.1497:
2010-10-28 00:20:51,640 DEBUG [ContentDirectory] Browse() called for profile Samsung TV / player (C-series) with parameters: objectID = A_F, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 4096, sortCriteria =
2010-10-28 00:20:51,640 DEBUG [RepositoryDAOImpl] Retrieving list of Repositories for AUDIO (from=0, count=4096)
2010-10-28 00:20:51,656 DEBUG [FolderDAOImpl] Getting number of AUDIO sub-folders and media items in folder 'root'
2010-10-28 00:20:51,703 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for AUDIO
2010-10-28 00:20:51,703 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2010-10-28 00:20:51,703 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2010-10-28 00:20:51,718 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from WINDOWS, UPnP/1.0, Intel MicroStack/1.0.1497:
2010-10-28 00:20:51,718 DEBUG [ContentDirectory] Browse() called for profile Samsung TV / player (C-series) with parameters: objectID = A_G, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 4096, sortCriteria =
2010-10-28 00:20:51,718 DEBUG [GenreDAOImpl] Retrieving list of genres for AUDIO (from=0, count=4096)
2010-10-28 00:20:51,750 DEBUG [GenreDAOImpl] Retrieving number of genres for AUDIO
2010-10-28 00:20:51,750 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2010-10-28 00:20:51,765 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2010-10-28 00:20:51,765 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from WINDOWS, UPnP/1.0, Intel MicroStack/1.0.1497:
2010-10-28 00:20:51,765 DEBUG [ContentDirectory] Browse() called for profile Samsung TV / player (C-series) with parameters: objectID = A_T, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 4096, sortCriteria =
2010-10-28 00:20:51,765 DEBUG [MusicTrackDAOImpl] Retrieving list of music track initials (from=0, count=4096)
2010-10-28 00:20:51,781 DEBUG [MusicTrackDAOImpl] Retrieving number of music track initials
2010-10-28 00:20:51,781 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2010-10-28 00:20:51,781 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2010-10-28 00:20:51,781 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from WINDOWS, UPnP/1.0, Intel MicroStack/1.0.1497:
2010-10-28 00:20:51,796 DEBUG [ContentDirectory] Browse() called for profile Samsung TV / player (C-series) with parameters: objectID = I_A, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 4096, sortCriteria =
2010-10-28 00:20:51,796 DEBUG [FolderDAOImpl] Retrieving list of leaf folders (from=0, count=4096)
2010-10-28 00:20:51,812 DEBUG [RepositoryDAOImpl] Reading a Repository (id = 1)
2010-10-28 00:20:51,828 DEBUG [ImageDAOImpl] Retrieving number of images for folder 1
2010-10-28 00:20:51,828 DEBUG [FolderDAOImpl] Retrieving number of leaf folders
2010-10-28 00:20:51,828 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2010-10-28 00:20:51,843 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2010-10-28 00:20:51,843 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from WINDOWS, UPnP/1.0, Intel MicroStack/1.0.1497:
2010-10-28 00:20:51,843 DEBUG [ContentDirectory] Browse() called for profile Samsung TV / player (C-series) with parameters: objectID = I_F, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 4096, sortCriteria =
2010-10-28 00:20:51,843 DEBUG [RepositoryDAOImpl] Retrieving list of Repositories for IMAGE (from=0, count=4096)
2010-10-28 00:20:51,843 DEBUG [FolderDAOImpl] Getting number of IMAGE sub-folders and media items in folder 'root'
2010-10-28 00:20:51,859 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for IMAGE
2010-10-28 00:20:51,859 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2010-10-28 00:20:51,859 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2010-10-28 00:20:51,859 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from WINDOWS, UPnP/1.0, Intel MicroStack/1.0.1497:
2010-10-28 00:20:51,875 DEBUG [ContentDirectory] Browse() called for profile Samsung TV / player (C-series) with parameters: objectID = I_Y, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 4096, sortCriteria =
2010-10-28 00:20:51,875 DEBUG [ImageDAOImpl] Retrieving list of images' years (from=0, count=4096)
2010-10-28 00:20:51,875 DEBUG [ImageDAOImpl] Retrieving number of images for year 2010
2010-10-28 00:20:51,906 DEBUG [ImageDAOImpl] Retrieving number of images' years
2010-10-28 00:20:51,906 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2010-10-28 00:20:51,906 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2010-10-28 00:20:51,906 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from WINDOWS, UPnP/1.0, Intel MicroStack/1.0.1497:
2010-10-28 00:20:51,921 DEBUG [ContentDirectory] Browse() called for profile Samsung TV / player (C-series) with parameters: objectID = I_T, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 4096, sortCriteria =
2010-10-28 00:20:51,921 DEBUG [ImageDAOImpl] Retrieving list of images' years (from=0, count=4096)
2010-10-28 00:20:51,921 DEBUG [ImageDAOImpl] Retrieving number of creation date months for year 2010
2010-10-28 00:20:51,937 DEBUG [ImageDAOImpl] Retrieving number of images' years
2010-10-28 00:20:51,937 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2010-10-28 00:20:51,937 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2010-10-28 00:20:51,937 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from WINDOWS, UPnP/1.0, Intel MicroStack/1.0.1497:
2010-10-28 00:20:51,953 DEBUG [ContentDirectory] Browse() called for profile Samsung TV / player (C-series) with parameters: objectID = V_T, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 4096, sortCriteria =
2010-10-28 00:20:51,953 DEBUG [VideoDAOImpl] Retrieving list of video initials (from=0, count=4096)
2010-10-28 00:20:51,953 DEBUG [VideoDAOImpl] Retrieving number of video initials
2010-10-28 00:20:51,953 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2010-10-28 00:20:51,953 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2010-10-28 00:20:51,953 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from WINDOWS, UPnP/1.0, Intel MicroStack/1.0.1497:
2010-10-28 00:20:51,953 DEBUG [ContentDirectory] Browse() called for profile Samsung TV / player (C-series) with parameters: objectID = V_M, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 4096, sortCriteria =
2010-10-28 00:20:51,953 DEBUG [VideoDAOImpl] Retrieving list of videos of type 2 (from=0, count=4096)
2010-10-28 00:20:51,984 DEBUG [VideoDAOImpl] Retrieving number of videos of type 2
2010-10-28 00:20:51,984 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2010-10-28 00:20:51,984 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2010-10-28 00:20:51,984 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from WINDOWS, UPnP/1.0, Intel MicroStack/1.0.1497:
2010-10-28 00:20:52,000 DEBUG [ContentDirectory] Browse() called for profile Samsung TV / player (C-series) with parameters: objectID = V_S, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 4096, sortCriteria =
2010-10-28 00:20:52,000 DEBUG [SeriesDAOImpl] Retrieving list of series (from=0, count=4096)
2010-10-28 00:20:52,000 DEBUG [SeriesDAOImpl] Retrieving number of series
2010-10-28 00:20:52,000 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2010-10-28 00:20:52,000 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2010-10-28 00:20:52,000 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from WINDOWS, UPnP/1.0, Intel MicroStack/1.0.1497:
2010-10-28 00:20:52,015 DEBUG [ContentDirectory] Browse() called for profile Samsung TV / player (C-series) with parameters: objectID = V_F, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 4096, sortCriteria =
2010-10-28 00:20:52,015 DEBUG [RepositoryDAOImpl] Retrieving list of Repositories for VIDEO (from=0, count=4096)
2010-10-28 00:20:52,015 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 'root'
2010-10-28 00:20:52,015 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO
2010-10-28 00:20:52,015 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2010-10-28 00:20:52,031 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2010-10-28 00:20:52,031 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from WINDOWS, UPnP/1.0, Intel MicroStack/1.0.1497:
2010-10-28 00:20:52,031 DEBUG [ContentDirectory] Browse() called for profile Samsung TV / player (C-series) with parameters: objectID = V_LV, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 4096, sortCriteria =
2010-10-28 00:20:52,031 DEBUG [VideoDAOImpl] Retrieving list of 10 last viewed videos (from=0, count=4096)
2010-10-28 00:20:52,046 DEBUG [VideoDAOImpl] Retrieving number of 10 last viewed videos
2010-10-28 00:20:52,046 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_resetafterplay), returning it
2010-10-28 00:20:52,046 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2010-10-28 00:20:52,046 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from WINDOWS, UPnP/1.0, Intel MicroStack/1.0.1497:
2010-10-28 00:20:52,046 DEBUG [ContentDirectory] Browse() called for profile Samsung TV / player (C-series) with parameters: objectID = V_LA, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 4096, sortCriteria =
2010-10-28 00:20:52,046 DEBUG [VideoDAOImpl] Retrieving list of 10 last added videos (from=0, count=4096)
2010-10-28 00:20:52,078 DEBUG [VideoDAOImpl] Retrieving number of 10 last added videos
2010-10-28 00:20:52,078 DEBUG [VideoDAOImpl] Retrieving number of videos of type 0
