Transcoding Files
afflictor
Post Thu May 09, 2013 2:38 pm
Transcoding Files
Hello, I have one question about transcoding.
I have a LG TV and use the lg tv profile. When I want to play a mkv file it says me thatthe file is an invalid format. But the transcoding file went bigger and bigger, but playback stops. Why went the file bigger?
Post Thu May 09, 2013 2:59 pm
Re: Transcoding Files
The ffmpeg process (that does the transcoding) will continue even after it has failed on your TV. The file will get bigger until it is fully transcoded. It will be deleted eventually.
Post details of the file that doesn't play and we may be able to help you with that. See here for how to provide this info - MediaInfo will provide the better information.
afflictor
Post Thu May 09, 2013 4:10 pm
Ah ok, thanks for info. I was only wondering that after failing the file is getting bigger.
Here is the file, that won't play..
Other files with dts would play with transcoding.
ffmpeg.txt
FFMPEG
(3.46 KiB) Downloaded 751 times
afflictor
Post Sat May 11, 2013 1:17 pm
What about the file?
Post Sat May 11, 2013 2:11 pm
Sorry, I lost track of this thread.
Have you edited your profile (the standard LG profile in 1.2.1 doesn't do any transcoding, but your OP suggests that the mkv file was being transcoded)? Anyway, assuming its the standard profile....
Some LG TV's do not support DTS audio. The standard LG profile in Serviio has some code commented out that transcodes DTS. Try my post: viewtopic.php?f=5&t=10355&p=68933#p68933 and see if this rectifies the problem for this file. If that doesn't work then post the details of the file using MediaInfo (see viewtopic.php?f=5&t=4510).
afflictor
Post Sun May 12, 2013 9:51 pm
Yeah I commendet that out, that dts is transcoding. Other files play normally, but they are a little smaller! Maybe this is the problem!
I provide Media Info File later.
afflictor
Post Wed May 15, 2013 6:57 pm
Sorry for the long delay, but here is the mediainfo:
Allgemein
Unique ID : 226039760225596423139431270958746666245 (0xAA0DAC9DE14C59B2BC4CECFC63B58505)
Complete name : \\10.0.0.1\video\movies\8 Mile (2002)\8 Mile_(2002)_1080p.mkv
Format : Matroska
Format version : Version 2
File size : 14,4 GiB
Duration : 1h 50min
Overall bit rate : 18,6 Mbps
Encoded date : UTC 2010-02-08 22:22:06
Writing application : mkvmerge v3.1.0 ('Happy up here') gebaut am Jan 19 2010 12:09:24
Writing library : libebml v0.7.9 + libmatroska v0.8.1
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Ja
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 50min
Bit rate : 16,7 Mbps
Width : 1 920 Pixel
Height : 814 Pixel
Display aspect ratio : 2,35:1
Frame rate mode : konstant
Frame rate : 23,976 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : progressiv
Bits/(Pixel*Frame) : 0.446
Stream size : 12,3 GiB (86%)
Writing library : x264 core 84 r1416kMod fcf70c2
Encoding settings : cabac=1 / ref=5 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=umh / subme=9 / psy=1 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=6,6 / fast_pskip=0 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=0 / mbaff=0 / constrained_intra=0 / bframes=4 / b_pyramid=0 / b_adapt=2 / b_bias=-20 / direct=3 / wpredb=1 / wpredp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc=2pass / mbtree=0 / bitrate=16713 / ratetol=1000000000.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.10 / pb_ratio=1.10 / aq=2:0.70
Language : Englisch
Default : Nein
Forced : Nein
Audio #1
Format : DTS
Mode : 16
Codec ID : A_DTS
Duration : 1h 50min
Bit rate mode : konstant
Bit rate : 768 Kbps
Channel(s) : 6 Kanäle
Sampling rate : 48,0 KHz
Bit depth : 24 bits
Stream size : 607 MiB (4%)
Language : Deutsch
Default : Ja
Forced : Nein
Audio #2
Format : DTS
Mode : 16
Codec ID : A_DTS
Duration : 1h 50min
Bit rate : 1 509 Kbps
Bit depth : 24 bits
Stream size : 1,16 GiB (8%)
Language : Englisch
Default : Nein
Forced : Nein
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Language : Deutsch
Default : Ja
Forced : Nein
Text #2
Format : UTF-8
Language : Deutsch
Default : Nein
Forced : Nein
Text #3
Format : UTF-8
Language : Englisch
Default : Nein
Forced : Nein
Menü
00:00:00.000 : :00:00:00.000
00:03:11.942 : :00:03:11.942
00:10:07.899 : :00:10:07.899
00:14:51.724 : :00:14:51.724
00:19:51.357 : :00:19:51.357
00:23:31.035 : :00:23:31.035
00:27:20.889 : :00:27:20.889
00:34:40.870 : :00:34:40.870
00:38:59.796 : :00:38:59.796
00:46:49.390 : :00:46:49.390
00:52:54.338 : :00:52:54.338
01:01:47.871 : :01:01:47.871
01:06:02.417 : :01:06:02.417
01:11:44.133 : :01:11:44.133
01:13:47.965 : :01:13:47.965
01:16:44.934 : :01:16:44.934
01:24:30.732 : :01:24:30.732
01:27:56.438 : :01:27:56.438
01:38:19.143 : :01:38:19.143
01:43:30.538 : :01:43:30.538
01:45:29.114 : :01:45:29.114
Post Thu May 16, 2013 9:45 am
As a test, you can try reducing the video bitrate for the file - change your present LG profile to (lines 2 to 4 are new, the rest should already be there):
   <Video targetContainer="mpegts" targetVCodec="mpeg2video" maxVBitrate="12000" targetACodec="ac3" aBitrate="384">
      <Matches container="matroska" vCodec="h264" profile="high" levelGreaterThan="4.0" />
   <Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" aBitrate="384" >
      <Matches container="flv" />
      <Matches container="asf" vCodec="wmv2"/>
      <Matches container="rm" />
If it works then try varying the maxVBitrate to "15000" and then "17000" to find how high we can go before failing. The problem with this is it will transcode files that may not need to be, but lets work out what's happening first.
