MKV to TS - a bug in FFmpeg?
ozpete999
Post Tue Mar 29, 2011 5:36 pm
Following on from my experiences trying to transcode for a Toshiba TV (see the topic viewtopic.php?f=7&t=2039) I have found a recurring problem with MKV to TS.
It appears there might be some bug still in FFmpeg (link at end of this post)
I am having problems trying to successfully transcode MKVs to TS. Sometimes it works and sometimes not.
Two examples.
The following “Australian_F1.mkv” file transcodes fine. The FFmpeg –i printouts are as follows:
Input file:
C:\Program Files\Serviio\lib>ffmpeg -i Y:\Australian_F1.mkv
686-mingw32-
  libavutil     50.36. 0 / 50.36. 0
  libavcore      0.16. 0 /  0.16. 0
  libavcodec    52.108. 0 / 52.108. 0
  libavformat   52.92. 0 / 52.92. 0
  libavdevice   52. 2. 3 / 52. 2. 3
  libavfilter    1.72. 0 /  1.72. 0
  libswscale     0.12. 0 /  0.12. 0
[matroska,webm @ 0164ce60] Estimating duration from bitrate, this may be inaccur
ate
Seems stream 0 codec frame rate differs from container frame rate: 50.00 (50/1)
-> 500.00 (500/1)
Input #0, matroska,webm, from 'Y:\Australian_F1.mkv':
  Duration: 00:55:03.00, start: 0.000000, bitrate: 192 kb/s
    Stream #0.0: Video: h264, yuv420p, 1280x720 [PAR 1:1 DAR 16:9], 25 fps, 500
tbr, 1k tbn, 50 tbc
    Stream #0.1: Audio: ac3, 48000 Hz, stereo, s16, 192 kb/s
C:\Program Files\Serviio\lib>ffmpeg.exe -i "y:\Australian_F1.mkv" -y -threads 1
-vcodec mpeg2video -sameq -r 25 -g 15 -s 720x576 -copyts -acodec ac3 -ab 128k -a
c 2 -map 0:0 -map 0:1 -sn -f vob "y:\Australian_F1.ts"
Result of the TS ouput file is:
C:\Program Files\Serviio\lib>ffmpeg -i Y:\Australian_F1.ts
686-mingw32-
[mpeg @ 0164ce60] max_analyze_duration reached
Input #0, mpeg, from 'Y:\Australian_F1.ts':
  Duration: 00:00:21.92, start: 1.000000, bitrate: 4441 kb/s
    Stream #0.0[0x1e0]: Video: mpeg2video, yuv420p, 720x576 [PAR 64:45 DAR 16:9]
, 104857 kb/s, 25 fps, 25 tbr, 90k tbn, 50 tbc
    Stream #0.1[0x80]: Audio: ac3, 48000 Hz, stereo, s16, 128 kb/s
But if I transcode this "Big_Engineering.mkv" file
C:\Program Files\Serviio\lib>ffmpeg -i Y:\Big_Engineering.mkv
686-mingw32-
ate
-> 500.00 (500/1)
Input #0, matroska,webm, from 'Y:\Big_Engineering.mkv':
  Duration: 00:48:52.20, start: 0.000000, bitrate: 384 kb/s
    Stream #0.0: Video: h264, yuv420p, 1280x720, PAR 1:1 DAR 16:9, 25 fps, 500 t
br, 1k tbn, 50 tbc
    Stream #0.1: Audio: ac3, 48000 Hz, stereo, s16, 384 kb/s
using this command line
C:\Program Files\Serviio\lib>ffmpeg.exe -i "y:\Big_Engineering.mkv" -y -threads
1 -vcodec mpeg2video -sameq -r 25 -g 15 -s 720x576 -copyts -acodec ac3 -ab 128k
-ac 2 -map 0:0 -map 0:1 -sn -f vob "y:\Big_Engineering.ts"
the resulting TS is
C:\Program Files\Serviio\lib>ffmpeg -i Y:\Big_Engineering.ts
686-mingw32-
Input #0, mpeg, from 'Y:\Big_Engineering.ts':
  Duration: 00:00:22.04, start: 1.000000, bitrate: 3988 kb/s
    Stream #0.0[0x1e0]: Video: mpeg2video, yuv420p, 720x576 [PAR 1:1 DAR 5:4], 1
The audio plays, but not the video.
Even if I change the aspect by setting the NTSC setting of 720x480
1 -vcodec mpeg2video -sameq -r 25 -g 15 -s 720x480 -copyts -acodec ac3 -ab 128k
The result is an unplayable file, as follows
686-mingw32-
  Duration: 00:00:21.16, start: 1.000000, bitrate: 3609 kb/s
    Stream #0.0[0x1e0]: Video: mpeg2video, yuv420p, 720x480 [PAR 1:1 DAR 3:2], 1
So that still doesn’t work – I get no picture at all (sound is OK, though).
Putting in an aspect of –aspect 16:9 or even aspect –hd720 also doesn’t give me the correct PAR and DAR settings.
I read on the internet that prior to 0.6.1 of FFmpeg, there were problems transcoding MKV to TS successfully all the time due to a bug. Then, for 0.6.1 there was a workaround.
http://ffmpeg.arrozcru.org/forum/viewtopic.php?f=1&t=1461&st=0&sk=t&sd=a&sid=3c1c12d4f210e691c9ebb6f60c8620a8
That thread offered a workaround – but that doesn’t work either.
It may well be that this bug is still present in FFmpeg - or I am doing something incorrect.
Any help much appreciated.
Post Tue Mar 29, 2011 7:31 pm
Re: MKV to TS - a bug in FFmpeg?
If you running using Serviio's FFmpeg it might be older than 0.6.1. Otherwise you should ask the FFmpeg guys, it's not really Serviio's issue.
ozpete999
Post Wed Mar 30, 2011 2:25 am
Yes. I can understand indeed that FFmpeg problems can't be resolved by you.
Without knowing all the difficulties of using a newer or latest version of FFmpeg, is it likely that Serviio's new version would update to be using the latest FFmpeg with the latest features?
Post Wed Mar 30, 2011 8:41 am
Yes, always trying to bring the latest FFmpeg with a big Serviio release (next will be 0.6)