2010-10-28 00:20:52,078 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2010-10-28 00:20:52,078 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2010-10-28 00:20:52,078 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from WINDOWS, UPnP/1.0, Intel MicroStack/1.0.1497:
2010-10-28 00:20:52,093 DEBUG [ContentDirectory] Browse() called for profile Samsung TV / player (C-series) with parameters: objectID = V_G, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 4096, sortCriteria =
2010-10-28 00:20:52,093 DEBUG [GenreDAOImpl] Retrieving list of genres for VIDEO (from=0, count=4096)
2010-10-28 00:20:52,093 DEBUG [GenreDAOImpl] Retrieving number of genres for VIDEO
2010-10-28 00:20:52,093 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2010-10-28 00:20:52,093 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2010-10-28 00:20:52,093 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from WINDOWS, UPnP/1.0, Intel MicroStack/1.0.1497:
2010-10-28 00:20:52,109 DEBUG [ContentDirectory] Browse() called for profile Samsung TV / player (C-series) with parameters: objectID = V_A, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 4096, sortCriteria =
2010-10-28 00:20:52,109 DEBUG [PersonDAOImpl] Retrieving list of person initials (role = ACTOR, from=0, count=4096)
2010-10-28 00:20:52,125 DEBUG [PersonDAOImpl] Retrieving number of person initials for role ACTOR
2010-10-28 00:20:52,125 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2010-10-28 00:20:52,125 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2010-10-28 00:20:52,125 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from WINDOWS, UPnP/1.0, Intel MicroStack/1.0.1497:
2010-10-28 00:20:52,125 DEBUG [ContentDirectory] Browse() called for profile Samsung TV / player (C-series) with parameters: objectID = V_D, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 4096, sortCriteria =
2010-10-28 00:20:52,125 DEBUG [PersonDAOImpl] Retrieving list of person initials (role = DIRECTOR, from=0, count=4096)
2010-10-28 00:20:52,125 DEBUG [PersonDAOImpl] Retrieving number of person initials for role DIRECTOR
2010-10-28 00:20:52,140 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2010-10-28 00:20:52,140 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from WINDOWS, UPnP/1.0, Intel MicroStack/1.0.1497:
2010-10-28 00:20:52,140 DEBUG [ContentDirectory] Browse() called for profile Samsung TV / player (C-series) with parameters: objectID = V_P, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 4096, sortCriteria =
2010-10-28 00:20:52,140 DEBUG [PersonDAOImpl] Retrieving list of person initials (role = PRODUCER, from=0, count=4096)
2010-10-28 00:20:52,140 DEBUG [PersonDAOImpl] Retrieving number of person initials for role PRODUCER
2010-10-28 00:20:52,140 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2010-10-28 00:20:52,156 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from WINDOWS, UPnP/1.0, Intel MicroStack/1.0.1497:
2010-10-28 00:20:52,156 DEBUG [ContentDirectory] Browse() called for profile Samsung TV / player (C-series) with parameters: objectID = A_F#FOL_R1, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 4096, sortCriteria =
2010-10-28 00:20:52,156 DEBUG [FolderDAOImpl] Getting number of sub-Folders in folder null
2010-10-28 00:20:52,171 DEBUG [MusicTrackDAOImpl] Retrieving list of music tracks for folder 1 (from=0, count=4096)
2010-10-28 00:20:52,187 DEBUG [FolderDAOImpl] Getting number of AUDIO sub-folders and media items in folder 'root'
2010-10-28 00:20:52,203 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2010-10-28 00:20:52,203 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2010-10-28 00:20:52,203 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from WINDOWS, UPnP/1.0, Intel MicroStack/1.0.1497:
2010-10-28 00:20:52,203 DEBUG [ContentDirectory] Browse() called for profile Samsung TV / player (C-series) with parameters: objectID = I_A#ALB_1, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 4096, sortCriteria =
2010-10-28 00:20:52,203 DEBUG [ImageDAOImpl] Retrieving list of images for folder 1 (from=0, count=4096)
2010-10-28 00:20:52,234 DEBUG [FolderDAOImpl] Reading a Folder (id = 1)
2010-10-28 00:20:52,234 DEBUG [RepositoryDAOImpl] Reading a Repository (id = 1)
2010-10-28 00:20:52,250 DEBUG [ImageDAOImpl] Reading an Image (id = 1)
2010-10-28 00:20:52,265 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 1 and profile Samsung TV / player (C-series)
2010-10-28 00:20:52,265 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1073.jpg
2010-10-28 00:20:52,515 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 1)
2010-10-28 00:20:53,000 DEBUG [FolderDAOImpl] Reading a Folder (id = 1)
2010-10-28 00:20:53,000 DEBUG [RepositoryDAOImpl] Reading a Repository (id = 1)
2010-10-28 00:20:53,000 DEBUG [ImageDAOImpl] Reading an Image (id = 2)
2010-10-28 00:20:53,000 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 2 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,000 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1074.jpg
2010-10-28 00:20:53,000 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 2)
2010-10-28 00:20:53,000 DEBUG [ImageDAOImpl] Reading an Image (id = 3)
2010-10-28 00:20:53,000 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 3 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,000 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1075.jpg
2010-10-28 00:20:53,000 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 3)
2010-10-28 00:20:53,000 DEBUG [ImageDAOImpl] Reading an Image (id = 4)
2010-10-28 00:20:53,000 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 4 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,000 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1076.jpg
2010-10-28 00:20:53,000 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 4)
2010-10-28 00:20:53,015 DEBUG [FolderDAOImpl] Reading a Folder (id = 1)
2010-10-28 00:20:53,015 DEBUG [RepositoryDAOImpl] Reading a Repository (id = 1)
2010-10-28 00:20:53,015 DEBUG [ImageDAOImpl] Reading an Image (id = 5)
2010-10-28 00:20:53,015 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 5 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,015 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1077.jpg
2010-10-28 00:20:53,015 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 5)
2010-10-28 00:20:53,046 DEBUG [FolderDAOImpl] Reading a Folder (id = 1)
2010-10-28 00:20:53,046 DEBUG [RepositoryDAOImpl] Reading a Repository (id = 1)
2010-10-28 00:20:53,046 DEBUG [ImageDAOImpl] Reading an Image (id = 6)
2010-10-28 00:20:53,046 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 6 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,046 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1078.jpg
2010-10-28 00:20:53,046 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 6)
2010-10-28 00:20:53,046 DEBUG [ImageDAOImpl] Reading an Image (id = 7)
2010-10-28 00:20:53,062 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 7 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,062 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1079.jpg
2010-10-28 00:20:53,062 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 7)
2010-10-28 00:20:53,062 DEBUG [FolderDAOImpl] Reading a Folder (id = 1)
2010-10-28 00:20:53,062 DEBUG [RepositoryDAOImpl] Reading a Repository (id = 1)
2010-10-28 00:20:53,062 DEBUG [ImageDAOImpl] Reading an Image (id = 8)
2010-10-28 00:20:53,062 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 8 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,062 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1080.jpg
2010-10-28 00:20:53,062 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 8)
2010-10-28 00:20:53,062 DEBUG [ImageDAOImpl] Reading an Image (id = 9)
2010-10-28 00:20:53,062 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 9 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,062 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1081.jpg
2010-10-28 00:20:53,062 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 9)
2010-10-28 00:20:53,078 DEBUG [FolderDAOImpl] Reading a Folder (id = 1)
2010-10-28 00:20:53,078 DEBUG [RepositoryDAOImpl] Reading a Repository (id = 1)
2010-10-28 00:20:53,078 DEBUG [ImageDAOImpl] Reading an Image (id = 10)
2010-10-28 00:20:53,078 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 10 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,078 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1082.jpg
2010-10-28 00:20:53,078 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 10)
2010-10-28 00:20:53,093 DEBUG [ImageDAOImpl] Reading an Image (id = 11)
2010-10-28 00:20:53,093 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 11 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,093 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1085.jpg
2010-10-28 00:20:53,093 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 11)
2010-10-28 00:20:53,093 DEBUG [FolderDAOImpl] Reading a Folder (id = 1)
2010-10-28 00:20:53,093 DEBUG [RepositoryDAOImpl] Reading a Repository (id = 1)
2010-10-28 00:20:53,093 DEBUG [ImageDAOImpl] Reading an Image (id = 12)
2010-10-28 00:20:53,093 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 12 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,093 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1086.jpg
2010-10-28 00:20:53,093 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 12)
2010-10-28 00:20:53,093 DEBUG [ImageDAOImpl] Reading an Image (id = 13)
