Lousy transcoding with Panasonic Viera GT30
rkman
Post Sat Apr 21, 2012 6:08 pm
My MPEG transcoding has really bad ghosting. It happens for all transcoded files, whether SD or HD, regardless of formats and containers.
TV: Panasonic Viera TC-P55GT30
Serviio 0.6.2 on Windows 7 64-bit
Also, can someone tell me how to disable the MediaItemDAOImpl and other crap from filling up my debug log so I can find the actual problem? I'm guessing this has something to do with the ffmpeg command line parameters, because when I manually use ffmpeg to convert the file into something the TV can natively play, it's fine.
profiles.xml
This is my tweaked profiles.xml
(14.17 KiB) Downloaded 902 times
Post Sat Apr 21, 2012 6:23 pm
Re: Lousy transcoding with Panasonic Viera GT30
look here to filter out library logs: viewtopic.php?f=3&t=1796
rkman
Post Sun Apr 22, 2012 8:56 pm
OK, so here is the ffmpeg transcode command from the log:
2012-04-22 16:18:18,729 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -i movie.avi -y -threads 4 -async 1 -vcodec mpeg2video -sameq -r 30000/1001 -g 15 -copyts -acodec copy -map 0:0 -map 0:1 -sn -f mpegts C:\Windows\TEMP\Serviio\transcoding-temp-5444-MPEG2TS.stf
Here's ffmpeg -i output:
  configuration: --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-memalign-hack --enable-libmp3lame --enable-librtmp --extra-libs='-lrtmp -lpolarssl -lws2_32 -lwinmm' --arch=x86 --enable-runtime-cpudetect --enable-pthreads --target-os=mingw32 --cross-prefix=i686-mingw32- --pkg-config=pkg-config
  libavutil    51. 32. 0 / 51. 32. 0
  libavcodec   53. 42. 0 / 53. 42. 0
  libavformat  53. 24. 0 / 53. 24. 0
  libavfilter   2. 53. 0 /  2. 53. 0
Seems stream 0 codec frame rate differs from container frame rate: 29.98 (65535/2186) -> 29.97 (30000/1001)
Input #0, avi, from 'movie.avi':
    encoder         : VirtualDubMod 1.5.4.1 (build 2178/release)
    IAS1            : English
  Duration: 01:54:59.35, start: 0.000000, bitrate: 1702 kb/s
    Stream #0:0: Video: mpeg4 (Advanced Simple Profile) (XVID / 0x44495658), yuv420p, 640x368 [SAR 1:1 DAR 40:23], 29.97 tbr, 29.97 tbn, 29.98 tbc
    Stream #0:1: Audio: ac3 ([0] [0][0] / 0x2000), 48000 Hz, stereo, s16, 192 kb/s
This movie produces awful ghosting during the titles/credits and pretty bad ghosting (fuzzy edges, like you're seeing double) overall.
1. I can't find -sameq in the ffmpeg documentation, has it been deprecated?
2. What ffmpeg params do you suggest I tinker with or add?
3. Is there an easier way to customize the ffmpeg command without the PERL kludge posted in the forums?
Post Thu Apr 26, 2012 4:57 pm
rkman wrote:1. I can't find -sameq in the ffmpeg documentation, has it been deprecated?
Interesting, looks like they removed it from there recently. Try to use -qscale 1 instead (should be the same as sameq)
