Flac with WDTV or Nokia Lumia 920
Liftboy
Post Thu Dec 20, 2012 9:22 am
Hi!
I tried to figure out and search here - maybe I'm too noob :)
I have a Windows Home Server 2011 (Server 2008) and Serviio 1.1 on it. I tried to play flac files on my Nokia Lumia 920 Windows Phone, but only mp3 and WMA lossless are working. That would be a transcoding problem and I don't know where to find possible configuration entries.
Secondly I also tried to play Flac files through my WDTV Live box (wich normally is working nativ with this files) w/o success. I used my Lumia as an remote for this.
Could you please give a beginner here a small hint?
Frank
Post Thu Dec 20, 2012 4:01 pm
Re: Flac with WDTV or Nokia Lumia 920
According to my info (http://wiki.serviio.org/doku.php?id=dev ... at_support), the WDTV doesn't support FLAC via DLNA natively. So you'd have to add this to your WDTV profile:
<Profile id="14" name="WDTV Live" extendsProfileId="1">
        <Detection>
            <UPnPSearch>
                <ModelName>WD TV HD Live</ModelName>
            </UPnPSearch>
        </Detection>
                <Matches container="wtv" />
            <Video targetContainer="mpeg" targetVCodec="mpeg2video" targetACodec="ac3" aBitrate="384">
                <Matches container="flv" /> <!-- this is used by online content, assuming WDTV cannot play local flv either -->
                <Matches container="rm" />
                <Matches container="ogg" />
                <Matches container="flac" />
            </Audio>
        <OnlineTranscoding>
                <Matches container="mp4" />
                <Matches container="asf" /> <!-- for mms:// -->
        </OnlineTranscoding>
You can try to use the same profile for playing the files on your Nokia, although I'm not sure it supports LPCM.
Liftboy
Post Fri Dec 21, 2012 3:03 am
Thank you very much for your help!
I'll try this and take a closer look.
Frank
Liftboy
Post Thu Dec 27, 2012 8:49 am
I thought that the WD TV Live could play via dlna Flac using a HomeServer and a remote. I also tried AVM Fritz! Repeater with an optical out with the same result. Both only working with mp3 files through dlna.
Directly those items support flac format. I added als the configuration file w/o success.
With the WIldMediaServer (I hate the licence modell) it worked also through dlna. What can I do or better what streaming client should I buy to use flac files in this case?
Regards,
Frank
Post Thu Dec 27, 2012 11:16 pm
try this:
        <Detection>
            <UPnPSearch>
            </UPnPSearch>
        </Detection>
       <MediaFormatProfiles>
                <MediaFormatProfile mime-type="audio/x-flac">FLAC</MediaFormatProfile>
      <MediaFormatProfile mime-type="audio/x-ogg">OGG</MediaFormatProfile>
        </MediaFormatProfiles>
        <OnlineTranscoding>
Post Sat Dec 29, 2012 3:57 am
This post made me check my new Nokia 920 phone, and I installed an app called MyMediaHub. I will stream from my Windows 7 computers with no issue, but refuses to play anything from my Serviio box, regardless of the video type. I've tried the generic profile, WDTV and PS3 with no success. I then tried the XBox 360 profile and thought I found the fix. It begins loading the video file, then stops. The banner on the phone app says it is opening the file, then suddenly closes it. Hitting play just repeats the process.
Any ideas, anyone?
Liftboy
Post Fri Jan 11, 2013 12:50 pm
Something new? ;)
Post Sat Jan 12, 2013 5:53 pm
Did you try the last profile?
Liftboy
Post Sat Jan 12, 2013 6:51 pm
Yes, for WDTV and Lumia920.
Frank
Post Sun Jan 13, 2013 3:57 pm
what is the result on wdtv?
Liftboy
Post Sun Jan 13, 2013 5:20 pm
No Playback. I'll take a closer look, what will happen. Is somewehre a log that I can post?
Regards and thanks!
Frank
Post Tue Jan 15, 2013 5:12 pm
yes, read the READ BEFORE POSTING topics in support section