2010-10-28 00:20:53,093 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 13 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,093 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1087.jpg
2010-10-28 00:20:53,093 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 13)
2010-10-28 00:20:53,109 DEBUG [FolderDAOImpl] Reading a Folder (id = 1)
2010-10-28 00:20:53,109 DEBUG [RepositoryDAOImpl] Reading a Repository (id = 1)
patillaldi
Continuos log
2010-10-28 00:20:53,109 DEBUG [ImageDAOImpl] Reading an Image (id = 14)
2010-10-28 00:20:53,109 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 14 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,109 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1088.jpg
2010-10-28 00:20:53,109 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 14)
2010-10-28 00:20:53,109 DEBUG [ImageDAOImpl] Reading an Image (id = 15)
2010-10-28 00:20:53,109 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 15 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,109 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1089.jpg
2010-10-28 00:20:53,109 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 15)
2010-10-28 00:20:53,109 DEBUG [ImageDAOImpl] Reading an Image (id = 16)
2010-10-28 00:20:53,109 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 16 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,109 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1090.jpg
2010-10-28 00:20:53,125 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 16)
2010-10-28 00:20:53,125 DEBUG [FolderDAOImpl] Reading a Folder (id = 1)
2010-10-28 00:20:53,125 DEBUG [RepositoryDAOImpl] Reading a Repository (id = 1)
2010-10-28 00:20:53,125 DEBUG [ImageDAOImpl] Reading an Image (id = 17)
2010-10-28 00:20:53,125 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 17 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,125 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1091.jpg
2010-10-28 00:20:53,125 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 17)
2010-10-28 00:20:53,125 DEBUG [ImageDAOImpl] Reading an Image (id = 18)
2010-10-28 00:20:53,125 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 18 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,125 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1092.jpg
2010-10-28 00:20:53,125 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 18)
2010-10-28 00:20:53,140 DEBUG [RepositoryDAOImpl] Reading a Repository (id = 1)
2010-10-28 00:20:53,140 DEBUG [ImageDAOImpl] Reading an Image (id = 19)
2010-10-28 00:20:53,140 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 19 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,140 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1093.jpg
2010-10-28 00:20:53,140 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 19)
2010-10-28 00:20:53,140 DEBUG [FolderDAOImpl] Reading a Folder (id = 1)
2010-10-28 00:20:53,140 DEBUG [ImageDAOImpl] Reading an Image (id = 20)
2010-10-28 00:20:53,140 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 20 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,140 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1094.jpg
2010-10-28 00:20:53,140 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 20)
2010-10-28 00:20:53,140 DEBUG [ImageDAOImpl] Retrieving number of images for folder 1
2010-10-28 00:20:53,140 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2010-10-28 00:20:53,218 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2010-10-28 00:20:53,234 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from WINDOWS, UPnP/1.0, Intel MicroStack/1.0.1497:
2010-10-28 00:20:53,234 DEBUG [ContentDirectory] Browse() called for profile Samsung TV / player (C-series) with parameters: objectID = I_F#FOL_R1, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 4096, sortCriteria =
2010-10-28 00:20:53,234 DEBUG [FolderDAOImpl] Getting number of sub-Folders in folder null
2010-10-28 00:20:53,234 DEBUG [ImageDAOImpl] Retrieving list of images for folder 1 (from=0, count=4096)
2010-10-28 00:20:53,234 DEBUG [FolderDAOImpl] Reading a Folder (id = 1)
2010-10-28 00:20:53,250 DEBUG [RepositoryDAOImpl] Reading a Repository (id = 1)
2010-10-28 00:20:53,250 DEBUG [ImageDAOImpl] Reading an Image (id = 1)
2010-10-28 00:20:53,250 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 1 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,250 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1073.jpg
2010-10-28 00:20:53,250 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 1)
2010-10-28 00:20:53,250 DEBUG [FolderDAOImpl] Reading a Folder (id = 1)
2010-10-28 00:20:53,250 DEBUG [ImageDAOImpl] Reading an Image (id = 2)
2010-10-28 00:20:53,250 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 2 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,250 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1074.jpg
2010-10-28 00:20:53,250 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 2)
2010-10-28 00:20:53,250 DEBUG [ImageDAOImpl] Reading an Image (id = 3)
2010-10-28 00:20:53,250 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 3 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,250 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1075.jpg
2010-10-28 00:20:53,250 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 3)
2010-10-28 00:20:53,265 DEBUG [FolderDAOImpl] Reading a Folder (id = 1)
2010-10-28 00:20:53,265 DEBUG [RepositoryDAOImpl] Reading a Repository (id = 1)
2010-10-28 00:20:53,265 DEBUG [ImageDAOImpl] Reading an Image (id = 4)
2010-10-28 00:20:53,265 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 4 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,265 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1076.jpg
2010-10-28 00:20:53,265 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 4)
2010-10-28 00:20:53,265 DEBUG [ImageDAOImpl] Reading an Image (id = 5)
2010-10-28 00:20:53,265 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 5 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,265 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1077.jpg
2010-10-28 00:20:53,265 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 5)
2010-10-28 00:20:53,265 DEBUG [ImageDAOImpl] Reading an Image (id = 6)
2010-10-28 00:20:53,265 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 6 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,265 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1078.jpg
2010-10-28 00:20:53,265 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 6)
2010-10-28 00:20:53,281 DEBUG [RepositoryDAOImpl] Reading a Repository (id = 1)
2010-10-28 00:20:53,281 DEBUG [ImageDAOImpl] Reading an Image (id = 7)
2010-10-28 00:20:53,281 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 7 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,281 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1079.jpg
2010-10-28 00:20:53,281 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 7)
2010-10-28 00:20:53,281 DEBUG [FolderDAOImpl] Reading a Folder (id = 1)
2010-10-28 00:20:53,281 DEBUG [ImageDAOImpl] Reading an Image (id = 8)
2010-10-28 00:20:53,281 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 8 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,281 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1080.jpg
2010-10-28 00:20:53,281 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 8)
2010-10-28 00:20:53,281 DEBUG [ImageDAOImpl] Reading an Image (id = 9)
2010-10-28 00:20:53,281 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 9 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,281 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1081.jpg
2010-10-28 00:20:53,281 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 9)
2010-10-28 00:20:53,281 DEBUG [ImageDAOImpl] Reading an Image (id = 10)
2010-10-28 00:20:53,296 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 10 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,296 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1082.jpg
2010-10-28 00:20:53,296 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 10)
2010-10-28 00:20:53,296 DEBUG [FolderDAOImpl] Reading a Folder (id = 1)
2010-10-28 00:20:53,296 DEBUG [RepositoryDAOImpl] Reading a Repository (id = 1)
2010-10-28 00:20:53,296 DEBUG [ImageDAOImpl] Reading an Image (id = 11)
2010-10-28 00:20:53,296 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 11 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,296 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1085.jpg
2010-10-28 00:20:53,296 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 11)
2010-10-28 00:20:53,296 DEBUG [ImageDAOImpl] Reading an Image (id = 12)
2010-10-28 00:20:53,296 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 12 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,296 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1086.jpg
2010-10-28 00:20:53,296 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 12)
2010-10-28 00:20:53,312 DEBUG [RepositoryDAOImpl] Reading a Repository (id = 1)
2010-10-28 00:20:53,312 DEBUG [ImageDAOImpl] Reading an Image (id = 13)
2010-10-28 00:20:53,312 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 13 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,312 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1087.jpg
2010-10-28 00:20:53,312 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 13)
2010-10-28 00:20:53,312 DEBUG [FolderDAOImpl] Reading a Folder (id = 1)
2010-10-28 00:20:53,312 DEBUG [ImageDAOImpl] Reading an Image (id = 14)
