Ask help: Failed to open bitstream filter h264_mp4toannexb
jingleserviio
Post Sat Nov 21, 2015 4:51 am
I installed ffmpeg-2.8.2 on Mac and run in command line:
ffmpeg -i firstTake.mp4 -vcodec copy -acodec copy -vbsf h264_mp4toannexb firstTake.ts
and get the following result with some errors. For each time running, the error "Failed to open bitstream filter h264_mp4toannexb for stream 0 with codec copy: Invalid argument" happens at different time points. And if I trim the original 18 minute video to 15 minutes, it works. I'm new in this area. Can anyone shed some light on my problem? Thanks!
ffmpeg version 2.8.2 Copyright (c) 2000-2015 the FFmpeg developers
built with Apple LLVM version 6.1.0 (clang-602.0.53) (based on LLVM 3.6.0svn)
configuration: --enable-libmp3lame --enable-shared --disable-mmx --arch=x86_64
libavutil 54. 31.100 / 54. 31.100
libavcodec 56. 60.100 / 56. 60.100
libavformat 56. 40.101 / 56. 40.101
libavdevice 56. 4.100 / 56. 4.100
libavfilter 5. 40.101 / 5. 40.101
libswscale 3. 1.101 / 3. 1.101
libswresample 1. 2.101 / 1. 2.101
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'firstTake.mp4':
major_brand : isom
minor_version : 512
compatible_brands: isomiso2avc1mp41
encoder : Lavf56.26.101
Duration: 00:18:31.61, start: 0.000000, bitrate: 15072 kb/s
Stream #0:0(und): Video: h264 (Main) (avc1 / 0x31637661), yuv420p, 2048x1024, 15001 kb/s, 59.38 fps, 59.94 tbr, 60k tbn, 119.88 tbc (default)
handler_name : VideoHandler
Stream #0:1(und): Audio: mp3 (mp4a / 0x6134706D), 48000 Hz, stereo, s16p, 64 kb/s (default)
handler_name : SoundHandler
Output #0, mpegts, to 'firstTake.ts':
major_brand : isom
minor_version : 512
encoder : Lavf56.40.101
Stream #0:0(und): Video: h264 (avc1 / 0x31637661), yuv420p, 2048x1024, q=2-31, 15001 kb/s, 59.38 fps, 59.94 tbr, 90k tbn, 60k tbc (default)
Stream #0:1(und): Audio: mp3 (mp4a / 0x6134706D), 48000 Hz, stereo, 64 kb/s (default)
Stream mapping:
Stream #0:0 -> #0:0 (copy)
Stream #0:1 -> #0:1 (copy)
frame=12103 fps=0.0 q=-1.0 size= 419134kB time=00:03:21.91 bitrate=17005.1kbitsframe=24662 fps=24658 q=-1.0 size= 830573kB time=00:06:51.43 bitrate=16537.5kbiframe=36982 fps=24652 q=-1.0 size= 1243712kB time=00:10:16.99 bitrate=16513.2kbiframe=48449 fps=24223 q=-1.0 size= 1625058kB time=00:13:28.29 bitrate=16469.8kbiframe=60978 fps=24388 q=-1.0 size= 2042907kB time=00:16:57.31 bitrate=16450.7kbi
[mpegts @ 0x7f9034010000] H.264 bitstream error, startcode missing, size 0
frame=66013 fps=24374 q=-1.0 Lsize= 2212026kB time=00:18:31.59 bitrate=16301.7kbits/s
video:2035677kB audio:8602kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 8.205680%
Post Mon Nov 23, 2015 1:54 pm
Re: Ask help: Failed to open bitstream filter h264_mp4toanne
Probably ask at the FFmpeg mailing list.
