Samsung J-Series vs HEVC 10bits
Fernado
Post Wed Apr 25, 2018 2:06 am
Hi Everyone!
I just can't figure out why my Samsung TV doesn't receive my HEVC 10bit transcoded files. It works perfectly fine with 8bits files, so I assume that the problem must be related to the 10 bits ones.
Here's the ffmpeg -i of the file
ffmpeg version 3.4.2 Copyright (c) 2000-2018 the FFmpeg developers
  built with gcc 7.3.0 (GCC)
  configuration: --enable-gpl --enable-version3 --enable-sdl2 --enable-bzlib --enable-fontconfig --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libfreetype --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libtheora --enable-libtwolame --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxml2 --enable-libzimg --enable-lzma --enable-zlib --enable-gmp --enable-libvidstab --enable-libvorbis --enable-libvo-amrwbenc --enable-libmysofa --enable-libspeex --enable-libxvid --enable-libmfx --enable-cuda --enable-cuvid --enable-d3d11va --enable-nvenc --enable-dxva2 --enable-avisynth
  libavutil      55. 78.100 / 55. 78.100
  libavcodec     57.107.100 / 57.107.100
  libavformat    57. 83.100 / 57. 83.100
  libavdevice    57. 10.100 / 57. 10.100
  libavfilter     6.107.100 /  6.107.100
  libswscale      4.  8.100 /  4.  8.100
  libswresample   2.  9.100 /  2.  9.100
  libpostproc    54.  7.100 / 54.  7.100
[matroska,webm @ 00000172e48466c0] Could not find codec parameters for stream 3 (Subtitle: hdmv_pgs_subtitle (pgssub)): unspecified size
Consider increasing the value for the 'analyzeduration' and 'probesize' options
[matroska,webm @ 00000172e48466c0] Could not find codec parameters for stream 4 (Subtitle: hdmv_pgs_subtitle (pgssub)): unspecified size
[matroska,webm @ 00000172e48466c0] Could not find codec parameters for stream 5 (Subtitle: hdmv_pgs_subtitle (pgssub)): unspecified size
Input #0, matroska,webm, from 'a.mkv':
    encoder         : libebml v1.3.4 + libmatroska v1.4.5
    creation_time   : 2018-03-18T11:47:44.000000Z
    Writing frontend: StaxRip 1.5.0.0
  Duration: 00:57:22.79, start: 0.000000, bitrate: 3935 kb/s
    Chapter #0:0: start 0.000000, end 286.119000
      title           : Chapter 1
    Chapter #0:1: start 286.119000, end 630.088000
      title           : Chapter 2
    Chapter #0:2: start 630.088000, end 820.069000
      title           : Chapter 3
    Chapter #0:3: start 820.069000, end 969.969000
      title           : Chapter 4
    Chapter #0:4: start 969.969000, end 1363.445000
      title           : Chapter 5
    Chapter #0:5: start 1363.445000, end 2031.571000
      title           : Chapter 6
    Chapter #0:6: start 2031.571000, end 2280.695000
      title           : Chapter 7
    Chapter #0:7: start 2280.695000, end 2418.833000
      title           : Chapter 8
    Chapter #0:8: start 2418.833000, end 2887.968000
      title           : Chapter 9
    Chapter #0:9: start 2887.968000, end 3198.987000
      title           : Chapter 10
    Chapter #0:10: start 3198.987000, end 3349.429000
      title           : Chapter 11
    Chapter #0:11: start 3349.429000, end 3442.793000
      title           : Chapter 12
    Stream #0:0: Video: hevc (Main 10), yuv420p10le(tv), 1920x1080, SAR 1:1 DAR 16:9, 23.98 fps, 23.98 tbr, 1k tbn, 23.98 tbc (default)
      BPS             : 3456819
      BPS-eng         : 3456819
      DURATION        : 00:57:22.773000000
      DURATION-eng    : 00:57:22.773000000
      NUMBER_OF_FRAMES: 82544
      NUMBER_OF_FRAMES-eng: 82544
      NUMBER_OF_BYTES : 1487630647
      NUMBER_OF_BYTES-eng: 1487630647
      _STATISTICS_WRITING_APP: mkvmerge v9.6.0 ('Slave To Your Mind') 64bit
      _STATISTICS_WRITING_APP-eng: mkvmerge v9.6.0 ('Slave To Your Mind') 64bit
      _STATISTICS_WRITING_DATE_UTC: 2018-03-18 11:47:44
      _STATISTICS_WRITING_DATE_UTC-eng: 2018-03-18 11:47:44
      _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
      _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
    Stream #0:1(eng): Audio: aac (LC), 48000 Hz, 5.1, fltp (default)
      BPS             : 443949
      BPS-eng         : 443949
      NUMBER_OF_FRAMES: 161380
      NUMBER_OF_FRAMES-eng: 161380
      NUMBER_OF_BYTES : 191052361
      NUMBER_OF_BYTES-eng: 191052361
    Stream #0:2(eng): Subtitle: hdmv_pgs_subtitle, 1920x1080
      BPS             : 9900
      BPS-eng         : 9900
      DURATION        : 00:57:08.425000000
      DURATION-eng    : 00:57:08.425000000
      NUMBER_OF_FRAMES: 1498
      NUMBER_OF_FRAMES-eng: 1498
      NUMBER_OF_BYTES : 4242919
      NUMBER_OF_BYTES-eng: 4242919
    Stream #0:3(fre): Subtitle: hdmv_pgs_subtitle
      BPS             : 6984
      BPS-eng         : 6984
      DURATION        : 00:57:05.088000000
      DURATION-eng    : 00:57:05.088000000
      NUMBER_OF_FRAMES: 1150
      NUMBER_OF_FRAMES-eng: 1150
      NUMBER_OF_BYTES : 2990385
      NUMBER_OF_BYTES-eng: 2990385
    Stream #0:4(ger): Subtitle: hdmv_pgs_subtitle