2010-10-28 00:20:53,312 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 14 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,312 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1088.jpg
2010-10-28 00:20:53,312 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 14)
2010-10-28 00:20:53,312 DEBUG [ImageDAOImpl] Reading an Image (id = 15)
2010-10-28 00:20:53,312 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 15 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,312 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1089.jpg
2010-10-28 00:20:53,312 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 15)
2010-10-28 00:20:53,312 DEBUG [ImageDAOImpl] Reading an Image (id = 16)
2010-10-28 00:20:53,312 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 16 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,312 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1090.jpg
2010-10-28 00:20:53,312 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 16)
2010-10-28 00:20:53,328 DEBUG [FolderDAOImpl] Reading a Folder (id = 1)
2010-10-28 00:20:53,328 DEBUG [RepositoryDAOImpl] Reading a Repository (id = 1)
2010-10-28 00:20:53,328 DEBUG [ImageDAOImpl] Reading an Image (id = 17)
2010-10-28 00:20:53,328 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 17 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,328 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1091.jpg
2010-10-28 00:20:53,328 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 17)
2010-10-28 00:20:53,328 DEBUG [ImageDAOImpl] Reading an Image (id = 18)
2010-10-28 00:20:53,328 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 18 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,328 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1092.jpg
2010-10-28 00:20:53,343 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 18)
2010-10-28 00:20:53,343 DEBUG [FolderDAOImpl] Reading a Folder (id = 1)
2010-10-28 00:20:53,343 DEBUG [RepositoryDAOImpl] Reading a Repository (id = 1)
2010-10-28 00:20:53,343 DEBUG [ImageDAOImpl] Reading an Image (id = 19)
2010-10-28 00:20:53,343 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 19 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,343 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1093.jpg
2010-10-28 00:20:53,343 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 19)
2010-10-28 00:20:53,343 DEBUG [ImageDAOImpl] Reading an Image (id = 20)
2010-10-28 00:20:53,343 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 20 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,343 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1094.jpg
2010-10-28 00:20:53,343 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 20)
2010-10-28 00:20:53,343 DEBUG [FolderDAOImpl] Getting number of IMAGE sub-folders and media items in folder 'root'
2010-10-28 00:20:53,343 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2010-10-28 00:20:53,390 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2010-10-28 00:20:53,390 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from WINDOWS, UPnP/1.0, Intel MicroStack/1.0.1497:
2010-10-28 00:20:53,406 DEBUG [ContentDirectory] Browse() called for profile Samsung TV / player (C-series) with parameters: objectID = I_Y#YEAR_2010, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 4096, sortCriteria =
2010-10-28 00:20:53,406 DEBUG [ImageDAOImpl] Retrieving list of images for year 2010 (from=0, count=4096)
2010-10-28 00:20:53,421 DEBUG [FolderDAOImpl] Reading a Folder (id = 1)
2010-10-28 00:20:53,421 DEBUG [RepositoryDAOImpl] Reading a Repository (id = 1)
2010-10-28 00:20:53,421 DEBUG [ImageDAOImpl] Reading an Image (id = 1)
2010-10-28 00:20:53,421 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 1 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,421 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1073.jpg
2010-10-28 00:20:53,421 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 1)
2010-10-28 00:20:53,421 DEBUG [ImageDAOImpl] Reading an Image (id = 2)
2010-10-28 00:20:53,421 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 2 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,421 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1074.jpg
2010-10-28 00:20:53,421 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 2)
2010-10-28 00:20:53,421 DEBUG [ImageDAOImpl] Reading an Image (id = 3)
2010-10-28 00:20:53,421 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 3 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,421 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1075.jpg
2010-10-28 00:20:53,421 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 3)
2010-10-28 00:20:53,437 DEBUG [RepositoryDAOImpl] Reading a Repository (id = 1)
2010-10-28 00:20:53,437 DEBUG [ImageDAOImpl] Reading an Image (id = 4)
2010-10-28 00:20:53,437 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 4 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,437 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1076.jpg
2010-10-28 00:20:53,437 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 4)
2010-10-28 00:20:53,437 DEBUG [FolderDAOImpl] Reading a Folder (id = 1)
2010-10-28 00:20:53,437 DEBUG [ImageDAOImpl] Reading an Image (id = 5)
2010-10-28 00:20:53,437 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 5 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,437 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1077.jpg
2010-10-28 00:20:53,437 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 5)
2010-10-28 00:20:53,437 DEBUG [ImageDAOImpl] Reading an Image (id = 6)
2010-10-28 00:20:53,437 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 6 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,437 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1078.jpg
2010-10-28 00:20:53,437 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 6)
2010-10-28 00:20:53,437 DEBUG [ImageDAOImpl] Reading an Image (id = 7)
2010-10-28 00:20:53,437 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 7 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,437 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1079.jpg
2010-10-28 00:20:53,437 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 7)
2010-10-28 00:20:53,437 DEBUG [ImageDAOImpl] Reading an Image (id = 8)
2010-10-28 00:20:53,437 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 8 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,437 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1080.jpg
2010-10-28 00:20:53,437 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 8)
2010-10-28 00:20:53,453 DEBUG [RepositoryDAOImpl] Reading a Repository (id = 1)
2010-10-28 00:20:53,453 DEBUG [ImageDAOImpl] Reading an Image (id = 9)
2010-10-28 00:20:53,453 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 9 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,453 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1081.jpg
2010-10-28 00:20:53,453 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 9)
2010-10-28 00:20:53,453 DEBUG [FolderDAOImpl] Reading a Folder (id = 1)
2010-10-28 00:20:53,453 DEBUG [ImageDAOImpl] Reading an Image (id = 10)
2010-10-28 00:20:53,453 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 10 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,453 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1082.jpg
2010-10-28 00:20:53,453 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 10)
2010-10-28 00:20:53,468 DEBUG [RepositoryDAOImpl] Reading a Repository (id = 1)
2010-10-28 00:20:53,468 DEBUG [ImageDAOImpl] Reading an Image (id = 11)
2010-10-28 00:20:53,468 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 11 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,468 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1085.jpg
2010-10-28 00:20:53,468 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 11)
2010-10-28 00:20:53,468 DEBUG [FolderDAOImpl] Reading a Folder (id = 1)
2010-10-28 00:20:53,468 DEBUG [ImageDAOImpl] Reading an Image (id = 12)
2010-10-28 00:20:53,468 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 12 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,468 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1086.jpg
2010-10-28 00:20:53,468 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 12)
2010-10-28 00:20:53,468 DEBUG [ImageDAOImpl] Reading an Image (id = 13)
2010-10-28 00:20:53,468 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 13 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,468 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1087.jpg
2010-10-28 00:20:53,468 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 13)
2010-10-28 00:20:53,468 DEBUG [ImageDAOImpl] Reading an Image (id = 14)
2010-10-28 00:20:53,484 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 14 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,484 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1088.jpg
2010-10-28 00:20:53,484 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 14)
2010-10-28 00:20:53,484 DEBUG [FolderDAOImpl] Reading a Folder (id = 1)
2010-10-28 00:20:53,484 DEBUG [RepositoryDAOImpl] Reading a Repository (id = 1)
2010-10-28 00:20:53,484 DEBUG [ImageDAOImpl] Reading an Image (id = 15)
2010-10-28 00:20:53,484 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 15 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,484 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1089.jpg
2010-10-28 00:20:53,484 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 15)
