GPU Accelerated Transcoding
bollerfant
Post Sat Mar 30, 2013 8:52 pm
i have a HP ProLiant MicroServer N40L with Windows 8 installed. This system should serve my TV as a UPNP Server.
I have an additional, spare (currently NOT installed) AMD 6450 HD graphics card.
Will Serviio use less CPU time and the GPU instead, when i install the 6450HD and use the serviio transcoding?
Or in general: Do i need the transcoding for my TV: Philips 42PFL4007K/12.
Sorry i am not an expert in streaming and didn't find any threads regarding "6450", "gpu" or similar...
Regards
bollerfant
slyguy42o
Post Sat Mar 30, 2013 10:17 pm
Re: GPU Accelerated Transcoding
all of serviio's transcoding is done by ffmpeg, which I don't think currently has gpu accelerated encoding.
jnahon
Post Sun Mar 31, 2013 3:20 pm
As far as I know ffmepg doesn't support HW Accel for transcoding, if you were watching the files live on the server than yes you would have improvements ... atleast this is how I have seen it preform.
samurai
Post Sun May 12, 2013 10:13 pm
I know this is old post ,but my tesla gpu's get a little hotter when the machine is transcoding
I set the serviio exe to run through them hard to say if this is really working
have not checked ffmpeg exe to run on the gpu's I would know more if I can get a quadro card
to support cuda pipe
Users browsing this forum: Google [Bot] and 8 guests
