ffmpeg 6.1 (7 Channel) audio
Nihilator
Post Tue Nov 15, 2011 2:10 am
Hi guys,
Does ffmpeg support 6.1 (7-channel) audio?
I have the following DTS-ES file and it errors when trying to manually convert it to AC-3 (5.1 channel):
ID :
1
Format :
DTS
Format/Info :
Digital Theater Systems
Format profile :
ES
Codec ID :
A_DTS
Duration :
3h 48mn
Bit rate mode :
Constant
Bit rate :
1 510 Kbps
Channel(s) :
7 channels / 6 channels
Channel positions :
Front: L C R, Side: L R, Back: C, LFE / Front: L C R, Side: L R, LFE
Sampling rate :
48.0 KHz
Bit depth :
24 bits
Compression mode :
Lossy
Stream size :
2.41 GiB
Language :
English
I am using the following command:
ffmpeg -i /DTS-ES/The.Lord.of.the.Rings.The.Fellowship.of.the.Ring.Extended.Editions.2001.1080p.Blu-ray.DTS.x264-WiKi.mka -vn -threads 8 -acodec ac3 -ac 6 -f ac3 -ab 640k /AC-3/The.Lord.of.the.Rings.The.Fellowship.of.the.Ring.Extended.Editions.2001.1080p.Blu-ray.DTS.x264-WiKi.mka
The error I am receiving is:
Can not resample 6 channels @ 48000 Hz to 6 channels @ 48000 Hz
Post Tue Nov 15, 2011 9:55 am
Re: ffmpeg 6.1 (7 Channel) audio
can you post ffmpeg -i of the original?
Nihilator
Post Tue Nov 15, 2011 3:14 pm
built on Jan 12 2011 19:51:48 with gcc 4.0.1 (Apple Inc. build 5493)
configuration: --enable-static --disable-shared --bindir=/tmp/ffmpeg --disable-ffplay --disable-ffserver --enable-libmp3lame --enable-pthreads --disable-mmx --extra-ldflags=-L/tmp/static/lib --extra-cflags=-I/tmp/static/include
libavutil 50.36. 0 / 50.36. 0
libavcore 0.16. 0 / 0.16. 0
libavfilter 1.72. 0 / 1.72. 0
libswscale 0.12. 0 / 0.12. 0
[matroska,webm @ 0x1009600] Estimating duration from bitrate, this may be inaccurate
Input #0, matroska,webm, from '/DTS-ES/The.Lord.of.the.Rings.The.Fellowship.of.the.Ring.Extended.Editions.2001.1080p.Blu-ray.DTS.x264-WiKi.mka':
Duration: 03:48:11.67, start: 0.000000, bitrate: 1536 kb/s
Stream #0.0(eng): Audio: dca, 48000 Hz, 7 channels (FL|FR|FC|LFE|BC|SL|SR), s16, 1536 kb/s
Post Tue Nov 15, 2011 3:24 pm
seems ok, but your FFmpeg is quite old. Are you using the one bundled with Serviio?
Nihilator
Post Tue Nov 15, 2011 4:19 pm
The bottom line is:
I know ffmpeg is able to transcode DTS 5.1 (6-channel) to AC-3 5.1 (AKA: 6-channel) .........BUT I don't think ffmpeg is capable of downmixing DTS-ES 6.1 (AKA: 7-channel) down to AC-3 5.1 (AKA: 6-channel).
Post Tue Nov 15, 2011 4:56 pm
It seems it does work: viewtopic.php?f=5&t=3759#p25085
LLoyd
Post Thu Nov 24, 2011 2:31 am
Nihilator and Zip,
ffmpeg does not support decoding DTS tracks over 5.1 (6-channel).
DTS-HD (7-channel or 8-channel) decoding will most likely never be supported by ffmpeg (due to expense and copyright infringement).
You will receive the following error if you try to decode a DTS-HD 6.1 or 7.1 audio track with ffmpeg:
Resampling with input channels greater than 2 unsupported.