2010-10-28 00:20:53,484 DEBUG [ImageDAOImpl] Reading an Image (id = 16)
2010-10-28 00:20:53,484 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 16 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,484 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1090.jpg
2010-10-28 00:20:53,500 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 16)
2010-10-28 00:20:53,500 DEBUG [FolderDAOImpl] Reading a Folder (id = 1)
2010-10-28 00:20:53,500 DEBUG [RepositoryDAOImpl] Reading a Repository (id = 1)
2010-10-28 00:20:53,500 DEBUG [ImageDAOImpl] Reading an Image (id = 17)
2010-10-28 00:20:53,500 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 17 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,500 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1091.jpg
2010-10-28 00:20:53,500 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 17)
2010-10-28 00:20:53,500 DEBUG [ImageDAOImpl] Reading an Image (id = 18)
2010-10-28 00:20:53,500 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 18 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,500 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1092.jpg
2010-10-28 00:20:53,500 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 18)
2010-10-28 00:20:53,515 DEBUG [RepositoryDAOImpl] Reading a Repository (id = 1)
2010-10-28 00:20:53,515 DEBUG [ImageDAOImpl] Reading an Image (id = 19)
2010-10-28 00:20:53,515 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 19 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,515 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1093.jpg
2010-10-28 00:20:53,515 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 19)
2010-10-28 00:20:53,515 DEBUG [FolderDAOImpl] Reading a Folder (id = 1)
2010-10-28 00:20:53,515 DEBUG [ImageDAOImpl] Reading an Image (id = 20)
2010-10-28 00:20:53,515 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 20 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,515 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1094.jpg
2010-10-28 00:20:53,515 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 20)
2010-10-28 00:20:53,515 DEBUG [ImageDAOImpl] Retrieving number of images for year 2010
2010-10-28 00:20:53,515 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2010-10-28 00:20:53,546 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2010-10-28 00:20:53,562 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from WINDOWS, UPnP/1.0, Intel MicroStack/1.0.1497:
2010-10-28 00:20:53,562 DEBUG [ContentDirectory] Browse() called for profile Samsung TV / player (C-series) with parameters: objectID = I_T#YEAR_2010, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 4096, sortCriteria =
2010-10-28 00:20:53,562 DEBUG [ImageDAOImpl] Retrieving list of creation date months for year 2010 (from=0, count=4096)
2010-10-28 00:20:53,609 DEBUG [ImageDAOImpl] Retrieving number of images for year 2010 and month 7
2010-10-28 00:20:53,625 DEBUG [ImageDAOImpl] Retrieving number of creation date months for year 2010
2010-10-28 00:20:53,625 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2010-10-28 00:20:53,640 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2010-10-28 00:20:53,640 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from WINDOWS, UPnP/1.0, Intel MicroStack/1.0.1497:
2010-10-28 00:20:53,640 DEBUG [ContentDirectory] Browse() called for profile Samsung TV / player (C-series) with parameters: objectID = V_F#FOL_R1, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 4096, sortCriteria =
2010-10-28 00:20:53,640 DEBUG [FolderDAOImpl] Getting number of sub-Folders in folder null
2010-10-28 00:20:53,640 DEBUG [VideoDAOImpl] Retrieving list of videos for folder 1 (from=0, count=4096)
2010-10-28 00:20:53,656 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 'root'
2010-10-28 00:20:53,671 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2010-10-28 00:20:53,671 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2010-10-28 00:20:53,671 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from WINDOWS, UPnP/1.0, Intel MicroStack/1.0.1497:
2010-10-28 00:20:53,671 DEBUG [ContentDirectory] Browse() called for profile Samsung TV / player (C-series) with parameters: objectID = I_T#YEAR_2010#MON_7, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 4096, sortCriteria =
2010-10-28 00:20:53,671 DEBUG [ImageDAOImpl] Retrieving list of images for year 2010 and month 7 (from=0, count=4096)
2010-10-28 00:20:53,703 DEBUG [FolderDAOImpl] Reading a Folder (id = 1)
2010-10-28 00:20:53,703 DEBUG [RepositoryDAOImpl] Reading a Repository (id = 1)
2010-10-28 00:20:53,703 DEBUG [ImageDAOImpl] Reading an Image (id = 1)
2010-10-28 00:20:53,703 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 1 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,703 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1073.jpg
2010-10-28 00:20:53,703 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 1)
patillaldi
Post Wed Oct 27, 2010 10:26 pm
Re: samsung le32c650 not find serviio
More log
2010-10-28 00:20:53,703 DEBUG [ImageDAOImpl] Reading an Image (id = 2)
2010-10-28 00:20:53,703 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 2 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,703 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1074.jpg
2010-10-28 00:20:53,703 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 2)
2010-10-28 00:20:53,703 DEBUG [ImageDAOImpl] Reading an Image (id = 3)
2010-10-28 00:20:53,703 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 3 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,703 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1075.jpg
2010-10-28 00:20:53,703 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 3)
2010-10-28 00:20:53,718 DEBUG [ImageDAOImpl] Reading an Image (id = 4)
2010-10-28 00:20:53,718 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 4 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,718 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1076.jpg
2010-10-28 00:20:53,718 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 4)
2010-10-28 00:20:53,718 DEBUG [FolderDAOImpl] Reading a Folder (id = 1)
2010-10-28 00:20:53,718 DEBUG [RepositoryDAOImpl] Reading a Repository (id = 1)
2010-10-28 00:20:53,718 DEBUG [ImageDAOImpl] Reading an Image (id = 5)
2010-10-28 00:20:53,718 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 5 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,718 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1077.jpg
2010-10-28 00:20:53,718 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 5)
2010-10-28 00:20:53,718 DEBUG [ImageDAOImpl] Reading an Image (id = 6)
2010-10-28 00:20:53,718 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 6 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,718 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1078.jpg
2010-10-28 00:20:53,718 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 6)
2010-10-28 00:20:53,718 DEBUG [ImageDAOImpl] Reading an Image (id = 7)
2010-10-28 00:20:53,718 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 7 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,718 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1079.jpg
2010-10-28 00:20:53,718 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 7)
2010-10-28 00:20:53,734 DEBUG [RepositoryDAOImpl] Reading a Repository (id = 1)
2010-10-28 00:20:53,734 DEBUG [ImageDAOImpl] Reading an Image (id = 8)
2010-10-28 00:20:53,734 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 8 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,734 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1080.jpg
2010-10-28 00:20:53,734 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 8)
2010-10-28 00:20:53,734 DEBUG [FolderDAOImpl] Reading a Folder (id = 1)
2010-10-28 00:20:53,734 DEBUG [ImageDAOImpl] Reading an Image (id = 9)
2010-10-28 00:20:53,734 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 9 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,734 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1081.jpg
2010-10-28 00:20:53,734 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 9)
2010-10-28 00:20:53,734 DEBUG [ImageDAOImpl] Reading an Image (id = 10)
2010-10-28 00:20:53,734 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 10 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,734 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1082.jpg
2010-10-28 00:20:53,734 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 10)
2010-10-28 00:20:53,734 DEBUG [ImageDAOImpl] Reading an Image (id = 11)
2010-10-28 00:20:53,734 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 11 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,734 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1085.jpg
2010-10-28 00:20:53,734 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 11)
2010-10-28 00:20:53,750 DEBUG [ImageDAOImpl] Reading an Image (id = 12)
2010-10-28 00:20:53,750 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 12 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,750 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1086.jpg
2010-10-28 00:20:53,750 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 12)
2010-10-28 00:20:53,750 DEBUG [FolderDAOImpl] Reading a Folder (id = 1)
2010-10-28 00:20:53,750 DEBUG [RepositoryDAOImpl] Reading a Repository (id = 1)
2010-10-28 00:20:53,750 DEBUG [ImageDAOImpl] Reading an Image (id = 13)