      BPS             : 8256
      BPS-eng         : 8256
      DURATION        : 00:56:21.211000000
      DURATION-eng    : 00:56:21.211000000
      NUMBER_OF_FRAMES: 1258
      NUMBER_OF_FRAMES-eng: 1258
      NUMBER_OF_BYTES : 3489713
      NUMBER_OF_BYTES-eng: 3489713
    Stream #0:5(spa): Subtitle: hdmv_pgs_subtitle
      BPS             : 7814
      BPS-eng         : 7814
      DURATION        : 00:56:21.044000000
      DURATION-eng    : 00:56:21.044000000
      NUMBER_OF_FRAMES: 1278
      NUMBER_OF_FRAMES-eng: 1278
      NUMBER_OF_BYTES : 3302536
      NUMBER_OF_BYTES-eng: 3302536
And my debug log (At least part of it):
2018-04-24 22:43:45,240 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 417, format MPEG_TS_SD_EU_ISO and profile Samsung TV / player (J-series)
2018-04-24 22:43:45,240 DEBUG [AbstractAVTranscodingDeliveryEngine] Getting media info for transcoded version of file The Handmaid's Tale (2017) - S01E01 - Offred (1080p BluRay x265 Silence).mkv
2018-04-24 22:43:45,240 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "The Handmaid's Tale (2017) - S01E01 - Offred (1080p BluRay x265 Silence).mkv": MPEG_TS_SD_EU_ISO
2018-04-24 22:43:45,240 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "The Handmaid's Tale (2017) - S01E01 - Offred (1080p BluRay x265 Silence).mkv": MPEG_TS_SD_NA_ISO
2018-04-24 22:43:45,240 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "The Handmaid's Tale (2017) - S01E01 - Offred (1080p BluRay x265 Silence).mkv": MPEG_TS_SD_KO_ISO
2018-04-24 22:43:45,241 DEBUG [VideoDAOImpl] Reading a Video (id = 417)
2018-04-24 22:43:45,242 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Length: 50000000000,Content-Type: video/mpeg,Cache-control: no-cache,Connection: close,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_EU_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,Date: Wed, 25 Apr 2018 01:43:45 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows_10 UPnP/1.0 DLNADOC/1.50 Serviio/1.9.1,transferMode.dlna.org: Streaming]]
2018-04-24 22:43:45,284 DEBUG [ServiioHttpService] Incoming request from /192.168.0.4:41518: POST /serviceControl HTTP/1.1, headers = [HOST: 192.168.0.16:8895,Accept: */*,CONTENT-LENGTH: 467,CONTENT-TYPE: text/xml; charset="utf-8",USER-AGENT: DLNADOC/1.50 SEC_HHP_[TV] UN40J6400/1.0 UPnP/1.0,SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse",Connection: close]]
2018-04-24 22:43:45,284 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.4
2018-04-24 22:43:45,284 DEBUG [ServiioHttpService] Incoming request from /192.168.0.4:41519: HEAD /resource/417/MEDIA_ITEM/MPEG_TS_SD_EU_ISO-0/ORIGINAL HTTP/1.1, headers = [getcontentFeatures.dlna.org: 1,Host: 192.168.0.16:8895,Connection: close]]
2018-04-24 22:43:45,284 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.4
2018-04-24 22:43:45,285 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.4
2018-04-24 22:43:45,285 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.4, Profile=Samsung TV / player (J-series), Name=UN40J6400'
2018-04-24 22:43:45,285 DEBUG [ResourceDeliveryProcessor] Request for resource 417 and type 'MEDIA_ITEM' received
2018-04-24 22:43:45,285 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 417 (local)
2018-04-24 22:43:45,285 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 417)
2018-04-24 22:43:45,286 DEBUG [VideoDAOImpl] Reading a Video (id = 417)
2018-04-24 22:43:45,286 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 417, format MPEG_TS_SD_EU_ISO and profile Samsung TV / player (J-series)
2018-04-24 22:43:45,287 DEBUG [AbstractAVTranscodingDeliveryEngine] Getting media info for transcoded version of file The Handmaid's Tale (2017) - S01E01 - Offred (1080p BluRay x265 Silence).mkv
2018-04-24 22:43:45,287 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "The Handmaid's Tale (2017) - S01E01 - Offred (1080p BluRay x265 Silence).mkv": MPEG_TS_SD_EU_ISO
2018-04-24 22:43:45,287 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "The Handmaid's Tale (2017) - S01E01 - Offred (1080p BluRay x265 Silence).mkv": MPEG_TS_SD_NA_ISO
2018-04-24 22:43:45,287 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "The Handmaid's Tale (2017) - S01E01 - Offred (1080p BluRay x265 Silence).mkv": MPEG_TS_SD_KO_ISO
2018-04-24 22:43:45,287 DEBUG [ContentDirectory] Browse() called for renderer UN40J6400 (profile sam_j) with parameters: objectID = V_S^SER*104^SSN*1^V*417, browseFlag = BrowseMetadata, filter = *, startIndex = 0, count = 0, sortCriteria =
2018-04-24 22:43:45,287 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_resetafterplay), returning it
2018-04-24 22:43:45,287 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Cache-control: no-cache,Connection: close,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_EU_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,Date: Wed, 25 Apr 2018 01:43:45 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows_10 UPnP/1.0 DLNADOC/1.50 Serviio/1.9.1,transferMode.dlna.org: Streaming]]
