Subtitles disable transcoding
valli
Post Sat Jun 01, 2013 9:48 pm
I run 1.2.1 version on windows xp and LG LW650 ( no dts ) as renderer
I use LG renderer profile ( id=8 ) with dts transcoding and having next problem when i want to play an mkv with dts sound and no embedded sub ( with "burned-in sub disabled" ):
1.if no external sub are put in folder all work ok , dts is transcoding nice with cpu load under 50% , of course no sub playing
2.if i put external sub in folder , lg dlna browswer show only movie name , without thumbnail , without movie lenght , and nothing happened when press play
Now , same mkv with dts sound and no embeddes sub but now with "burned-in sub enabled"
1.if no external sub are put in folder all work ok , dts is transcoding nice with cpu load under 50% ,of course no sub playing
2.if i put again external sub in folder dts transcoding buffering a lot with cpu load near 100% , sub play ok , but even if i stop playing cpu load stay near 100% due to ffmpeg.exe until exit serviio
Again same mkv with dts sound but now with embedded sub , no external sub :
1.if "embedded sub is disable" all work ok , dts is transcoding nice with cpu load under 50% , of course no sub playing
2.if "embedded sub is enable" , lg dlna browswer show only movie name , without thumbnail , without movie lenght , and nothing happened when press play
3.if both "embedded sub is enable" and "burned-in sub enabled" LW650 exit from dlna mode with message "no server found "
If i choose Generic profile all come back to normal but of course no sound
Now big question is : it is a bug of serviio , it is a bug of LW650 or i just need a better profile ?
Thank you
LE : All above behaviours appear only when "burned-in sub enabled" with "always" option
Post Sun Jun 02, 2013 1:24 pm
Re: Subtitles disable transcoding
valli wrote:I use LG renderer profile ( id=8 ) with dts transcoding and having next problem when i want to play an mkv with dts sound and no embedded sub ( with "burned-in sub disabled" ):
Can you send detailed log of this case (point 2)?
That is expected, it transcodes the file until the end.
valli
Post Sun Jun 02, 2013 6:41 pm
I think 1 picture woth more than 1000 words !
I set serviio to share only 2 mkv in a folder , one with dts sound and another with ac3 sound , burned-in sub disabled , then exit serviio
1.Open serviio without any external sub , transcoding work ok for file with dts , and both files are displayed ok as you can see in picture 614
2.Open serviio with external sub for both mkv , only file with ac3 have info as you can see in picture 615 , the other one is unavailable for playing
In serviio.log same modus , first half is without sub , second half with sub
I compare myself and look pretty similar , just 2 lines have reverse order
What next ?
Thank you
(15.87 KiB) Downloaded 611 times
Post Sun Jun 02, 2013 11:09 pm
the log, you have to enable detailed log
valli
Post Mon Jun 03, 2013 6:32 am
Done
I try again to look inside and now are to many differences
Procedure was same for both file , second have sub also :
Start server , start console , browse movie with my LW650 , save log
Thank you
sub.log
(96.76 KiB) Downloaded 611 times
no sub.log
(98.12 KiB) Downloaded 645 times
Post Mon Jun 03, 2013 12:36 pm
It all looks fine. I reproduced your setup and the only difference the server sends is the additional external srt resource. So looks like the TV doesn't like external subs for transcoded files..
Users browsing this forum: Google [Bot] and 7 guests