2010-10-28 00:20:53,750 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 13 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,750 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1087.jpg
2010-10-28 00:20:53,750 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 13)
2010-10-28 00:20:53,750 DEBUG [ImageDAOImpl] Reading an Image (id = 14)
2010-10-28 00:20:53,750 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 14 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,750 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1088.jpg
2010-10-28 00:20:53,750 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 14)
2010-10-28 00:20:53,750 DEBUG [ImageDAOImpl] Reading an Image (id = 15)
2010-10-28 00:20:53,750 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 15 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,750 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1089.jpg
2010-10-28 00:20:53,750 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 15)
2010-10-28 00:20:53,750 DEBUG [ImageDAOImpl] Reading an Image (id = 16)
2010-10-28 00:20:53,750 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 16 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,750 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1090.jpg
2010-10-28 00:20:53,750 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 16)
2010-10-28 00:20:53,765 DEBUG [FolderDAOImpl] Reading a Folder (id = 1)
2010-10-28 00:20:53,765 DEBUG [RepositoryDAOImpl] Reading a Repository (id = 1)
2010-10-28 00:20:53,765 DEBUG [ImageDAOImpl] Reading an Image (id = 17)
2010-10-28 00:20:53,765 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 17 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,765 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1091.jpg
2010-10-28 00:20:53,765 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 17)
2010-10-28 00:20:53,765 DEBUG [ImageDAOImpl] Reading an Image (id = 18)
2010-10-28 00:20:53,765 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 18 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,765 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1092.jpg
2010-10-28 00:20:53,765 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 18)
2010-10-28 00:20:53,765 DEBUG [ImageDAOImpl] Reading an Image (id = 19)
2010-10-28 00:20:53,765 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 19 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,765 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1093.jpg
2010-10-28 00:20:53,765 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 19)
2010-10-28 00:20:53,765 DEBUG [ImageDAOImpl] Reading an Image (id = 20)
2010-10-28 00:20:53,765 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 20 and profile Samsung TV / player (C-series)
2010-10-28 00:20:53,765 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file IMG_1094.jpg
2010-10-28 00:20:53,765 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 20)
2010-10-28 00:20:53,765 DEBUG [ImageDAOImpl] Retrieving number of images for year 2010 and month 7
2010-10-28 00:20:53,765 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2010-10-28 00:20:53,812 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2010-10-28 00:20:58,093 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2010-10-28 00:20:58,093 DEBUG [RepositoryDAOImpl] Reading all Repositories
2010-10-28 00:20:58,093 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2010-10-28 00:20:58,093 DEBUG [LibraryUpdatesCheckerThread] Looking for removed/updated files in repository: C:\Documents and Settings\monica\Escritorio\fotos
2010-10-28 00:20:58,093 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: C:\Documents and Settings\monica\Escritorio\fotos
2010-10-28 00:20:58,093 DEBUG [MediaItemDAOImpl] Reading MediaItems for Repository (id = 1)
2010-10-28 00:20:58,156 DEBUG [LibraryAdditionsCheckerThread] Found file 'IMG_1073.jpg', checking if it's already in the Library
2010-10-28 00:20:58,156 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item IMG_1073.jpg
2010-10-28 00:20:58,171 DEBUG [MediaItemDAOImpl] Media item IMG_1073.jpg already exists in DB
2010-10-28 00:20:58,203 DEBUG [LibraryAdditionsCheckerThread] Found file 'IMG_1074.jpg', checking if it's already in the Library
2010-10-28 00:20:58,203 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item IMG_1074.jpg
2010-10-28 00:20:58,203 DEBUG [MediaItemDAOImpl] Media item IMG_1074.jpg already exists in DB
2010-10-28 00:20:58,234 DEBUG [MediaItemDAOImpl] Getting file of media item 20
2010-10-28 00:20:58,250 DEBUG [LibraryAdditionsCheckerThread] Found file 'IMG_1075.jpg', checking if it's already in the Library
2010-10-28 00:20:58,250 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item IMG_1075.jpg
2010-10-28 00:20:58,250 DEBUG [MediaItemDAOImpl] Media item IMG_1075.jpg already exists in DB
2010-10-28 00:20:58,296 DEBUG [LibraryAdditionsCheckerThread] Found file 'IMG_1076.jpg', checking if it's already in the Library
2010-10-28 00:20:58,296 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item IMG_1076.jpg
2010-10-28 00:20:58,296 DEBUG [MediaItemDAOImpl] Media item IMG_1076.jpg already exists in DB
2010-10-28 00:20:58,312 DEBUG [LibraryAdditionsCheckerThread] Found file 'IMG_1077.jpg', checking if it's already in the Library
2010-10-28 00:20:58,312 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item IMG_1077.jpg
2010-10-28 00:20:58,328 DEBUG [MediaItemDAOImpl] Media item IMG_1077.jpg already exists in DB
2010-10-28 00:20:58,328 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type AUDIO
2010-10-28 00:20:58,328 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type VIDEO
2010-10-28 00:20:58,343 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type IMAGE
2010-10-28 00:20:58,343 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 20) and extractor EMBEDDED
2010-10-28 00:20:58,343 DEBUG [LibraryAdditionsCheckerThread] Found file 'IMG_1078.jpg', checking if it's already in the Library
2010-10-28 00:20:58,343 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item IMG_1078.jpg
2010-10-28 00:20:58,390 DEBUG [MediaItemDAOImpl] Media item IMG_1078.jpg already exists in DB
2010-10-28 00:20:58,421 DEBUG [LibraryAdditionsCheckerThread] Found file 'IMG_1079.jpg', checking if it's already in the Library
2010-10-28 00:20:58,421 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item IMG_1079.jpg
2010-10-28 00:20:58,593 DEBUG [MediaItemDAOImpl] Media item IMG_1079.jpg already exists in DB
2010-10-28 00:20:58,640 DEBUG [LibraryAdditionsCheckerThread] Found file 'IMG_1080.jpg', checking if it's already in the Library
2010-10-28 00:20:58,640 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item IMG_1080.jpg
2010-10-28 00:20:58,656 DEBUG [MediaItemDAOImpl] Media item IMG_1080.jpg already exists in DB
2010-10-28 00:20:58,671 DEBUG [LibraryAdditionsCheckerThread] Found file 'IMG_1081.jpg', checking if it's already in the Library
2010-10-28 00:20:58,671 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item IMG_1081.jpg
2010-10-28 00:20:58,718 DEBUG [MediaItemDAOImpl] Media item IMG_1081.jpg already exists in DB
2010-10-28 00:20:58,734 DEBUG [LibraryAdditionsCheckerThread] Found file 'IMG_1082.jpg', checking if it's already in the Library
2010-10-28 00:20:58,734 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item IMG_1082.jpg
2010-10-28 00:20:58,750 DEBUG [MediaItemDAOImpl] Media item IMG_1082.jpg already exists in DB
2010-10-28 00:20:58,781 DEBUG [LibraryAdditionsCheckerThread] Found file 'IMG_1085.jpg', checking if it's already in the Library
2010-10-28 00:20:58,781 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item IMG_1085.jpg
2010-10-28 00:20:58,781 DEBUG [MediaItemDAOImpl] Media item IMG_1085.jpg already exists in DB
2010-10-28 00:20:58,796 DEBUG [LibraryAdditionsCheckerThread] Found file 'IMG_1086.jpg', checking if it's already in the Library
2010-10-28 00:20:58,796 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item IMG_1086.jpg
2010-10-28 00:20:58,812 DEBUG [MediaItemDAOImpl] Media item IMG_1086.jpg already exists in DB
2010-10-28 00:20:58,828 DEBUG [MediaItemDAOImpl] Getting file of media item 1
2010-10-28 00:20:58,828 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1) and extractor EMBEDDED
2010-10-28 00:20:58,828 DEBUG [LibraryAdditionsCheckerThread] Found file 'IMG_1087.jpg', checking if it's already in the Library
2010-10-28 00:20:58,828 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item IMG_1087.jpg
2010-10-28 00:20:58,828 DEBUG [MediaItemDAOImpl] Media item IMG_1087.jpg already exists in DB
2010-10-28 00:20:58,859 DEBUG [LibraryAdditionsCheckerThread] Found file 'IMG_1088.jpg', checking if it's already in the Library
2010-10-28 00:20:58,859 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item IMG_1088.jpg
2010-10-28 00:20:58,859 DEBUG [MediaItemDAOImpl] Media item IMG_1088.jpg already exists in DB
2010-10-28 00:20:58,906 DEBUG [LibraryAdditionsCheckerThread] Found file 'IMG_1089.jpg', checking if it's already in the Library
2010-10-28 00:20:58,906 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item IMG_1089.jpg
2010-10-28 00:20:58,921 DEBUG [MediaItemDAOImpl] Media item IMG_1089.jpg already exists in DB
2010-10-28 00:20:58,921 DEBUG [MediaItemDAOImpl] Getting file of media item 2
2010-10-28 00:20:58,921 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 2) and extractor EMBEDDED
2010-10-28 00:20:58,953 DEBUG [LibraryAdditionsCheckerThread] Found file 'IMG_1090.jpg', checking if it's already in the Library
