MKV Fast forward
ravsbo
Post Mon Nov 10, 2014 9:38 am
MKV Fast forward
Is there a way to get the fastforward feature working when transcoding MKV files? I dont have any problems with audio as i've set that to transcode in shark007 but is there a way i can transcode on the fly to mp4 or something so that fastforward/rewind will work?
I'm on the current version of serviio using the xbone profile...
thanks
Ravsbo
colemanlee
Post Tue Oct 15, 2019 5:09 am
Re: MKV Fast forward
I also have this can not fast forward problem.
Post Tue Oct 15, 2019 7:39 pm
It is dependent on the player, but in most cases transcoded files cannot perform trick play functions (ff/rewind/resume). HLS transcoding allows trick play with most media, but still not all. But in general, FF won't work with transcoding, regardless of container.
colemanlee
Post Wed Oct 16, 2019 1:37 am
atc98092 wrote:It is dependent on the player, but in most cases transcoded files cannot perform trick play functions (ff/rewind/resume). HLS transcoding allows trick play with most media, but still not all. But in general, FF won't work with transcoding, regardless of container.
Thank you.