2018-04-24 22:43:45,290 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2018-04-24 22:43:45,301 DEBUG [ServiioHttpService] Incoming request from /192.168.0.4:41520: HEAD /resource/417/MEDIA_ITEM/MPEG_TS_SD_EU_ISO-0/ORIGINAL HTTP/1.1, headers = [getcontentFeatures.dlna.org: 1,TimeSeekRange.dlna.org: npt=0-,Host: 192.168.0.16:8895,Connection: close]]
2018-04-24 22:43:45,301 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.4
2018-04-24 22:43:45,302 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.4
2018-04-24 22:43:45,303 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.4, Profile=Samsung TV / player (J-series), Name=UN40J6400'
2018-04-24 22:43:45,303 DEBUG [ResourceDeliveryProcessor] Request for resource 417 and type 'MEDIA_ITEM' received
2018-04-24 22:43:45,303 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 417 (local)
2018-04-24 22:43:45,303 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 417)
2018-04-24 22:43:45,303 DEBUG [VideoDAOImpl] Reading a Video (id = 417)
2018-04-24 22:43:45,303 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 417, format MPEG_TS_SD_EU_ISO and profile Samsung TV / player (J-series)
2018-04-24 22:43:45,303 DEBUG [AbstractAVTranscodingDeliveryEngine] Getting media info for transcoded version of file The Handmaid's Tale (2017) - S01E01 - Offred (1080p BluRay x265 Silence).mkv
2018-04-24 22:43:45,304 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "The Handmaid's Tale (2017) - S01E01 - Offred (1080p BluRay x265 Silence).mkv": MPEG_TS_SD_EU_ISO
2018-04-24 22:43:45,304 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "The Handmaid's Tale (2017) - S01E01 - Offred (1080p BluRay x265 Silence).mkv": MPEG_TS_SD_NA_ISO
2018-04-24 22:43:45,304 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "The Handmaid's Tale (2017) - S01E01 - Offred (1080p BluRay x265 Silence).mkv": MPEG_TS_SD_KO_ISO
2018-04-24 22:43:45,304 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Cache-control: no-cache,Connection: close,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_EU_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,Date: Wed, 25 Apr 2018 01:43:45 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows_10 UPnP/1.0 DLNADOC/1.50 Serviio/1.9.1,TimeSeekRange.dlna.org: npt=0-3442/3442,transferMode.dlna.org: Streaming]]
2018-04-24 22:43:45,330 DEBUG [ServiioHttpService] Incoming request from /192.168.0.4:41521: GET /resource/417/MEDIA_ITEM/MPEG_TS_SD_EU_ISO-0/ORIGINAL HTTP/1.1, headers = [getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,getMediaInfo.sec: 1,Host: 192.168.0.16:8895,Connection: close]]
2018-04-24 22:43:45,330 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.4
2018-04-24 22:43:45,331 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.4
2018-04-24 22:43:45,331 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.4, Profile=Samsung TV / player (J-series), Name=UN40J6400'
2018-04-24 22:43:45,331 DEBUG [ResourceDeliveryProcessor] Request for resource 417 and type 'MEDIA_ITEM' received
2018-04-24 22:43:45,331 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 417 (local)
2018-04-24 22:43:45,331 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 417)
2018-04-24 22:43:45,331 DEBUG [VideoDAOImpl] Reading a Video (id = 417)
2018-04-24 22:43:45,332 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 417, format MPEG_TS_SD_EU_ISO and profile Samsung TV / player (J-series)
2018-04-24 22:43:45,332 DEBUG [AbstractAVTranscodingDeliveryEngine] Getting media info for transcoded version of file The Handmaid's Tale (2017) - S01E01 - Offred (1080p BluRay x265 Silence).mkv
2018-04-24 22:43:45,332 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "The Handmaid's Tale (2017) - S01E01 - Offred (1080p BluRay x265 Silence).mkv": MPEG_TS_SD_EU_ISO
2018-04-24 22:43:45,332 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "The Handmaid's Tale (2017) - S01E01 - Offred (1080p BluRay x265 Silence).mkv": MPEG_TS_SD_NA_ISO
2018-04-24 22:43:45,332 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "The Handmaid's Tale (2017) - S01E01 - Offred (1080p BluRay x265 Silence).mkv": MPEG_TS_SD_KO_ISO
2018-04-24 22:43:45,332 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 417 (local)
2018-04-24 22:43:45,332 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 417)
2018-04-24 22:43:45,333 DEBUG [VideoDAOImpl] Reading a Video (id = 417)
2018-04-24 22:43:45,333 DEBUG [VideoDeliveryEngine] Delivering item '417' for client 'Identifier=192.168.0.4, Profile=Samsung TV / player (J-series), Name=UN40J6400'
2018-04-24 22:43:45,334 DEBUG [VideoDeliveryEngine] Delivering file 'The Handmaid's Tale (2017) - S01E01 - Offred (1080p BluRay x265 Silence).mkv' using transcoding
