Transcoding problem for playback on a Sony BDP-S370?? Help
n3mmr
Post Thu Dec 12, 2013 1:31 pm
I've got this file that won't play back on my Sony BDP-S370 via Serviio.
What could/should I do??
hans@klaus%66%14:24> /usr/local/bin/ffmpeg -i 1\ -\ Star.Tr.mp4        ffmpeg version N-52264-g6189ff3 Copyright (c) 2000-2013 the FFmpeg developers
  built on Apr 19 2013 19:26:03 with gcc 4.6.3 (GCC)
  configuration: --enable-mmx --enable-sse --enable-ssse3 --disable-debug --enable-nonfree --enable-gpl --enable-runtime-cpudetect --enable-postproc --enable-avfilter --enable-swscale --enable-libgsm --enable-libxvid --enable-libx264 --enable-libfaac --enable-libtheora --enable-libmp3lame --enable-libvorbis --enable-libvpx --enable-x11grab --enable-libspeex --enable-pthreads --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-version3 --disable-static --enable-libschroedinger --enable-libopenjpeg --enable-librtmp --enable-vdpau --enable-libass --enable-openssl --enable-openal --enable-shared
  libavutil      52. 27.100 / 52. 27.100
  libavcodec     55.  3.100 / 55.  3.100
  libavformat    55.  3.100 / 55.  3.100
  libavdevice    55.  0.100 / 55.  0.100
  libavfilter     3. 58.100 /  3. 58.100
  libswscale      2.  2.100 /  2.  2.100
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '1 - Star.Tr.mp4':
    major_brand     : isom
    minor_version   : 1
    compatible_brands: isomavc1
    creation_time   : 2012-10-03 18:23:57
  Duration: 02:12:00.30, start: 0.000000, bitrate: 2539 kb/s
    Chapter #0.0: start 0.000000, end 101.518000
      title           :
    Chapter #0.1: start 101.518000, end 530.905000
      title           :
    Chapter #0.2: start 530.905000, end 709.292000
      title           :
    Chapter #0.3: start 709.292000, end 1246.203000
      title           :
    Chapter #0.4: start 1246.203000, end 1512.970000
      title           :
    Chapter #0.5: start 1512.970000, end 1681.179000
      title           :
    Chapter #0.6: start 1681.179000, end 1891.223000
      title           :
    Chapter #0.7: start 1891.223000, end 2282.822000
      title           :
    Chapter #0.8: start 2282.822000, end 2676.382000
      title           :
    Chapter #0.9: start 2676.382000, end 2887.760000
      title           :
    Chapter #0.10: start 2887.760000, end 3328.283000
      title           :
    Chapter #0.11: start 3328.283000, end 3675.380000
      title           :
    Chapter #0.12: start 3675.380000, end 4340.628000
      title           :
    Chapter #0.13: start 4340.628000, end 4648.853000
      title           :
    Chapter #0.14: start 4648.853000, end 4915.202000
      title           :
    Chapter #0.15: start 4915.202000, end 5241.319000
      title           :
    Chapter #0.16: start 5241.319000, end 5894.222000
      title           :
    Chapter #0.17: start 5894.222000, end 6378.205000
      title           :
    Chapter #0.18: start 6378.205000, end 6716.919000
      title           :
    Chapter #0.19: start 6716.919000, end 7716.250000
      title           :
    Chapter #0.20: start 7716.250000, end 7920.298333
      title           :
    Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p, 1920x816, 2228 kb/s, 23.98 fps, 23.98 tbr, 24k tbn, 47.95 tbc
      handler_name    : Video
    Stream #0:1(eng): Audio: aac (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 84 kb/s
      creation_time   : 2012-10-03 18:24:58
      handler_name    : GPAC ISO Audio Handler
    Stream #0:2(eng): Audio: aac (mp4a / 0x6134706D), 48000 Hz, 5.1, fltp, 221 kb/s
      creation_time   : 2012-10-03 18:25:01
mightymouse2045
Post Tue Dec 17, 2013 6:49 pm
Re: Transcoding problem for playback on a Sony BDP-S370?? He
n3mmr wrote:I've got this file that won't play back on my Sony BDP-S370 via Serviio.
    major_brand     : isom
    minor_version   : 1
      title           :
      title           :
      title           :
      title           :
      title           :
      title           :
      title           :
      title           :
      title           :
      title           :
      title           :
      title           :
      title           :
      title           :
      title           :
      title           :
      title           :
      title           :
      title           :
      title           :
      title           :
What's happening? The screen is blank with sound, or u can see the movie but no sound, or u get an error displayed on screen?
Probably you need to transcode the movie. Try setting a profile for your tv in serviio console
Sent from my GT-P7500 using Tapatalk
