No Audio on DirecTV HD DVR HR20
BigDog
Post Wed Jan 26, 2011 12:42 am
I was able to get everything to work properly on my Sony BDP-S470.
But when trying it on my HR20, I am not getting any audio from my ripped DVDs. They are in 1 GB VOB files. The video looks great. I tried the AC3 to MP3 change in the config file and restarted the service. I also turned up the logging up to DEBUG, but that didn't show any issues in the log file. Here's what FFmpeg had to show for itself.
686-mingw32-
  libavutil     50.36. 0 / 50.36. 0
  libavcore      0.16. 0 /  0.16. 0
  libavcodec    52.108. 0 / 52.108. 0
  libavformat   52.92. 0 / 52.92. 0
  libavdevice   52. 2. 3 / 52. 2. 3
  libavfilter    1.72. 0 /  1.72. 0
  libswscale     0.12. 0 /  0.12. 0
[mpeg @ 015ec4b0] max_analyze_duration reached
Seems stream 0 codec frame rate differs from container frame rate: 59.94 (60000/
1001) -> 29.97 (60000/2002)
Input #0, mpeg, from 'VTS_01_1.VOB':
  Duration: 00:25:12.91, start: 115.148644, bitrate: 5677 kb/s
    Stream #0.0[0x1e0]: Video: mpeg2video, yuv420p, 720x480 [PAR 32:27 DAR 16:9]
, 9800 kb/s, 24.10 fps, 29.97 tbr, 90k tbn, 59.94 tbc
    Stream #0.1[0x80]: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
I'd say it is not the VOB file since it works on the Sony BDP. Any thoughts? Do you need any more info?
Thank you,
BD
BigDog
Post Mon Jan 31, 2011 11:47 am
Re: No Audio on DirecTV HD DVR HR20
Okay, can anyone confirm that they are using VOB's with an HR20 and are getting sound?
mediabob
Post Sat Feb 05, 2011 1:59 pm
I have an DTV HR23-700 and I have "no" audio on my copied DVDs also and I am running the .5 version of Serviio.
josh208
Post Thu Feb 10, 2011 9:51 pm
A number of people have found that change targetACodec to 'mp3' does not work, this was the case for me. However, 0.5 now supports target of 'mp2'. This works!
Gleaned this from: http://www.serviio.org/index.php?option ... icle&id=24
Sidenote: I also had to set downmix to stereo under video settings on the Transcoding Tab otherwise FFMPEG would croak claiming impossible bitrate (Before doing this, I would not even get video).
Post Thu Feb 10, 2011 9:52 pm
So can you post your final profile? I guess it could be included in the next release as the proper DirecTV profile...
josh208
Post Mon Mar 07, 2011 10:15 pm
I apologize for the slow reply, I haven't checked in in awhile. The full profile is...
<Profile id="6" name="DirecTV HD-DVR" extendsProfileId="1">
<Detection>
<HttpHeaders>
<User-Agent>.*DIRECTV.*</User-Agent>
</HttpHeaders>
</Detection>
<Video targetContainer="mpeg" targetVCodec="mpeg2video" targetACodec="mp2" maxVBitrate="8192">
<Matches container="mp4" />
<Matches container="asf" />
<Matches container="avi" />
josh208
Post Mon Mar 07, 2011 10:20 pm
Also, in order to retain AC3 audio when streaming to my Samsung Bluray player, I unchecked downmix and applied the following as a hack...
moved my ffmpeg binary to ffmpeg.bin and created the following script in place of ffmpeg. Basically this looks for usage of mp2 codec (-acodec mp2) and if that is set, it replaces the 'ac N' argument with 'ac 2' since 2 channel audio is the only thing that's appropriate for mp2.
#!/usr/bin/perl
my $args = join(' ',@ARGV);
if ($args =~ /-acodec mp2/) {
$args =~ s/ac \d/ac 2/;
exec "$0.bin $args";
Post Mon Mar 07, 2011 10:35 pm
thanks, there is an option on transcoding config to forceStereo, so you won't need the script anymore
josh208
Post Tue Mar 15, 2011 2:41 pm
Awesome. Thank you!