2018-04-24 22:43:45,336 DEBUG [AbstractAVTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'Identifier=192.168.0.4, Profile=Samsung TV / player (J-series), Name=UN40J6400'
2018-04-24 22:43:45,339 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: G:\Series\The Handmaid's Tale\Season 1\The Handmaid's Tale (2017) - S01E01 - Offred (1080p BluRay x265 Silence).mkv
2018-04-24 22:43:45,340 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib\ffmpeg.exe -threads 0 -i G:\Series\The Handmaid's Tale\Season 1\The Handmaid's Tale (2017) - S01E01 - Offred (1080p BluRay x265 Silence).mkv -y -threads 0 -c:v mpeg2video -pix_fmt yuv420p -b:v 15360k -maxrate:v 15360k -bufsize:v 15360k -r 24000/1001 -g 15 -c:a:0 ac3 -b:a:0 192k -ac:a:0 2 -map 0:0 -map 0:1 -sn -f mpegts C:\Windows\TEMP\Serviio\transcoding-temp-280799a99194444ab9b3d32762b43158.stf
2018-04-24 22:43:45,985 DEBUG [TheTVDBv2SourceAdaptor] Successfully logged into thetvdb.com
2018-04-24 22:43:46,840 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2018-04-24 22:43:46,841 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "The Handmaid's Tale (2017) - S01E01 - Offred (1080p BluRay x265 Silence).mkv": MPEG_TS_SD_EU_ISO
2018-04-24 22:43:46,841 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "The Handmaid's Tale (2017) - S01E01 - Offred (1080p BluRay x265 Silence).mkv": MPEG_TS_SD_NA_ISO
2018-04-24 22:43:46,841 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "The Handmaid's Tale (2017) - S01E01 - Offred (1080p BluRay x265 Silence).mkv": MPEG_TS_SD_KO_ISO
2018-04-24 22:43:46,845 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2018-04-24 22:43:46,845 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2018-04-24 22:43:46,845 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Cache-control: no-cache,Connection: close,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_EU_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,Date: Wed, 25 Apr 2018 01:43:46 GMT,MediaInfo.sec: SEC_Duration=3442000;,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows_10 UPnP/1.0 DLNADOC/1.50 Serviio/1.9.1,transferMode.dlna.org: Streaming]]
2018-04-24 22:43:46,845 INFO  [PlaybackEventsManager] Playback of media item 417 (Offred [The Handmaid's Tale (2017) - S01E01 - Offred (1080p BluRay x265 Silence).mkv]) has started at 0% on Identifier=192.168.0.4, Profile=Samsung TV / player (J-series), Name=UN40J6400
2018-04-24 22:43:46,870 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2018-04-24 22:43:46,892 DEBUG [ServiioHttpService] Incoming request from /192.168.0.4:41523: HEAD /resource/417/MEDIA_ITEM/MPEG_TS_SD_EU_ISO-0/ORIGINAL HTTP/1.1, headers = [getcontentFeatures.dlna.org: 1,Host: 192.168.0.16:8895,Connection: close]]
2018-04-24 22:43:46,892 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.4
2018-04-24 22:43:46,893 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.4
2018-04-24 22:43:46,893 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.4, Profile=Samsung TV / player (J-series), Name=UN40J6400'
2018-04-24 22:43:46,893 DEBUG [ResourceDeliveryProcessor] Request for resource 417 and type 'MEDIA_ITEM' received
2018-04-24 22:43:46,893 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 417 (local)
2018-04-24 22:43:46,893 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 417)
2018-04-24 22:43:46,893 DEBUG [VideoDAOImpl] Reading a Video (id = 417)
2018-04-24 22:43:46,893 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 417, format MPEG_TS_SD_EU_ISO and profile Samsung TV / player (J-series)
2018-04-24 22:43:46,894 DEBUG [AbstractAVTranscodingDeliveryEngine] Getting media info for transcoded version of file The Handmaid's Tale (2017) - S01E01 - Offred (1080p BluRay x265 Silence).mkv
2018-04-24 22:43:46,894 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "The Handmaid's Tale (2017) - S01E01 - Offred (1080p BluRay x265 Silence).mkv": MPEG_TS_SD_EU_ISO
2018-04-24 22:43:46,894 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "The Handmaid's Tale (2017) - S01E01 - Offred (1080p BluRay x265 Silence).mkv": MPEG_TS_SD_NA_ISO
2018-04-24 22:43:46,894 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "The Handmaid's Tale (2017) - S01E01 - Offred (1080p BluRay x265 Silence).mkv": MPEG_TS_SD_KO_ISO
2018-04-24 22:43:46,894 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Cache-control: no-cache,Connection: close,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_EU_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,Date: Wed, 25 Apr 2018 01:43:46 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows_10 UPnP/1.0 DLNADOC/1.50 Serviio/1.9.1,transferMode.dlna.org: Streaming]]
2018-04-24 22:43:46,925 DEBUG [ServiioHttpService] Incoming request from /192.168.0.4:41524: HEAD /resource/417/MEDIA_ITEM/MPEG_TS_SD_EU_ISO-0/ORIGINAL HTTP/1.1, headers = [getcontentFeatures.dlna.org: 1,TimeSeekRange.dlna.org: npt=0-,Host: 192.168.0.16:8895,Connection: close]]