2010-10-28 00:20:58,953 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item IMG_1090.jpg
2010-10-28 00:20:58,953 DEBUG [MediaItemDAOImpl] Media item IMG_1090.jpg already exists in DB
2010-10-28 00:20:59,000 DEBUG [LibraryAdditionsCheckerThread] Found file 'IMG_1091.jpg', checking if it's already in the Library
2010-10-28 00:20:59,000 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item IMG_1091.jpg
2010-10-28 00:20:59,000 DEBUG [MediaItemDAOImpl] Media item IMG_1091.jpg already exists in DB
2010-10-28 00:20:59,031 DEBUG [MediaItemDAOImpl] Getting file of media item 3
2010-10-28 00:20:59,031 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3) and extractor EMBEDDED
2010-10-28 00:20:59,046 DEBUG [LibraryAdditionsCheckerThread] Found file 'IMG_1092.jpg', checking if it's already in the Library
2010-10-28 00:20:59,046 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item IMG_1092.jpg
2010-10-28 00:20:59,046 DEBUG [MediaItemDAOImpl] Media item IMG_1092.jpg already exists in DB
2010-10-28 00:20:59,062 DEBUG [LibraryAdditionsCheckerThread] Found file 'IMG_1093.jpg', checking if it's already in the Library
2010-10-28 00:20:59,062 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item IMG_1093.jpg
2010-10-28 00:20:59,062 DEBUG [MediaItemDAOImpl] Media item IMG_1093.jpg already exists in DB
2010-10-28 00:20:59,078 DEBUG [LibraryAdditionsCheckerThread] Found file 'IMG_1094.jpg', checking if it's already in the Library
2010-10-28 00:20:59,078 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item IMG_1094.jpg
2010-10-28 00:20:59,093 DEBUG [MediaItemDAOImpl] Media item IMG_1094.jpg already exists in DB
2010-10-28 00:20:59,125 DEBUG [MediaItemDAOImpl] Getting file of media item 4
2010-10-28 00:20:59,125 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 4) and extractor EMBEDDED
2010-10-28 00:20:59,234 DEBUG [MediaItemDAOImpl] Getting file of media item 5
2010-10-28 00:20:59,234 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 5) and extractor EMBEDDED
2010-10-28 00:20:59,343 DEBUG [MediaItemDAOImpl] Getting file of media item 6
2010-10-28 00:20:59,343 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 6) and extractor EMBEDDED
2010-10-28 00:20:59,437 DEBUG [MediaItemDAOImpl] Getting file of media item 7
2010-10-28 00:20:59,437 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 7) and extractor EMBEDDED
2010-10-28 00:20:59,546 DEBUG [MediaItemDAOImpl] Getting file of media item 8
2010-10-28 00:20:59,546 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 8) and extractor EMBEDDED
2010-10-28 00:20:59,640 DEBUG [MediaItemDAOImpl] Getting file of media item 9
2010-10-28 00:20:59,656 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 9) and extractor EMBEDDED
2010-10-28 00:20:59,750 DEBUG [MediaItemDAOImpl] Getting file of media item 10
2010-10-28 00:20:59,750 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 10) and extractor EMBEDDED
2010-10-28 00:20:59,859 DEBUG [MediaItemDAOImpl] Getting file of media item 11
2010-10-28 00:20:59,859 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 11) and extractor EMBEDDED
2010-10-28 00:20:59,953 DEBUG [MediaItemDAOImpl] Getting file of media item 12
2010-10-28 00:20:59,953 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 12) and extractor EMBEDDED
2010-10-28 00:21:00,062 DEBUG [MediaItemDAOImpl] Getting file of media item 13
2010-10-28 00:21:00,062 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 13) and extractor EMBEDDED
2010-10-28 00:21:00,171 DEBUG [MediaItemDAOImpl] Getting file of media item 14
2010-10-28 00:21:00,171 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 14) and extractor EMBEDDED
2010-10-28 00:21:00,265 DEBUG [MediaItemDAOImpl] Getting file of media item 15
2010-10-28 00:21:00,265 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 15) and extractor EMBEDDED
2010-10-28 00:21:00,375 DEBUG [MediaItemDAOImpl] Getting file of media item 16
2010-10-28 00:21:00,375 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 16) and extractor EMBEDDED
2010-10-28 00:21:00,468 DEBUG [MediaItemDAOImpl] Getting file of media item 17
2010-10-28 00:21:00,468 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 17) and extractor EMBEDDED
2010-10-28 00:21:00,578 DEBUG [MediaItemDAOImpl] Getting file of media item 18
2010-10-28 00:21:00,578 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 18) and extractor EMBEDDED
2010-10-28 00:21:00,671 DEBUG [MediaItemDAOImpl] Getting file of media item 19
2010-10-28 00:21:00,687 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 19) and extractor EMBEDDED
2010-10-28 00:21:00,687 DEBUG [LibraryUpdatesCheckerThread] Updating dirty metadata
2010-10-28 00:21:00,687 DEBUG [MediaItemDAOImpl] Reading dirty MediaItems for Repository (id = 1)
patillaldi
Post Wed Oct 27, 2010 10:27 pm
2010-10-28 00:22:10,203 DEBUG [WebServer] Incoming connection from /192.168.0.14:57849
2010-10-28 00:22:10,203 DEBUG [ServiceEventSubscriptionRequestHandler] ServiceEvent renewal request received for service ContentDirectory and subscription uuid:ae9b89db-56e0-4323-b3f5-31add5d90adc
2010-10-28 00:22:10,203 DEBUG [ServiceEventSubscriptionRequestHandler] Event subscription renewed for service urn:upnp-org:serviceId:ContentDirectory and subscription ae9b89db-56e0-4323-b3f5-31add5d90adc
2010-10-28 00:22:35,390 DEBUG [WebServer] Incoming connection from /192.168.0.14:1045
2010-10-28 00:22:35,406 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.0.14:53954
2010-10-28 00:22:35,406 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s)
2010-10-28 00:22:37,015 DEBUG [WebServer] Incoming connection from /192.168.0.14:57924
2010-10-28 00:22:37,015 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 33a806e5-df8a-3086-bdee-a45ec476debd from WINDOWS, UPnP/1.0, Intel MicroStack/1.0.1497
2010-10-28 00:22:37,015 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Samsung TV / player (C-series)'
2010-10-28 00:22:37,015 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2010-10-28 00:22:37,015 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2010-10-28 00:22:37,015 DEBUG [ServiceEventSubscriptionRequestHandler] ServiceEvent subscription request received for service ContentDirectory
2010-10-28 00:22:37,015 DEBUG [ServiceEventSubscriptionRequestHandler] Event subscription registered (uuid=c47dfb91-62f8-4d12-bb91-02ddde717259) for service urn:upnp-org:serviceId:ContentDirectory reporting to http://192.168.0.14:57641/serviceEventi ... tDirectory
2010-10-28 00:22:37,265 DEBUG [EventDispatcher] Sending event notification #0 for subscription c47dfb91-62f8-4d12-bb91-02ddde717259 to endpoint http://192.168.0.14:57641/serviceEventi ... tDirectory
2010-10-28 00:22:37,265 DEBUG [RequestExecutor] Sending HTTP request to 192.168.0.14:57641
2010-10-28 00:22:37,265 DEBUG [EventDispatcher] Event notification sent and received successfully
2010-10-28 00:22:37,265 DEBUG [EventDispatcher] Sending event notification #1 for subscription ae9b89db-56e0-4323-b3f5-31add5d90adc to endpoint http://192.168.0.14:57046/serviceEventi ... tDirectory
2010-10-28 00:22:37,265 DEBUG [RequestExecutor] Sending HTTP request to 192.168.0.14:57046
2010-10-28 00:22:38,234 WARN [EventDispatcher] Couldn't send event message for subscription ae9b89db-56e0-4323-b3f5-31add5d90adc, will keep trying until subscription expires
2010-10-28 00:24:07,031 DEBUG [WebServer] Incoming connection from /192.168.0.14:61460
2010-10-28 00:24:07,031 DEBUG [ServiceEventSubscriptionRequestHandler] ServiceEvent renewal request received for service ContentDirectory and subscription uuid:c47dfb91-62f8-4d12-bb91-02ddde717259
2010-10-28 00:24:07,031 DEBUG [ServiceEventSubscriptionRequestHandler] Event subscription renewed for service urn:upnp-org:serviceId:ContentDirectory and subscription c47dfb91-62f8-4d12-bb91-02ddde717259
2010-10-28 00:25:10,218 DEBUG [EventSubscriptionExpirationChecker] Removed expired subscription ae9b89db-56e0-4323-b3f5-31add5d90adc from service urn:upnp-org:serviceId:ContentDirectory
2010-10-28 00:25:12,218 DEBUG [EventSubscriptionExpirationChecker] Removed expired subscription ae9b89db-56e0-4323-b3f5-31add5d90adc from service urn:upnp-org:serviceId:ContentDirectory
2010-10-28 00:25:14,218 DEBUG [EventSubscriptionExpirationChecker] Removed expired subscription ae9b89db-56e0-4323-b3f5-31add5d90adc from service urn:upnp-org:serviceId:ContentDirectory
2010-10-28 00:25:16,218 DEBUG [EventSubscriptionExpirationChecker] Removed expired subscription ae9b89db-56e0-4323-b3f5-31add5d90adc from service urn:upnp-org:serviceId:ContentDirectory
2010-10-28 00:25:18,218 DEBUG [EventSubscriptionExpirationChecker] Removed expired subscription ae9b89db-56e0-4323-b3f5-31add5d90adc from service urn:upnp-org:serviceId:ContentDirectory
2010-10-28 00:25:20,218 DEBUG [EventSubscriptionExpirationChecker] Removed expired subscription ae9b89db-56e0-4323-b3f5-31add5d90adc from service urn:upnp-org:serviceId:ContentDirectory
2010-10-28 00:25:22,218 DEBUG [EventSubscriptionExpirationChecker] Removed expired subscription ae9b89db-56e0-4323-b3f5-31add5d90adc from service urn:upnp-org:serviceId:ContentDirectory
2010-10-28 00:25:24,218 DEBUG [EventSubscriptionExpirationChecker] Removed expired subscription ae9b89db-56e0-4323-b3f5-31add5d90adc from service urn:upnp-org:serviceId:ContentDirectory
2010-10-28 00:25:26,218 DEBUG [EventSubscriptionExpirationChecker] Removed expired subscription ae9b89db-56e0-4323-b3f5-31add5d90adc from service urn:upnp-org:serviceId:ContentDirectory
