Samsung D7000 and 60fps 1080p
pavel
Post Fri Mar 16, 2012 11:09 am
my D7000 can plays almost everything - except 1080p 60fps files. But my PC can play that. Everytime I try to play such a file, there is error message that codec is not supported (that it not true - it is f.e. Divx, but in 1080p 60fps). I am totally IT dump and new to Seviio, but can someone give me advise how to set profiles.xml to play these video files? Thank you very much.
Pavel
Post Fri Mar 16, 2012 11:59 am
Re: Samsung D7000 and 60fps 1080p
If this framerate 60fps is not supported by your device, you need to transcode this file.
But for the moment, Serviio could not distinguish divx/30fps with divx/60fps.
So for this particular file, you need to select another profile on seviio console that will transcode all divx files (ex:Sony TV 2010).
Could you provide information about this file, "ffmpeg -i" or MediaInfo tools result in text format ?
pavel
Post Fri Mar 16, 2012 5:49 pm
Illico wrote:If this framerate 60fps is not supported by your device, you need to transcode this file.
Mediainfo:
Format : AVI
File size : 48.8 MiB
Duration : 20s 621ms
Overall bit rate : 19.8 Mbps
TCOD : 0
TCDO : 206206000
Format : MPEG-4 Visual
Format profile : Simple@L1
Format settings, BVOP : No
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (MPEG)
Codec ID : DIVX
Codec ID/Info : Project Mayo
Codec ID/Hint : DivX 4
Bit rate : 18.3 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 59.940 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.147
Stream size : 44.9 MiB (92%)
Writing library : Lavc52.62.0
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Signed
Codec ID : 1
Bit rate mode : Constant
Bit rate : 1 536 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 3.78 MiB (8%)
Interleave, duration : 982 ms (58.86 video frames)
When I set profile to Sony Bravia TV 2010, it does not have any effect - result is the same. I have enabled transcoding but it seems to me that it does not work. I have AMD 9650 Quad-core 2,3Ghz (4GB Ram) now running on old WinXP.
pavel
Post Fri Mar 16, 2012 6:16 pm
And when I resample the video to 30fps it works
Post Sat Mar 17, 2012 7:46 am
pavel wrote:When I set profile to Sony Bravia TV 2010, it does not have any effect - result is the same.
Its probably because the ffmpeg transcoding command line use the same framerate option (60fps).
Check the detailed logging file (see signature).