2018-04-24 22:43:46,925 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.4
2018-04-24 22:43:46,926 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.4
2018-04-24 22:43:46,926 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.4, Profile=Samsung TV / player (J-series), Name=UN40J6400'
2018-04-24 22:43:46,926 DEBUG [ResourceDeliveryProcessor] Request for resource 417 and type 'MEDIA_ITEM' received
2018-04-24 22:43:46,926 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 417 (local)
2018-04-24 22:43:46,926 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 417)
2018-04-24 22:43:46,926 DEBUG [VideoDAOImpl] Reading a Video (id = 417)
2018-04-24 22:43:46,926 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 417, format MPEG_TS_SD_EU_ISO and profile Samsung TV / player (J-series)
2018-04-24 22:43:46,926 DEBUG [AbstractAVTranscodingDeliveryEngine] Getting media info for transcoded version of file The Handmaid's Tale (2017) - S01E01 - Offred (1080p BluRay x265 Silence).mkv
2018-04-24 22:43:46,927 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "The Handmaid's Tale (2017) - S01E01 - Offred (1080p BluRay x265 Silence).mkv": MPEG_TS_SD_EU_ISO
2018-04-24 22:43:46,927 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "The Handmaid's Tale (2017) - S01E01 - Offred (1080p BluRay x265 Silence).mkv": MPEG_TS_SD_NA_ISO
2018-04-24 22:43:46,927 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "The Handmaid's Tale (2017) - S01E01 - Offred (1080p BluRay x265 Silence).mkv": MPEG_TS_SD_KO_ISO
2018-04-24 22:43:46,927 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Cache-control: no-cache,Connection: close,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_EU_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,Date: Wed, 25 Apr 2018 01:43:46 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows_10 UPnP/1.0 DLNADOC/1.50 Serviio/1.9.1,TimeSeekRange.dlna.org: npt=0-3442/3442,transferMode.dlna.org: Streaming]]
2018-04-24 22:43:46,941 DEBUG [ServiioHttpService] Incoming request from /192.168.0.4:41525: GET /resource/417/MEDIA_ITEM/MPEG_TS_SD_EU_ISO-0/ORIGINAL HTTP/1.1, headers = [getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,getMediaInfo.sec: 1,Host: 192.168.0.16:8895,Connection: close]]
2018-04-24 22:43:46,941 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.4
2018-04-24 22:43:46,942 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.4
2018-04-24 22:43:46,942 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.4, Profile=Samsung TV / player (J-series), Name=UN40J6400'
2018-04-24 22:43:46,942 DEBUG [ResourceDeliveryProcessor] Request for resource 417 and type 'MEDIA_ITEM' received
2018-04-24 22:43:46,942 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 417 (local)
2018-04-24 22:43:46,943 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 417)
2018-04-24 22:43:46,943 DEBUG [VideoDAOImpl] Reading a Video (id = 417)
2018-04-24 22:43:46,943 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 417, format MPEG_TS_SD_EU_ISO and profile Samsung TV / player (J-series)
2018-04-24 22:43:46,944 DEBUG [AbstractAVTranscodingDeliveryEngine] Getting media info for transcoded version of file The Handmaid's Tale (2017) - S01E01 - Offred (1080p BluRay x265 Silence).mkv
2018-04-24 22:43:46,944 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "The Handmaid's Tale (2017) - S01E01 - Offred (1080p BluRay x265 Silence).mkv": MPEG_TS_SD_EU_ISO
2018-04-24 22:43:46,944 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "The Handmaid's Tale (2017) - S01E01 - Offred (1080p BluRay x265 Silence).mkv": MPEG_TS_SD_NA_ISO
2018-04-24 22:43:46,944 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "The Handmaid's Tale (2017) - S01E01 - Offred (1080p BluRay x265 Silence).mkv": MPEG_TS_SD_KO_ISO
2018-04-24 22:43:46,944 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 417 (local)
2018-04-24 22:43:46,944 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 417)
2018-04-24 22:43:46,944 DEBUG [VideoDAOImpl] Reading a Video (id = 417)
2018-04-24 22:43:46,944 DEBUG [VideoDeliveryEngine] Delivering item '417' for client 'Identifier=192.168.0.4, Profile=Samsung TV / player (J-series), Name=UN40J6400'
2018-04-24 22:43:46,944 DEBUG [VideoDeliveryEngine] Delivering file 'The Handmaid's Tale (2017) - S01E01 - Offred (1080p BluRay x265 Silence).mkv' using transcoding
2018-04-24 22:43:46,945 DEBUG [AbstractAVTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'Identifier=192.168.0.4, Profile=Samsung TV / player (J-series), Name=UN40J6400'
2018-04-24 22:43:46,945 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2018-04-24 22:43:46,945 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "The Handmaid's Tale (2017) - S01E01 - Offred (1080p BluRay x265 Silence).mkv": MPEG_TS_SD_EU_ISO
2018-04-24 22:43:46,945 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "The Handmaid's Tale (2017) - S01E01 - Offred (1080p BluRay x265 Silence).mkv": MPEG_TS_SD_NA_ISO
