how force mkv trascoding - Samsung C Profile
rodasa
Post Fri Mar 25, 2011 7:24 pm
Hi, how can i force the trascoding of MKV file. Actually when i try to play in my samsung get an error like "Video Codec not admited"The strange is that other mkv files play ok...¿?
I use de gspot to view de filetype and codecs and i found video/x.matroska ¿?
¿How can i force de trascoding of this file type?
Post Fri Mar 25, 2011 7:58 pm
Re: how force mkv trascoding - Samsung C Profile
in gansta.
What yas have ta do is give us da ffmpeg -i result of da file and we mite tells yas why it ant workin.
or in english
Can you post a ffmpeg -I result for the fiel that will not play, you can see my signiture for a howto if you are unsure how to do it.
Stardust
Post Fri Mar 25, 2011 10:19 pm
Are you using the newest Version of Seviio? I encountered the same problem somewhen before 0.51 and solved it by simply renaming the file to .avi... Now (with 0.51) it works without renaming.
But some mkv´s still need special attention and there is already a thread about it:
viewtopic.php?f=10&t=2052
Samsung UE37C5700, Server-PC: Mobile T5500 on Abit iL90MV (945GT chipset)
Post Fri Mar 25, 2011 10:55 pm
Serviio cares nothing about extensions, they are only useful for identifying files to scan.
Stardust
Post Fri Mar 25, 2011 10:58 pm
zip wrote:Serviio cares nothing about extensions, they are only useful for identifying files to scan.
hm... Okay, sorry. Maybe it was the Samsung media player that did not want my mkv´s named as such. I am not quite sure which program it was....
rodasa
Post Sat Mar 26, 2011 1:46 pm
Stardust wrote:Are you using the newest Version of Seviio? I encountered the same problem somewhen before 0.51 and solved it by simply renaming the file to .avi... Now (with 0.51) it works without renaming.
Yes i´m using the newest Version. I renamed the file to .avi, but the same, "Coded de video no admitido" :(
rodasa
Post Sat Mar 26, 2011 1:52 pm
Hi guys, thanks for your reply´s and sorry for my poor English, but I have been able to understand JAJAJA
This is the output of the file does not play
NOTE: This is the post for my problem? (viewtopic.php?f=10&t=2052) If so, that program had patanpatan detailed file information?
rodrigo@n3grixsrv:~$ ffmpeg -i /media/MediaStore/Peliculas/Accion/El\ Caballero\ Oscuro.mkv
FFmpeg version 0.6-4:0.6-2ubuntu6, Copyright (c) 2000-2010 the FFmpeg developers
built on Oct 5 2010 22:36:53 with gcc 4.4.5
configuration: --extra-version=4:0.6-2ubuntu6 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-vaapi --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-gpl --enable-postproc --enable-x11grab --enable-libdc1394 --enable-shared --disable-static
libavutil 50.15. 1 / 50.15. 1
libavcodec 52.72. 2 / 52.72. 2
libavformat 52.64. 2 / 52.64. 2
libavdevice 52. 2. 0 / 52. 2. 0
libavfilter 1.19. 0 / 1.19. 0
libswscale 0.11. 0 / 0.11. 0
[matroska @ 0x8f7420]Estimating duration from bitrate, this may be inaccurate
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (20000000/417083) -> 24.00 (24/1)
Input #0, matroska, from '/media/MediaStore/Peliculas/Accion/El Caballero Oscuro.mkv':
doctype : matroska
Duration: 02:32:13.24, start: 0.000000, bitrate: 640 kb/s
Stream #0.0(spa): Video: h264, yuv420p, 1920x1080, PAR 1:1 DAR 16:9, 23.98 fps, 24 tbr, 1k tbn, 47.95 tbc
Stream #0.1(spa): Audio: ac3, 48000 Hz, 5.1, s16, 640 kb/s
rodasa
Post Sat Mar 26, 2011 4:09 pm
Hello friends, thank you!
I solved the problem with the post http://forum.serviio.org/viewtopic.php?f=10&t=2052implementing Illico response, option 2, changing profile.
Using the tsMuxer I noticed that the movie was High@5.1 :D
Only thing now is that there are two services of ffmpeg that I consume all the CPU so the video on your screen freezes at times.
I hope this is temporary :o
