Is it a transcoding problem? Flv live stream
sam_tv
Post Thu Nov 15, 2012 11:39 am
I'm trying to watch this live stream from EarthCam, on my Samsung d5500 Led tv,
but i get an error: ""video codec not supported"
rtmp://video2.earthcam.com/fecnetwork/4017timessquare.flv.flv pageUrl=http://www.earthcam.com swfUrl=http://www.earthcam.com/swf/cam_player_v2/ecnPlayer.swf?20120504_a live=1
Is it related to a transcoding problem, like it says here?
viewtopic.php?f=10&t=3618
https://bitbucket.org/xnejp03/serviio/i ... transcoded
If yes, how can i fix it? what should i change/add in the profile ?
Please help :-)
Post Fri Nov 16, 2012 1:12 pm
Re: Is it a transcoding problem? Flv live stream
post result of
ffmpeg -i "rtmp://video2.earthcam.com/fecnetwork/4017timessquare.flv.flv pageUrl=http://www.earthcam.com swfUrl=http://www.earthcam.com/swf/cam_player_v2/ecnPlayer.swf?20120504_a live=1"
Post Fri Nov 16, 2012 5:10 pm
The stream plays fine for me on mediabrowser, and ffmpeg reports it as a valid avc/aac.flv stream. However flv is is not a valid stream according to samsungs documentation even though most C/D series play avc.flv streams ok, but perhaps yours does not, so you could try removing this line from the profile which will then cause the file to be transcoded to mpeg2video.
sam_tv
Post Sat Nov 17, 2012 12:08 am
zip wrote:post result of
Hi this is the result:
C:\Program Files\Serviio\lib>ffmpeg -i "rtmp://video2.earthcam.com/fecnetwork/40
g-config
  videocodecid          avc1
  width                 800.00
  height                450.00
  frameWidth            800.00
  frameHeight           450.00
  displayWidth          800.00
  displayHeight         450.00
  audiochannels         1.00
  audiosamplerate       16000.00
  audiocodecid          mp4a
trackinfo:
  timescale             90000.00
  language              eng
sampledescription:
  sampletype            H264
  type                  video
  profile-level-id      420014
  sprop-parameter-sets  Z0IAFOKQGQd/EYC3AQEB4eJEVA==,aM48gA==
  description           {H264CodecConfigInfo: profile: "Baseline", level: 2.0, f
rameSize: 800x450, displaySize: 800x450, PAR: 1:1, crop: l:0 r:0 t:0 b:7}
  timescale             16000.00
  language              eng
sampledescription:
  sampletype            MPEG4-GENERIC
  type                  audio
  config                1408
  description           {AACFrame: size: 0, rate: 16000, channels: 1, samples: 1
024, errorBitsAbsent: true, profileObjectType: "LC"}
rtpsessioninfo:
  connectiondata        IN IP4 204.107.64.58
  information           -
  name                  Live
  origin                - 867497653 867497653 IN IP4 127.0.0.1
  timing                0 0
  protocolversion       0
attributes:
  x-qt-text-cmt         source application:H.264 Encoder
  x-qt-text-inf         -
  x-qt-text-nam         Live
  x-qt-text-cpy         2011
  x-qt-text-aut         EarthCam
[flv @ 0199C060] Estimating duration from bitrate, this may be inaccurate
Input #0, flv, from 'rtmp://video2.earthcam.com/fecnetwork/4017timessquare.flv.f
_v2/ecnPlayer.swf?20120504_a live=1':
    frameWidth      : 800
    frameHeight     : 450
    displayWidth    : 800
    displayHeight   : 450
    audiochannels   : 1
  Duration: N/A, start: 0.000000, bitrate: N/A
    Stream #0:0: Video: h264 (Baseline), yuvj420p, 800x450 [SAR 1:1 DAR 16:9], 1
4.99 tbr, 1k tbn, 2k tbc
    Stream #0:1: Audio: aac, 16000 Hz, mono, s16
jhb50 wrote:The stream plays fine for me on mediabrowser, and ffmpeg reports it as a valid avc/aac.flv stream. However flv is is not a valid stream according to samsungs documentation even though most C/D series play avc.flv streams ok, but perhaps yours does not, so you could try removing this line from the profile which will then cause the file to be transcoded to mpeg2video.
That SOLVED the problem :D
I thought that the "OnlineTranscoding" in the profile is controlling live streaming.
What is "OnlineTranscoding" is for?
Again, Thank you.
Post Sat Nov 17, 2012 12:20 am
For additional rules required for online. After they are applied(if any) the regular transcoding rules are then applied. First rule that fits is used.
sam_tv
Post Sun Nov 18, 2012 8:28 pm
Thank you :)
sam_tv
Post Tue Jan 08, 2013 12:25 pm
Hi
After upgrading to serviio 1.1, i'm getting this "video codec not supported" error again.
I checked and in the profile the line " <Matches container="flv" vCodec="h264" />" does not appear.
anyone know what is the problem?
Just to remind, my tv is Samsung LED D5500 46" .
Here is the ffmpeg run:
C:\Program Files\Serviio\lib>ffmpeg -i "rtmp://video2.earthcam.com/fecnetwork/hd
times11.flv.flv swfUrl=http://www.earthcam.com/swf/cam_player_v2/ecnPlayer.swf p
ageUrl=http://www.earthcam.com/usa/newyork/timessquare/?cam=tsstreet live=1"
g-config
  videocodecid          avc1
  width                 800.00
  height                450.00
  frameWidth            800.00
  frameHeight           450.00
  displayWidth          800.00
  audiochannels         1.00
  audiocodecid          mp4a
trackinfo:
  timescale             90000.00
  language              eng
sampledescription:
  sampletype            H264
  type                  video
  profile-level-id      420029
  sprop-parameter-sets  Z0IAKeKQGQd/EYC3AQEB4eJEVA==,aM48gA==
  description           {H264CodecConfigInfo: profile: "Baseline", level: 4.1, f
  timescale             16000.00
  language              eng
sampledescription:
  sampletype            mpeg4-generic
  type                  audio
  config                1408
rtpsessioninfo:
  emailaddress          NONE
  name                  Media Presentation
  origin                - 1357630902964703 1357630902964703 IN IP4 155.229.76.14
  timing                0 0
  protocolversion       0
attributes:
  range                 npt=0.000000-
[flv @ 01A0C080] Estimating duration from bitrate, this may be inaccurate
Input #0, flv, from 'rtmp://video2.earthcam.com/fecnetwork/hdtimes11.flv.flv swf
Url=http://www.earthcam.com/swf/cam_player_v2/ecnPlayer.swf pageUrl=http://www.e
arthcam.com/usa/newyork/timessquare/?cam=tsstreet live=1':
    frameWidth      : 800
    frameHeight     : 450
    displayWidth    : 800
    displayHeight   : 450
    audiochannels   : 1
Thank you.
EDIT: I just installed serviio 1.01, and it's working with it. what went wrong with the newer version (1.1) ?
Users browsing this forum: Baidu [Spider] and 2 guests