2018-04-24 22:43:46,945 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "The Handmaid's Tale (2017) - S01E01 - Offred (1080p BluRay x265 Silence).mkv": MPEG_TS_SD_KO_ISO
2018-04-24 22:43:46,945 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2018-04-24 22:43:46,945 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2018-04-24 22:43:46,945 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Cache-control: no-cache,Connection: close,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_EU_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,Date: Wed, 25 Apr 2018 01:43:46 GMT,MediaInfo.sec: SEC_Duration=3442000;,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows_10 UPnP/1.0 DLNADOC/1.50 Serviio/1.9.1,transferMode.dlna.org: Streaming]]
2018-04-24 22:43:47,007 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2018-04-24 22:43:47,023 DEBUG [ServiioHttpService] Incoming request from /192.168.0.4:41526: HEAD /resource/417/MEDIA_ITEM/MPEG_TS_SD_EU_ISO-0/ORIGINAL HTTP/1.1, headers = [getcontentFeatures.dlna.org: 1,TimeSeekRange.dlna.org: npt=0-60,Host: 192.168.0.16:8895,Connection: close]]
2018-04-24 22:43:47,023 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.4
2018-04-24 22:43:47,024 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.4, Profile=Samsung TV / player (J-series), Name=UN40J6400'
2018-04-24 22:43:47,024 DEBUG [ResourceDeliveryProcessor] Request for resource 417 and type 'MEDIA_ITEM' received
2018-04-24 22:43:47,024 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 417 (local)
2018-04-24 22:43:47,024 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 417)
2018-04-24 22:43:47,024 DEBUG [VideoDAOImpl] Reading a Video (id = 417)
2018-04-24 22:43:47,025 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 417, format MPEG_TS_SD_EU_ISO and profile Samsung TV / player (J-series)
2018-04-24 22:43:47,025 DEBUG [AbstractAVTranscodingDeliveryEngine] Getting media info for transcoded version of file The Handmaid's Tale (2017) - S01E01 - Offred (1080p BluRay x265 Silence).mkv
2018-04-24 22:43:47,025 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "The Handmaid's Tale (2017) - S01E01 - Offred (1080p BluRay x265 Silence).mkv": MPEG_TS_SD_EU_ISO
2018-04-24 22:43:47,025 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "The Handmaid's Tale (2017) - S01E01 - Offred (1080p BluRay x265 Silence).mkv": MPEG_TS_SD_NA_ISO
2018-04-24 22:43:47,025 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "The Handmaid's Tale (2017) - S01E01 - Offred (1080p BluRay x265 Silence).mkv": MPEG_TS_SD_KO_ISO
2018-04-24 22:43:47,025 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mpeg,Cache-control: no-cache,Connection: close,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_EU_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,Date: Wed, 25 Apr 2018 01:43:47 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows_10 UPnP/1.0 DLNADOC/1.50 Serviio/1.9.1,TimeSeekRange.dlna.org: npt=0-60/3442,transferMode.dlna.org: Streaming]]
2018-04-24 22:43:47,051 DEBUG [TheTVDBv2SourceAdaptor] Searching for episode (seriesId = 73244, season = 3, episode = 24)
2018-04-24 22:43:47,052 DEBUG [ServiioHttpService] Incoming request from /192.168.0.4:41527: GET /resource/417/MEDIA_ITEM/MPEG_TS_SD_EU_ISO-0/ORIGINAL HTTP/1.1, headers = [getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.0.16:8895,Connection: close]]
2018-04-24 22:43:47,052 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.4
2018-04-24 22:43:47,053 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.4
2018-04-24 22:43:47,053 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.4, Profile=Samsung TV / player (J-series), Name=UN40J6400'
2018-04-24 22:43:47,053 DEBUG [ResourceDeliveryProcessor] Request for resource 417 and type 'MEDIA_ITEM' received
2018-04-24 22:43:47,053 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 417 (local)
2018-04-24 22:43:47,053 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 417)
2018-04-24 22:43:47,053 DEBUG [VideoDAOImpl] Reading a Video (id = 417)
2018-04-24 22:43:47,053 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 417, format MPEG_TS_SD_EU_ISO and profile Samsung TV / player (J-series)
2018-04-24 22:43:47,054 DEBUG [AbstractAVTranscodingDeliveryEngine] Getting media info for transcoded version of file The Handmaid's Tale (2017) - S01E01 - Offred (1080p BluRay x265 Silence).mkv
2018-04-24 22:43:47,054 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "The Handmaid's Tale (2017) - S01E01 - Offred (1080p BluRay x265 Silence).mkv": MPEG_TS_SD_EU_ISO
2018-04-24 22:43:47,054 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "The Handmaid's Tale (2017) - S01E01 - Offred (1080p BluRay x265 Silence).mkv": MPEG_TS_SD_NA_ISO
