Philips 58PUS6809 Transcoding problem
wattson
Post Sat Nov 27, 2021 5:40 pm
Hi, I using a Philips 58PUS6809 television with Philips (2010-) profile, but some files cannot be played.
I see this in the log:
2021-11-27 16:55:46,475 INFO [PlaybackEventsManager] Playback of media item 67624 (Captain America: The First Avenger [Amerika.kapitany.Az.elso.bosszuallo.2011.1080p.UHD.BluRay.DD+7.1.HDR.x265-gyontato.mkv]) has stopped at 0% on Identifier=192.168.1.170, Profile=Philips (2010-), Name=
2021-11-27 16:56:37,278 INFO [PlaybackEventsManager] Playback of media item 1213 (01 - A hajcsat [01 - A hajcsat.avi]) has started at 0% on Identifier=192.168.1.170, Profile=Philips (2010-), Name=
2021-11-27 16:56:44,677 INFO [PlaybackEventsManager] Playback of media item 1213 (01 - A hajcsat [01 - A hajcsat.avi]) has stopped at 1% on Identifier=192.168.1.170, Profile=Philips (2010-), Name=
2021-11-27 16:57:26,647 INFO [PlaybackEventsManager] Playback of media item 67624 (Captain America: The First Avenger [Amerika.kapitany.Az.elso.bosszuallo.2011.1080p.UHD.BluRay.DD+7.1.HDR.x265-gyontato.mkv]) has started at 0% on Identifier=192.168.1.170, Profile=Philips (2010-), Name=
2021-11-27 16:57:47,268 INFO [RendererManager] Updated an existing renderer: uuid='e27fb665-ebae-470e-ad60-ecadc5fa6324', name = 'Unrecognized device', ipAddress='192.168.1.171', profile = 'plps2010', userId = 'null'
2021-11-27 16:57:47,449 INFO [AbstractAVTranscodingDeliveryEngine] Cleaning transcode engine and its data
2021-11-27 16:57:47,450 INFO [WebServer] WebServer shutting down
2021-11-27 16:57:47,451 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2021-11-27 16:57:47,453 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2021-11-27 16:57:47,453 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2021-11-27 16:57:47,453 INFO [EventDispatcher] Leaving EventDispatcher
2021-11-27 16:57:47,454 INFO [Device] Updated bound IP address of Device with UUID: 8dee68fe-0370-3fc8-a5f5-ae4a1fb10a65, bound address: 192.168.1.10
2021-11-27 16:57:47,455 INFO [WebServer] WebServer starting on port 8895
2021-11-27 16:57:47,455 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth1 (eth1) and address 192.168.1.10, timeout = 0
2021-11-27 16:57:47,455 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2021-11-27 16:57:47,455 INFO [EventDispatcher] Starting EventDispatcher
2021-11-27 16:57:47,456 INFO [RendererSearchSender] Starting Renderer searcher process
2021-11-27 16:57:47,456 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
Anyone have an idea?
Thanks!
Post Sat Nov 27, 2021 8:33 pm
Re: Philips 58PUS6809 Transcoding problem
That Philips profile is really out of date for a 4K capable TV. Based on your log and the file name of the video you tried to play, my first guess was your TV doesn't support H.265 video. However, I just looked up that model number and it is a 4K TV, so it should support it. I've looked at the Philips profile, and it doesn't have any match for TrueHD audio, so that might be the issue if your media has that codec. As a test, you could try a different profile and see if the unsupported content can be matched and transcoded. Perhaps try the Roku 4K TV profile and see if it plays. That profile should pass your video through and just transcode any unsupported audio. Or perhaps one of the later Samsung profiles, such as the NU Series.
wattson
Post Mon Dec 06, 2021 6:15 pm
Thanks for your reply, unfortunately it didn't work with these two profiles either, it was in the log:
2021-12-06 19:03:23,794 INFO [PlaybackEventsManager] Playback of media item 71704 (Captain America: The First Avenger [Amerika.kapitany.Az.elso.bosszuallo.2011.1080p.UHD.BluRay.DD+7.1.HDR.x265-gyontato.mkv]) has started at 0% on Identifier=192.168.1.170, Profile=Roku 4K TV, Name=
2021-12-06 19:04:14,673 INFO [RendererManager] Updated an existing renderer: uuid='13a1539a-1e8a-11b2-9ad2-542aa21aa05b', name = '', ipAddress='192.168.1.170', profile = 'Samsung_NU', userId = 'null'
2021-12-06 19:04:14,840 INFO [AbstractAVTranscodingDeliveryEngine] Cleaning transcode engine and its data
2021-12-06 19:04:14,841 INFO [WebServer] WebServer shutting down
2021-12-06 19:04:14,843 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2021-12-06 19:04:14,843 INFO [EventDispatcher] Leaving EventDispatcher
2021-12-06 19:04:14,843 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2021-12-06 19:04:14,844 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2021-12-06 19:04:14,847 INFO [WebServer] WebServer starting on port 8895
2021-12-06 19:04:14,847 INFO [Device] Updated bound IP address of Device with UUID: 8dee68fe-0370-3fc8-a5f5-ae4a1fb10a65, bound address: 192.168.1.10
2021-12-06 19:04:14,847 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2021-12-06 19:04:14,848 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth1 (eth1) and address 192.168.1.10, timeout = 0
2021-12-06 19:04:14,848 INFO [EventDispatcher] Starting EventDispatcher
2021-12-06 19:04:14,848 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2021-12-06 19:04:14,848 INFO [RendererSearchSender] Starting Renderer searcher process
2021-12-06 19:05:43,198 INFO [PlaybackEventsManager] Playback of media item 71704 (Captain America: The First Avenger [Amerika.kapitany.Az.elso.bosszuallo.2011.1080p.UHD.BluRay.DD+7.1.HDR.x265-gyontato.mkv]) has started at 0% on Identifier=192.168.1.170, Profile=Samsung TV (NU-series), Name=
Post Tue Dec 07, 2021 12:27 am
The Serviio developer will likely need to see a debug log to determine what's happening. That log info you provided isn't detailed enough to see what might be happening.
wattson
Post Wed Dec 08, 2021 6:42 pm
The value in the log file was set to "DEBUG", attach the serviio.log file (compressed)
serviio.zip
(398 KiB) Downloaded 408 times
Post Wed Dec 08, 2021 11:13 pm
OK, Zip will need to look that over. While I see some error messages, I really don't understand what they mean. But I'm suspicious of perhaps an issue with non-Latin characters in your file names. Again, merely a guess on my part, so someone with more experience in the debug log will need to look it over. If Zip doesn't respond to this thread in a few days, I suggest sending him a private message with a link to this thread, in case he misses it.
wattson
Post Thu Dec 09, 2021 8:03 am
Ok, thanks!
wattson
Post Wed Dec 15, 2021 4:31 pm
Hi, Zip didn't answer, but I don't see where I can send him a message. Thanks for the help!
Post Wed Dec 15, 2021 11:38 pm
There's a line of links at the top of the page, and one says "0 new messages". (assuming you have no unread messages). Click that to enter the messaging function, and you can send him a PM there.
wattson
Post Thu Dec 16, 2021 8:57 am
I wrote him, thank you!
Post Mon Jan 17, 2022 11:41 am
So 2 things:
- I don't think you enabled DEBUG log, or at least not when you tried to play that Avengers movie.
- it's a h265 movie, perhaps the newest Samsung profile doesn't transcode it. You could try one of the older Samsung profiles, or post debug log using the Philips profile.
Users browsing this forum: Ask Jeeves [Bot] and 10 guests