2010-10-28 00:25:28,218 DEBUG [EventSubscriptionExpirationChecker] Removed expired subscription ae9b89db-56e0-4323-b3f5-31add5d90adc from service urn:upnp-org:serviceId:ContentDirectory
2010-10-28 00:25:30,218 DEBUG [EventSubscriptionExpirationChecker] Removed expired subscription ae9b89db-56e0-4323-b3f5-31add5d90adc from service urn:upnp-org:serviceId:ContentDirectory
2010-10-28 00:25:32,218 DEBUG [EventSubscriptionExpirationChecker] Removed expired subscription ae9b89db-56e0-4323-b3f5-31add5d90adc from service urn:upnp-org:serviceId:ContentDirectory
2010-10-28 00:25:34,953 DEBUG [EventSubscriptionExpirationChecker] Removed expired subscription ae9b89db-56e0-4323-b3f5-31add5d90adc from service urn:upnp-org:serviceId:ContentDirectory
2010-10-28 00:25:36,953 DEBUG [EventSubscriptionExpirationChecker] Removed expired subscription ae9b89db-56e0-4323-b3f5-31add5d90adc from service urn:upnp-org:serviceId:ContentDirectory
2010-10-28 00:25:36,968 DEBUG [WebServer] Incoming connection from /192.168.0.14:1075
2010-10-28 00:25:36,984 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.0.14:51104
2010-10-28 00:25:36,984 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s)
2010-10-28 00:25:37,640 DEBUG [WebServer] Incoming connection from /192.168.0.14:50075
2010-10-28 00:25:37,640 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 33a806e5-df8a-3086-bdee-a45ec476debd from WINDOWS, UPnP/1.0, Intel MicroStack/1.0.1497
2010-10-28 00:25:37,640 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Samsung TV / player (C-series)'
2010-10-28 00:25:37,640 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2010-10-28 00:25:37,640 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2010-10-28 00:25:37,656 DEBUG [ServiceEventSubscriptionRequestHandler] ServiceEvent subscription request received for service ContentDirectory
2010-10-28 00:25:37,656 DEBUG [ServiceEventSubscriptionRequestHandler] Event subscription registered (uuid=11da8ee0-a557-4aec-b373-1eb13dd91712) for service urn:upnp-org:serviceId:ContentDirectory reporting to http://192.168.0.14:58232/serviceEventi ... tDirectory
2010-10-28 00:25:37,968 DEBUG [EventDispatcher] Sending event notification #0 for subscription 11da8ee0-a557-4aec-b373-1eb13dd91712 to endpoint http://192.168.0.14:58232/serviceEventi ... tDirectory
2010-10-28 00:25:37,968 DEBUG [RequestExecutor] Sending HTTP request to 192.168.0.14:58232
2010-10-28 00:25:38,000 DEBUG [EventDispatcher] Event notification sent and received successfully
2010-10-28 00:25:38,000 DEBUG [EventDispatcher] Sending event notification #1 for subscription c47dfb91-62f8-4d12-bb91-02ddde717259 to endpoint http://192.168.0.14:57641/serviceEventi ... tDirectory
2010-10-28 00:25:38,000 DEBUG [RequestExecutor] Sending HTTP request to 192.168.0.14:57641
2010-10-28 00:25:38,953 DEBUG [EventSubscriptionExpirationChecker] Removed expired subscription ae9b89db-56e0-4323-b3f5-31add5d90adc from service urn:upnp-org:serviceId:ContentDirectory
2010-10-28 00:25:38,984 WARN [EventDispatcher] Couldn't send event message for subscription c47dfb91-62f8-4d12-bb91-02ddde717259, will keep trying until subscription expires
2010-10-28 00:25:38,984 DEBUG [EventDispatcher] Sending event notification #1 for subscription ae9b89db-56e0-4323-b3f5-31add5d90adc to endpoint http://192.168.0.14:57046/serviceEventi ... tDirectory
2010-10-28 00:25:38,984 DEBUG [RequestExecutor] Sending HTTP request to 192.168.0.14:57046
2010-10-28 00:25:40,000 WARN [EventDispatcher] Couldn't send event message for subscription ae9b89db-56e0-4323-b3f5-31add5d90adc, will keep trying until subscription expires
2010-10-28 00:25:40,953 DEBUG [EventSubscriptionExpirationChecker] Removed expired subscription ae9b89db-56e0-4323-b3f5-31add5d90adc from service urn:upnp-org:serviceId:ContentDirectory
2010-10-28 00:25:42,953 DEBUG [EventSubscriptionExpirationChecker] Removed expired subscription ae9b89db-56e0-4323-b3f5-31add5d90adc from service urn:upnp-org:serviceId:ContentDirectory
2010-10-28 00:25:44,953 DEBUG [EventSubscriptionExpirationChecker] Removed expired subscription ae9b89db-56e0-4323-b3f5-31add5d90adc from service urn:upnp-org:serviceId:ContentDirectory
2010-10-28 00:25:46,953 DEBUG [EventSubscriptionExpirationChecker] Removed expired subscription ae9b89db-56e0-4323-b3f5-31add5d90adc from service urn:upnp-org:serviceId:ContentDirectory
2010-10-28 00:25:48,953 DEBUG [EventSubscriptionExpirationChecker] Removed expired subscription ae9b89db-56e0-4323-b3f5-31add5d90adc from service urn:upnp-org:serviceId:ContentDirectory
2010-10-28 00:25:50,953 DEBUG [EventSubscriptionExpirationChecker] Removed expired subscription ae9b89db-56e0-4323-b3f5-31add5d90adc from service urn:upnp-org:serviceId:ContentDirectory
2010-10-28 00:25:52,953 DEBUG [EventSubscriptionExpirationChecker] Removed expired subscription ae9b89db-56e0-4323-b3f5-31add5d90adc from service urn:upnp-org:serviceId:ContentDirectory
2010-10-28 00:25:54,953 DEBUG [EventSubscriptionExpirationChecker] Removed expired subscription ae9b89db-56e0-4323-b3f5-31add5d90adc from service urn:upnp-org:serviceId:ContentDirectory
2010-10-28 00:25:56,953 DEBUG [EventSubscriptionExpirationChecker] Removed expired subscription ae9b89db-56e0-4323-b3f5-31add5d90adc from service urn:upnp-org:serviceId:ContentDirectory
2010-10-28 00:25:58,953 DEBUG [EventSubscriptionExpirationChecker] Removed expired subscription ae9b89db-56e0-4323-b3f5-31add5d90adc from service urn:upnp-org:serviceId:ContentDirectory
patillaldi
Post Wed Oct 27, 2010 10:39 pm
I download Upnp developer tools s instructed by the post "HOWTO: Provide supported formats of a device", but in field Sink appears empty.
Captured Image
Upnp developer tools.JPG (58.53 KiB) Viewed 24464 times
Post Wed Oct 27, 2010 11:23 pm
There is no activity coming from the TV's IP address. So either the advertisement didn't reach it or the TV cannot access the PC. Make sure UDP 1900 is open on the PC/router and TCP 8895 is open on the PC. I know you said there is no firewall but double check please.
patillaldi
Post Thu Oct 28, 2010 6:08 am
Router configuration. If i telnet from other pc to serviio pc
telnet 192.168.0.14 8895 --> works
Post Thu Oct 28, 2010 7:35 am
patillaldi wrote:I download Upnp developer tools s instructed by the post "HOWTO: Provide supported formats of a device", but in field Sink appears empty....
On "Device Spy" left windows you will find list of all dlna devices on your local network. Serviio, Samsung TV,etc.
On your capture, you select Serviio GetProtocolInfo, but we need your Samsung TV GetProtocolInfo.
It seems that your TV is not seeing on you local network (check connection, open port, firewall, IP adress configuration on devices, etc...)
Post Thu Oct 28, 2010 7:44 am
patillaldi wrote:Router configuration....telnet 192.168.0.14 8895 --> works
Suggestion:
Set a different fixed IP address for all your devices: 192.168.0.20 (TV), 192.168.0.14 (PC) OK
What is the IP address of your Router (may be different to your PC or devices)?
On all devices, set DNS Server IP with IP router address.
patillaldi
Post Thu Oct 28, 2010 1:32 pm
On "Device Spy" left windows i not find samsung tv. I try add manually with uri http://192.168.0.11, but not works. My TV is not seeing on you local network, but i don´t know what causes.
I change fixed IP for TV and PC. Now, IP´s PC (192.168.0.12) and Ip´s TV (192.168.0.11). IP´s Router (192.168.0.1). DNS Server IP from PC and TV is 192.168.0.1.
TV is connected through PLC with cable network. PLC is connected to router through cable network. PC is connected to router through cable usb.
TV still does not see the computer
Post Thu Oct 28, 2010 1:49 pm
what is PLC? is it not blocking network traffic?
patillaldi
Post Thu Oct 28, 2010 2:14 pm
PLC technology can use the household electrical wiring as a transmission of signals. The HomePlug and HomePlug AV technology, are the two most popular de facto standards used in the home, without installing additional wiring.
http://en.wikipedia.org/wiki/Power_line_communication
http://www.tp-link.com/products/productDetails.asp?class=pl&pmodel=TL-PA201
Post Thu Oct 28, 2010 2:17 pm
patillaldi wrote:I change fixed IP for TV and PC. Now, IP´s PC (192.168.0.12) and Ip´s TV (192.168.0.11). IP´s Router (192.168.0.1). DNS Server IP from PC and TV is 192.168.0.1
Well
patillaldi wrote:TV is connected through PLC with cable network. PLC is connected to router through cable network. PC is connected to router through cable usb.
Could you connect PC to router with cable network?
Post Thu Oct 28, 2010 2:19 pm
patillaldi wrote:PLC technology can use the household electrical wiring as a transmission of signals.
No problem with PLC, it's plug&play, I think the problem is your USB connection to your router.
Post Thu Oct 28, 2010 2:22 pm
ah ok, I have the same at home ;-) not going throught the PLC though, I have a switch between the TV and my server when my media is stored so that I have gigabit network in place.
I assume you can ping the TV from your PC? is your Windows firewall turned off?
patillaldi
Post Thu Oct 28, 2010 2:25 pm
after work, I'll try to install the server on a laptop that connects via wifi to the router. If it works, the problem is the USB cable connection.
After I tell you the result.
Post Thu Oct 28, 2010 2:34 pm
What is your router? How many cable connection does it provide?
If only one Ethernet Cable connection, I suggest you to buy a Switch (D-Link DES-1008D for example), with Router / PC / PLC connected. (Bye Bye USB)
Return to User experiences