2018-04-24 22:43:47,054 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "The Handmaid's Tale (2017) - S01E01 - Offred (1080p BluRay x265 Silence).mkv": MPEG_TS_SD_KO_ISO
2018-04-24 22:43:47,054 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 417 (local)
2018-04-24 22:43:47,054 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 417)
2018-04-24 22:43:47,054 DEBUG [VideoDAOImpl] Reading a Video (id = 417)
2018-04-24 22:43:47,054 DEBUG [VideoDeliveryEngine] Delivering item '417' for client 'Identifier=192.168.0.4, Profile=Samsung TV / player (J-series), Name=UN40J6400'
2018-04-24 22:43:47,054 DEBUG [VideoDeliveryEngine] Delivering file 'The Handmaid's Tale (2017) - S01E01 - Offred (1080p BluRay x265 Silence).mkv' using transcoding
2018-04-24 22:43:47,055 DEBUG [AbstractAVTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'Identifier=192.168.0.4, Profile=Samsung TV / player (J-series), Name=UN40J6400'
2018-04-24 22:43:47,055 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2018-04-24 22:43:47,055 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "The Handmaid's Tale (2017) - S01E01 - Offred (1080p BluRay x265 Silence).mkv": MPEG_TS_SD_EU_ISO
2018-04-24 22:43:47,055 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "The Handmaid's Tale (2017) - S01E01 - Offred (1080p BluRay x265 Silence).mkv": MPEG_TS_SD_NA_ISO
2018-04-24 22:43:47,055 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "The Handmaid's Tale (2017) - S01E01 - Offred (1080p BluRay x265 Silence).mkv": MPEG_TS_SD_KO_ISO
2018-04-24 22:43:47,055 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2018-04-24 22:43:47,055 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2018-04-24 22:43:47,055 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Cache-control: no-cache,Connection: close,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_EU_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,Date: Wed, 25 Apr 2018 01:43:47 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows_10 UPnP/1.0 DLNADOC/1.50 Serviio/1.9.1,transferMode.dlna.org: Streaming]]
2018-04-24 22:43:47,086 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2018-04-24 22:43:47,117 DEBUG [ServiioHttpService] Incoming request from /192.168.0.4:41528: GET /resource/417/MEDIA_ITEM/MPEG_TS_SD_EU_ISO-0/ORIGINAL HTTP/1.1, headers = [getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.0.16:8895,Connection: close]]
2018-04-24 22:43:47,117 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.4
2018-04-24 22:43:47,118 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.4
2018-04-24 22:43:47,119 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.4
2018-04-24 22:43:47,119 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.4, Profile=Samsung TV / player (J-series), Name=UN40J6400'
2018-04-24 22:43:47,119 DEBUG [ResourceDeliveryProcessor] Request for resource 417 and type 'MEDIA_ITEM' received
2018-04-24 22:43:47,119 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 417 (local)
2018-04-24 22:43:47,119 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 417)
2018-04-24 22:43:47,119 DEBUG [VideoDAOImpl] Reading a Video (id = 417)
2018-04-24 22:43:47,120 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 417, format MPEG_TS_SD_EU_ISO and profile Samsung TV / player (J-series)
2018-04-24 22:43:47,120 DEBUG [AbstractAVTranscodingDeliveryEngine] Getting media info for transcoded version of file The Handmaid's Tale (2017) - S01E01 - Offred (1080p BluRay x265 Silence).mkv
2018-04-24 22:43:47,120 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "The Handmaid's Tale (2017) - S01E01 - Offred (1080p BluRay x265 Silence).mkv": MPEG_TS_SD_EU_ISO
2018-04-24 22:43:47,120 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "The Handmaid's Tale (2017) - S01E01 - Offred (1080p BluRay x265 Silence).mkv": MPEG_TS_SD_NA_ISO
2018-04-24 22:43:47,120 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "The Handmaid's Tale (2017) - S01E01 - Offred (1080p BluRay x265 Silence).mkv": MPEG_TS_SD_KO_ISO
2018-04-24 22:43:47,120 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 417 (local)
2018-04-24 22:43:47,120 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 417)
2018-04-24 22:43:47,120 DEBUG [VideoDAOImpl] Reading a Video (id = 417)
2018-04-24 22:43:47,121 DEBUG [VideoDeliveryEngine] Delivering item '417' for client 'Identifier=192.168.0.4, Profile=Samsung TV / player (J-series), Name=UN40J6400'
2018-04-24 22:43:47,121 DEBUG [VideoDeliveryEngine] Delivering file 'The Handmaid's Tale (2017) - S01E01 - Offred (1080p BluRay x265 Silence).mkv' using transcoding
2018-04-24 22:43:47,121 DEBUG [AbstractAVTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'Identifier=192.168.0.4, Profile=Samsung TV / player (J-series), Name=UN40J6400'
2018-04-24 22:43:47,121 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2018-04-24 22:43:47,122 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "The Handmaid's Tale (2017) - S01E01 - Offred (1080p BluRay x265 Silence).mkv": MPEG_TS_SD_EU_ISO
