transcode with Ue40c5100
sidecar12
Post Fri Nov 26, 2010 1:48 pm
Big thanks for your soft it's great !
I try to transcode mkv files with samsung C profile but nothing happen.
how can i check if transcode start? It's seem it do not start?
Sidecar12
Post Fri Nov 26, 2010 2:14 pm
Re: transcode with Ue40c5100
Please read the "HOW TO" topics viewforum.php?f=5
You can check if transcode start in the detailed log file.viewtopic.php?f=5&t=7
sidecar12
Post Fri Nov 26, 2010 2:37 pm
Thank,i try to make it
Sidecar12
Post Fri Nov 26, 2010 3:17 pm
Also, the C Samsungs play almost everything, what is your file? ffmpeg -i
sidecar12
Post Fri Nov 26, 2010 4:39 pm
Please read this there are 2 files inside that samsung doesn't play
C:\Mirc download>ffmpeg -i +++++.mkv
FFmpeg version SVN-r25456-Sherpya, Copyright (c) 2000-2010 the FFmpeg developers
built on Oct 14 2010 16:46:15 with gcc 4.2.5 20090330 (prerelease) [Sherpya]
libavutil 50.32. 3 / 50.32. 3
libavcore 0. 9. 1 / 0. 9. 1
libavcodec 52.92. 0 / 52.92. 0
libavformat 52.81. 0 / 52.81. 0
libavdevice 52. 2. 2 / 52. 2. 2
libavfilter 1.51. 1 / 1.51. 1
libswscale 0.12. 0 / 0.12. 0
[matroska,webm @ 01a5d150] Estimating duration from bitrate, this may be inaccurate
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (48000/1001) -> 24.00 (24/1)
Input #0, matroska,webm, from '+++++.mkv':
Duration: 02:28:07.96, start: 0.000000, bitrate: 384 kb/s
Stream #0.0(ita): Video: h264, yuv420p, 1280x536 [PAR 1:1 DAR 160:67], 23.98 fps, 24 tbr, 1k tbn, 47.95 tbc
Stream #0.1(ita): Audio: ac3, 48000 Hz, 5.1, s16, 384 kb/s
C:\Mirc download>ffmpeg -i ++++++.mkv
[matroska,webm @ 01a5cd70] Estimating duration from bitrate, this may be inaccurate
Seems stream 1 codec frame rate differs from container frame rate: 47.95 (48000/1001) -> 24.00 (24/1)
Input #0, matroska,webm, from '++++++.mkv':
Duration: 01:33:10.56, start: 0.000000, bitrate: 640 kb/s
Stream #0.0(ita): Audio: ac3, 48000 Hz, 5.1, s16, 640 kb/s
title : AC3.LONDON
Stream #0.1(eng): Video: h264, yuv420p, 1280x544 [PAR 1:1 DAR 40:17], 23.98 fps, 24 tbr, 1k tbn, 47.95 tbc
title : 720p.BluRay.x264-REFiNED
Sidecar12
sidecar12
Post Fri Nov 26, 2010 4:54 pm
Here the file for supported formats of my device UE40C5100
Sidecar12
Log samsungue40c5100.7z
(919 Bytes) Downloaded 829 times
sidecar12
Post Sat Nov 27, 2010 8:56 am
Hi at all
I attached file with debug (i hope it's correct)
Sorry if it's wrong i'm newbie
Waiting your answer :|
Best regards
sidecar12
Log debug.rar
(1.01 KiB) Downloaded 876 times
Post Sat Nov 27, 2010 8:02 pm
The log is from playing a AVI file. Your files are MKV with H264/AC3 ... the TV sometimes doesn't play some files with H264 even though it normally supports it... it's just picky. Not much we can do unless you're willing to transcode into mpeg2
