AVC_TS_MP_SD_AAC_MULT5_ISO and MKV format
ackwdw123
Post Sat Jun 23, 2012 1:59 am
Hi everyone, I'm running into a situation with streaming the mkv format to a Panasonic device. I enabled Debug/tracing but the log didn't show any errors.
This is the message in the log:
2012-06-22 16:09:25,275 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Vacation.Part.1.mkv: AVC_TS_MP_SD_AAC_MULT5_ISO
Here is my device and the profile I am using:
Panasonic DMP BDT-210
Using the Generic DLNA Profile
I added the following to the profiles.xml file under the Generic DLNA Profile:
<MediaFormatProfile mime-type="video/mkv">AVC_TS_MP_SD_AAC_MULT5_ISO</MediaFormatProfile>
When I tried to search the forum for AVC_TS_MP_SD_AAC_MULT5_ISO the following was returned and I didn't want to cause any problems with the forum:
SQL ERROR [ mysql4 ]
The SELECT would examine more than MAX_JOIN_SIZE rows; check your WHERE and use SET SQL_BIG_SELECTS=1 or SET SQL_MAX_JOIN_SIZE=# if the SELECT is okay [1104]
An SQL error occurred while fetching this page. Please contact the Board Administrator if this problem persists.
So I'm trying to understand if I need to add something else to the profiles.xml. Using a different Sony bluray player/dlna device the files stream perfectly. Any help or guidance is greatly appreciated.
~ack
ackwdw123
Post Sat Jun 23, 2012 1:36 pm
Re: AVC_TS_MP_SD_AAC_MULT5_ISO and MKV format
Hi everyone, I did some testing this morning and this is what I found:
I enabled DEBUG and noticed in the DEBUG log that this device is being recognized with the following: Profile=Panasonic Viera
2012-06-23 08:37:49,491 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.5, Profile=Panasonic Viera'
My device is a Panasonic DMP BDT-210
I changed this from the Generic DLNA Profile to the Panasonic Viera Profile and now I see a transcoding .stf file. The playback is 1-2 seconds then a 3-5 second delay, then playback is 1-2 seconds and a 3-5 second delay, this loop continues. I (randomly) changed to the Toshiba REGZA profile and I now see transcoding happening. I disabled transcoding and watched the DEBUG log. I see the following:
2012-06-23 09:23:03,351 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: No media description available for required version: MPEG_TS_SD_NA_ISO
org.serviio.dlna.UnsupportedDLNAMediaFileFormatException: No media description available for required version: MPEG_TS_SD_NA_ISO
I will post any updates later when I do some more testing.