2018-04-24 22:43:47,122 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "The Handmaid's Tale (2017) - S01E01 - Offred (1080p BluRay x265 Silence).mkv": MPEG_TS_SD_NA_ISO
2018-04-24 22:43:47,123 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "The Handmaid's Tale (2017) - S01E01 - Offred (1080p BluRay x265 Silence).mkv": MPEG_TS_SD_KO_ISO
2018-04-24 22:43:47,124 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2018-04-24 22:43:47,124 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2018-04-24 22:43:47,124 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Cache-control: no-cache,Connection: close,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_EU_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,Date: Wed, 25 Apr 2018 01:43:47 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows_10 UPnP/1.0 DLNADOC/1.50 Serviio/1.9.1,transferMode.dlna.org: Streaming]]
2018-04-24 22:43:47,201 DEBUG [AbstractCDSLibraryIndexingListener] Library updated, notifying CDS
2018-04-24 22:43:47,201 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2018-04-24 22:43:47,202 DEBUG [LocalContentCacheDecorator] Cleared cache (local_default)
2018-04-24 22:43:47,706 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
And also the line I added to the profile for h265 transcoding:
    <Profile id="sam_j" name="Samsung TV / player (J-series)" extendsProfileId="1">
      <ContentDirectoryMessageBuilder>org.serviio.upnp.service.contentdirectory.SamsungTizenDLNAMessageBuilder</ContentDirectoryMessageBuilder>
      <ResourceTransportProtocolHandler>org.serviio.upnp.protocol.http.transport.SamsungWiseLinkProtocolHandler</ResourceTransportProtocolHandler>
      <Detection>
         <UPnPSearch>
            <ModelName>(^[A-Z]{2}\d{2}J[A-Z]?\d{3,4}.*)</ModelName>
            <ModelNumber>(1\.0)|(AllShare1\.0)</ModelNumber>
         </UPnPSearch>
         <HttpHeaders>
            <!-- some models only support headers -->
            <User-Agent>(.*SEC_HHP_\[TV\] [A-Z]{2}\d{2}J[A-Z]?\d{3,4}.*)</User-Agent>
         </HttpHeaders>
      </Detection>
        <MediaFormatProfiles>
            <MediaFormatProfile mime-type="video/x-matroska">MATROSKA</MediaFormatProfile>
            <MediaFormatProfile mime-type="audio/x-flac">FLAC</MediaFormatProfile>
            <MediaFormatProfile mime-type="audio/x-wav">WAV</MediaFormatProfile>
        </MediaFormatProfiles>
      <ContentDirectoryDefinitionFilter>org.serviio.upnp.service.contentdirectory.definition.SamsungContentDirectoryDefinitionFilter</ContentDirectoryDefinitionFilter>
      <H264LevelCheck>FILE_ATTRIBUTES</H264LevelCheck>
         <!-- Transcode all h264 video with HIGH/MAIN > Level 4.1 on MPEG-TS stream with MPEG2VIDEO and ac3 audio transcoding -->
         <Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" aBitrate="192" maxVBitrate="15360" forceInheritance="true">
            <Matches container="*" vCodec="h264" profile="high_10" />
            <Matches container="*" vCodec="h264" profile="high" levelGreaterThan="4.2" />
            <Matches container="*" vCodec="h264" profile="main" levelGreaterThan="4.2" />
            <!-- THIS LINE DOWN HERE -->
            <Matches container="*" vCodec="h265" />
                <Matches container="*" vCodec="dvvideo" />
                <Matches container="matroska" vCodec="vp9" />
I hope maybe you can help me guys, I dont know what to do!
Thanks!
grinningdog
Post Sat May 05, 2018 12:26 pm
Re: Samsung J-Series vs HEVC 10bits
I have the same problem if anyone can help
Post Wed May 09, 2018 8:21 am
Can the J series play any transocded files? I had a problem where it would not... My M series works .. but maybe they updated the firmware to fix this.
Fernado
Post Tue May 15, 2018 1:13 am
zip wrote:Can the J series play any transocded files? I had a problem where it would not... My M series works .. but maybe they updated the firmware to fix this.
I never thought about that... and it's true. It seems that my tv cannot play the transcoded files. I have always used codecs supported by the tv (even some I didn't know that they worked, like HEVC 8bit).
So, the tv is the problem? is there some way to fix this?
loganj01
Post Sat Dec 01, 2018 12:48 pm
i know its a bit old post but i'm trying to transcode some h264 hi10/flac video files and i ran into this post and few other while google it.
to make thinks short, the transcoder is not working. it serves the files as they are without even bothering to transcode them (no temp files are created)
So, are you sure that transcoder is working for you?
P.S.: i'm on linux
Edit: nvm my server had some problems. now it starts transcoding but the tv says unsupported format. never had this problem with emby. too bad emby has no way to decode only specific codec compression (hi10/flac only)
