Transcoding only Audio DTS to ac3.
kuche
Post Thu Aug 09, 2012 9:55 pm
i want to transcode all movie with DTS AudioCodec to ac3. The video-Codec should not be touched, cause my TV can play every Video-Format and the CPU-Powerusage would be too high.
I already wrote a profile, but i think it's not doing what it should do.
Here my work till now:
<Profile id="150" name="Grundig " extendsProfile="1">
<Detection>
<HttpHeaders>
<X-AV-Client-Info>.*Grundig*.</X-AV-Client-Info>
</HttpHeaders>
<UPnPSearch>
<ModelName> Grundig </ModelName>
</UPnPSearch>
</Detection>
<Mathces container="matroska" />
The audio transcoding works, but i think it does also video transcoding, what i don't want it to do.
Thanks for any help.
Post Fri Aug 10, 2012 5:38 am
Re: Transcoding only Audio DTS to ac3.
kuche wrote:The audio transcoding works, but i think it does also video transcoding, what i don't want it to do.
Replace:
by
-> All files with DTS audio will be remuxed to MPEGTS container, video codec copy and audio ac3 transcoded.
There is a syntax error Mathces vs Matches on your example.
Post Fri Aug 10, 2012 10:09 am
Also Detection is wrong (based on Sony, will be different for Grundig), so you can remove it (not that it'll help you with transcoding)
brianmel
Post Wed Aug 15, 2012 7:22 pm
Hi, I have a samsung lcd series 5 d550 tv, and I saw that the profile in serviio is for led tv.
Therefore it doesnt decode .dts files, and i want to add that to the profile.
I really dont know if my tv support ac3, and i haven't a HT so i prefer transcode to mp3
How it have to be?
<Video targetContainer="mpegts" targetACodec="mp3" aBitrate="192" forceStereo="true">
Post Wed Aug 15, 2012 8:07 pm
Try the B series profile, it transcodes DTS to AC3
