.MOV file not able to play on DIRECTV HR24
icehanger
Post Tue Aug 02, 2011 5:14 am
My ffmpeg output
FFmpeg version 0.6.2-4:0.6.2-1ubuntu1, Copyright (c) 2000-2010 the Libav developers
built on Mar 22 2011 15:55:04 with gcc 4.5.2
configuration: --extra-version=4:0.6.2-1ubuntu1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --enable-shared --disable-static
WARNING: library configuration mismatch
libavutil configuration: --extra-version=4:0.6.2-1ubuntu2 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libdirac --enable-libgsm --enable-libopenjpeg --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-libopenjpeg --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libfaad --enable-libdirac --enable-libfaad --enable-libmp3lame --enable-librtmp --enable-libx264 --enable-libxvid --enable-libdc1394 --enable-shared --disable-static
libavcodec configuration: --extra-version=4:0.6.2-1ubuntu2 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libdirac --enable-libgsm --enable-libopenjpeg --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-libopenjpeg --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libfaad --enable-libdirac --enable-libfaad --enable-libmp3lame --enable-librtmp --enable-libx264 --enable-libxvid --enable-libdc1394 --enable-shared --disable-static
libswscale configuration: --extra-version=4:0.6.2-1ubuntu2 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libdirac --enable-libgsm --enable-libopenjpeg --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-libopenjpeg --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libfaad --enable-libdirac --enable-libfaad --enable-libmp3lame --enable-librtmp --enable-libx264 --enable-libxvid --enable-libdc1394 --enable-shared --disable-static
libpostproc configuration: --extra-version=4:0.6.2-1ubuntu2 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libdirac --enable-libgsm --enable-libopenjpeg --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-libopenjpeg --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libfaad --enable-libdirac --enable-libfaad --enable-libmp3lame --enable-librtmp --enable-libx264 --enable-libxvid --enable-libdc1394 --enable-shared --disable-static
libavutil 50.15. 1 / 50.15. 1
libavcodec 52.72. 2 / 52.72. 2
libavformat 52.64. 2 / 52.64. 2
libavdevice 52. 2. 0 / 52. 2. 0
libavfilter 1.19. 0 / 1.19. 0
libswscale 0.11. 0 / 0.11. 0
Seems stream 0 codec frame rate differs from container frame rate: 60000.00 (60000/1) -> 29.97 (30000/1001)
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'MVI_0840.MOV':
major_brand : qt
minor_version : 537331968
compatible_brands: qt CAEP
Duration: 00:03:08.35, start: 0.000000, bitrate: 47049 kb/s
Stream #0.0(eng): Video: h264, yuv420p, 1920x1088, 45510 kb/s, 29.97 fps, 29.97 tbr, 30k tbn, 60k tbc
Stream #0.1(eng): Audio: pcm_s16le, 48000 Hz, 2 channels, s16, 1536 kb/s
Post Tue Aug 02, 2011 7:07 am
Re: .MOV file not able to play on DIRECTV HR24
Which profile did you used?
Could you enable detailed logging (see signature) and look at ffmpeg command line, an try locally the same command line?
icehanger
Post Wed Aug 03, 2011 4:13 am
I was using the generic profile, I selected the DIRECTV profile now the .MOV files are playing, but the play back is choppy. The format is canon DSLR HD format.