afflictor
Post Fri May 17, 2013 3:33 pm
No it says again, invalid file. And with this Profile, encoding is very slow!! So other video files won't work or are very very slow.
Post Fri May 17, 2013 10:53 pm
That's fine. This was only designed to test whether bit rate was the issue - it may pay to do one more test with a low bit rate, say 4000 to rule it out all together.
If you remove lines 2-4 in the above do you end up back with the profile you started with? If not can you please post your profile just so we are on the same page.
How many files are failing?
afflictor
Post Sat May 18, 2013 12:32 pm
Here is my current profile. It workes fine (til now) with all video files except the one above from me.
<Profile id="8" name="LG TV / player" extendsProfileId="1">
      <Detection>
         <HttpHeaders>
            <friendlyName.dlna.org>LG.*</friendlyName.dlna.org>
         </HttpHeaders>
      </Detection>
      <!-- ResourceTransportProtocolHandler>org.serviio.upnp.protocol.http.transport.LGProtocolHandler</ResourceTransportProtocolHandler -->
      <MediaFormatProfiles>
         <MediaFormatProfile mime-type="video/mp4" name="">AVI</MediaFormatProfile>
      </MediaFormatProfiles>
         <Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" >
      <Subtitles>
         <SoftSubs mime-type="text/srt" />
      </Subtitles>
Post Sun May 19, 2013 6:39 am
Given that it is only one file, and that I can't see anything obvious from MediaInfo for the file, it could simply be that this file is malformed in some way. It may be simpler to re-mux this file - try, from the command prompt:
    "path\ffmpeg.exe" -i "\\10.0.0.1\video\movies\8 Mile (2002)\8 Mile_(2002)_1080p.mkv" -map 0 -vcodec copy -acodec copy test.mkv
substituting path to where your copy of the ffmpeg command is (in Windows 7 this is C:\Program Files\Serviio\lib\). This will simply re-mux the video and audio to a new mkv container (test.mkv). See if that plays or has the same error.
Failing this you may want to look at MakeMKV to recreate the mkv file.
afflictor
Post Mon May 20, 2013 7:41 pm
thx for the tip, but with this command I get something like this:
[matroska @ 0xfa85c0] st:0 PTS: 6626325 DTS: 6626325 < 6626353 invalid, clipping
[matroska @ 0xfa85c0] st:0 PTS: 6626335 DTS: 6626335 < 6626353 invalid, clipping
[matroska @ 0xfa85c0] st:0 PTS: 6626345 DTS: 6626345 < 6626353 invalid, clipping
frame=158908 fps=165 q=-1.0 Lsize=15093964kB time=01:50:27.71 bitrate=18656.5kbits/s
And I think this "invalid" is something bad.
afflictor
Post Thu May 23, 2013 5:45 pm
I cannot create a new mkv file wih MakeMKV.. It said, that he had failed.
Post Fri May 24, 2013 12:24 am
Can you actually watch this movie direct eg. On your PC.
afflictor
Post Fri May 24, 2013 9:12 am
Yes on my notebook with VLC it works. Because of that I'm asking why only that video isn't working :P
Post Fri May 24, 2013 10:48 am
You should be able to re-package the file using MakeMKV. As you can't, and because of the errors you have when ffmpeg'ing it, it looks like this file is stuffed in some way. Have you played it all the way through in VLC (looks like the error could be late in the movie)?
In any case, it seems to be a one off, so you wouldn't change the Serviio profile to cater for it (even if you could work it out, you'd likely make all other mkv's unplayable). I'd try to get the file from its source again.
afflictor
Post Fri May 24, 2013 2:47 pm
MakeMKV starts to convert, and in middle of the process it fails!! At start it says, track 4-6 were skipped because of an error or because of the type.
And I think I remember, that I played the file over Seagate GoFlex TV.
I played it everytime with VLC.
Don't worry about the one file. Something is wrong. I can download it again xD
Thanks for the help :D
